Sample deepstream_nvdsanalytics_test - Can’t remove object outside ROI from meta object list
I’m running the sample deepstream_nvdsanalytics_test (c++) and I don’t understand why the objects outside ROI are not deleted.
For example, I defined a ROI and as you can see, there is one vehicle in the ROI but the log still contains more vehicles (7):
Frame Number = 104 of Stream = 0 ; Number of objects = 7 ; Vehicle Count = 7 ; Objs in ROI RF = 1
• DeepStream Version
• TensorRT Version
Jetson Nano
Deepstream 6.0.1
Jetpack 4.6.2
• TensorRT Version
TensorRT 8
Docker image nvcr.io/nvidia/deepstream-l4t-6.0.1-samples
Sample deepstream_nvdsanalytics_test (c++)
did you modify the code or configuration file? if yes, please share the diff.
I have not changed anything
what is your video input?
/opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4
“Number of objects = 7” means there are 7 objects in the whole picture, “Vehicle Count = 7” means there are 7 vehicles in the whole picture, “Objs in ROI RF = 1” means there are one object in the ROI. please refer to nvdsanalytics_src_pad_buffer_probe of deepstream_nvdsanalytics_test.cpp,
In the config_nvdsanalytics.txt file:
## Per stream configuration
[roi-filtering-stream-0]
#enable or disable following feature
enable=1
#ROI to filter select objects, and remove from meta data
roi-RF=700;0;1300;0;1300;200;700;200
#remove objects in the ROI
inverse-roi=0
class-id=-1
It is indicated that the filtered objects are removed from the metadata (#ROI to filter select objects, and remove from meta data). However, the objects are still in obj_meta_list.
Each object (l_obj) is browsed in the obj_meta_list with the loop :
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
And the filtered objects are still in this list.
How can we remove them?
“inverse-roi = 0” means only count the objects inside the ROI, it will not remove object mea, if want to remove meta, please refer to Cannot remove obj from frame meta - #6 by minhsaco99
