Hi!
I want to access user data with python .
but i can’t make it with python and could make it with c++.
How can i do this with python
while l_user is not None:
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
NVDS_USER_FRAME_META_NVDSANALYTICS = pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META")
#NVDS_USER_FRAME_META_DSANALYTICSOBJ = pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META")
if user_meta.base_meta.meta_type == NVDS_USER_FRAME_META_NVDSANALYTICS:
meta = user_meta.user_meta_data
if meta is not None:
try:
string1="LineCrossing Cumulativ:{}".format(meta.objLCCumCnt)
print(string1)
except StopIteration:
break
try:
string1="LineCrossing current frame:{}".format(meta.objLCCurrCnt)
print(string1)
a=1
break
• Hardware Platform (Jetson / GPU) : jetson nano • DeepStream Version : 5.0 • TensorRT Version : 7.0.0-1 • NVIDIA GPU Driver Version (valid for GPU only):
please try describing the issue as clear as possible!
What do you mean “i can’t make it”, does it crash or return invalid valid when you access it ?
objLCCumCnt is element of NvDsAnalyticsFrameMeta, did you run Gst-nvdsanalytics?
I make my app that count number of people crossing line with nvdsanalytics api.
I set pipeline and it run well with display.
When i get the data in NvDsAnalyticsFrameMeta, i have this error.
How can i get the data in NvDsAnalyticsFrameMeta by python
This is callback function.
def tiler_sink_pad_buffer_probe(pad,info,u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
break
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
class_id = obj_meta.class_id
confidence = round(obj_meta.confidence,3)
#print("{}'s confidence={}".format(class_id,confidence))
try:
l_obj=l_obj.next
break
l_user = frame_meta.frame_user_meta_list
print(user_meta.base_meta.meta_type)
try:
string2="LineCrossing current frame:{}".format(meta.objLCCurrCnt)
print(string1)
print(string2)
break
try:
l_user = l_user.next
break
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
and i have error below.
raceback (most recent call last):
File “/home/humani/Documents/apc_project/main.py”, line 66, in tiler_sink_pad_buffer_probe
string1=“LineCrossing Cumulativ:{}”.format(meta.objLCCumCnt)
AttributeError: ‘PyCapsule’ object has no attribute ‘objLCCumCnt’
