Deepstream 5.0 Gst-nvdsanalytics access meta data in Python
I am trying to use the new Gst-nvdsanalytics plugin to gather line counting data and send it to azure IOT using the msg conv and broker.
I have my python script (a combination of deepstream-test3 and 4) working and can see the analytics lines and counts on the osd and data to going to azure IOT hub.
How do I access the analytics data to send it to azure? I am after the frame analytics information. From the plugin docs I have this: The analytics output (Frame level) is encapsulated in the NvDsAnalyticsFrameMeta structure and is added as user meta with meta_type set to NVDS_USER_FRAME_META_NVDSANALYTICS.The user meta is added to the frame_user_meta_list member of NvDsFrameMeta. Code below:
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
l_user = frame_meta.frame_user_meta_list
After that I am not sure, any help would be much appreciated :)
Still having issues here. Looking at the python docs I can see that the following casting functions are available:
NvDsBatchMeta.cast
NvDsFrameMeta.cast
NvDsObjectMeta.cast
NvDsUserMeta.cast
NvDsClassifierMeta.cast
NvDsDisplayMeta.cast
NvDsLabelInfo.cast
NvDsEventMsgMeta.cast
NvDsVehicleObject.cast
NvDsPersonObject.cast
When i look at the deepstream_nvdsanalytics_test.cpp example I see that the frame analytics data is accessed using:
NvDsAnalyticsFrameMeta *meta =(NvDsAnalyticsFrameMeta *) user_meta->user_meta_data;
Does that mean I cannot access the analytics data using the Python bindings because there is no NvDsAnalyticsFrameMeta.cast in python bindings?
Hey Customer,
nvdsanalytics is a new plugin added in DS5.0, currently we cannot access NvDsAnalyticsFrameMeta in python app, just like what you said we need to add Python bingdings to support it in upcoming release.
Thanks, will wait for the next release of the python bindings. Understand that time frames on development are hard but is this a week, month, 6 months timeline?
Same question here, we need to access NvDsAnalyticsFrameMeta in python app, otherwise we cannot get the number of line crossing objects etc. Do you guys have release roadmap? Thanks.
Not yet support this in DS5.0-GA?
https://docs.nvidia.com/metropolis/deepstream/python-api/NvDsAnalytics/NvDsAnalyticsFrameMeta.html
Deepstream 5.0 is released still no casting functions available, how do we access the metadata or will have to wait for it.
I was wondering if anyone has an example to set the nvdsanayltics plugin parameters,
Im assuming it would go after the pgie->tracker->nvdsanalytics
Below is my thinking for how we would set each streams properties
# Set properties of tracker
config = configparser.ConfigParser()
config.read('config_nvdsanalytics.txt')
config.sections()
print('config',config)
for key in config:
    # print('key',key)
    # print('val',config[key])
    section = config[key]
    print('section',section)
    if section.name == "property":
        for sec_key,val in section.items():
            print('sec_key',sec_key,val)
            if key == 'enable':
                dsA = config.get('enable', sec_key)
                analytics.set_property('enable', dsA)
            if key == 'config-width':
                dsA_width = config.get('config-width', sec_key)
                analytics.set_property('config-width', dsA_width)
            if key == 'config-height':
                dsA_height = config.get('config-height', sec_key)
                analytics.set_property('config-height', dsA_height)
    else:
        if 'stream' in section.name:
            analytics.set_property(sec_key, section.name)
                #section <Section: roi-filtering-stream-0>
                #sec_key enable 1
                #sec_key roi-rf 295;643;579;634;642;913;56;828
                #sec_key inverse-roi 0
                #sec_key class-id -1
                analytics.set_property(sec_key, val)
Nevermind I completely over thought it, I found reference from “deepstream_nvdsanalytics_test.cpp”
if it helps anyone else the solution is simply
analytics.set_property( “config-file”, “config_nvdsanalytics.txt”)
Is there an update on this?
This may make me switch to the c++ api
Pls refer Deepstream 5.0 python bindings for Gst-nvdsanalytics access meta data - #18 by niels.kjaergaard.madsen
