**• Hardware Platform (Jetson / GPU)**tx2 • DeepStream Version5.0
**• JetPack Version (valid for Jetson only)**4.4 • TensorRT Version7.1 • NVIDIA GPU Driver Version (valid for GPU only)
Hi everybody,
I’ve tested deepstream-nvdsanalytics app and got to know how to retrieve the analytic data, like objInROIcnt, objLCCumCnt… But I have a question: If I have a time table/schedule for each ROI, in off-duty cycle, the above mentioned figures should set to zero. How can I update these figures? I’ve tried function like nvds_remove_user_meta_from_frame but it did not work. The OSD screen display did not change accordingly. I think this has nothing to do with topic:“User/Custom Metadata Addition inside NvDsBatchMeta”, am I wrong? Please provide some advices.
I used nvdsanalytics plugin along with deepstream-app. In parse_nvdsanalytics_meta_data()function:
NvDsAnalyticsFrameMeta *meta =
(NvDsAnalyticsFrameMeta *) user_meta->user_meta_data;
/* Get the labels from nvdsanalytics config file */
for (std::pair<std::string, uint32_t> status : meta->objInROIcnt){
// filtering with schedule
status.first = "i do not konw!!!!";
out_string << " Objs in ROI ";
out_string << status.first;
out_string << " = ";
out_string << status.second;
I set values for status.first or status.second and got the updated values in terminals, but the displayed string values on OSD windows unchanged. And I tried to remove the value pairs by calling nvds_remove_user_meta_from_frame() just before above mentioned statements and it again did not effect OSD display.
My question is:
How can I manually change values in user/custom metadata such as analytics which are already existing in NvDsBatchMeta? Because I’m aware that if I want to add new user metadata, I need to follow the method in “sample_apps/deepstream-user-metadata-test”.
What is the best practice to filter analytics metadata according to a time shedule? Do I need to write a plugin or just use a probe to retrieve data, change them and write back from analytics plugin’s src pad/osd plugin’s sink pad?
