Hello. I’m having some trouble adding custom info to DeepStream meta data in a python Gstreamer plugin.
I wrote minimal gst plugin based on GstBase.BaseTransform basically only implementing 2 functions
def do_transform_ip(self, buffer: Gst.Buffer):
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
if not batch_meta:
return Gst.FlowReturn.OK
pyds.nvds_acquire_meta_lock(batch_meta)
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
except StopIteration:
break
user_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
if user_meta:
message = 'test'
fill_user_meta(user_meta, message)
pyds.nvds_add_user_meta_to_frame(frame_meta, user_meta)
else:
Gst.info('failed to acquire user meta')
try:
l_frame = l_frame.next
break
pyds.nvds_release_meta_lock(batch_meta)
def do_stop(self) -> bool:
pyds.unset_callback_funcs()
return True
The idea is to pass some string message in a NvDsUserMeta using NvDsEventMsgMeta structure. This is how I alloc and fill the structure
def fill_user_meta(meta: pyds.NvDsUserMeta, msg: str):
data = pyds.alloc_nvds_event_msg_meta()
data.otherAttrs = msg
meta.user_meta_data = data
meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
pyds.set_user_copyfunc(meta, meta_copy_func)
pyds.set_user_releasefunc(meta, meta_free_func)
def meta_copy_func(data, user_data) -> pyds.NvDsEventMsgMeta:
user_meta = pyds.glist_get_nvds_user_meta(data)
src_meta = pyds.glist_get_nvds_event_msg_meta(user_meta.user_meta_data)
dst_meta_ptr = pyds.memdup(pyds.get_ptr(src_meta), sys.getsizeof(pyds.NvDsEventMsgMeta))
dst_meta = pyds.glist_get_nvds_event_msg_meta(dst_meta_ptr)
dst_meta.otherAttrs = pyds.get_string(dst_meta.otherAttrs)
return dst_meta
def meta_free_func(data, user_data):
pyds.free_buffer(src_meta.otherAttrs)
However, my test pipeline doesn’t finish cleanly. When I run the following command in a Docker container based on nvcr.io/nvida/deepstream:4.0.2-19.12-devel with Python DS bindings
GST_DEBUG=python:4 \
gst-launch-1.0 uridecodebin uri=file:///<path to 1080p sample.mp4> \
! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 \
! nvinfer config-file-path=<path to config_infer_primary.txt> \
! my_plugin \
! fakesink sync=false
At the end of processing I get
Got EOS from element "pipeline0".
Execution ended after 0:00:02.036809166
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
terminate called after throwing an instance of 'pybind11::error_already_set'
what(): SystemError: <built-in method glist_get_nvds_user_meta of PyCapsule object at 0x7f90ceedcae0> returned a result with an error set
At:
/opt/app/perception/event_msg_meta_helper.py(44): meta_free_func
What am I doing wrong? Any advice will be much appreciated.
