• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• Issue Type( questions, new requirements, bugs) questions
I am developing with Python and I’ve been trying to access tensor_meta in the preprocess example (deepstream-preprocess-test), but frame_meta.frame_user_meta_list is always None.
The same method works fine when not using nvdspreprocess. What could be the reason for this issue?
--- deepstream_preprocess_test_1.py 2024-06-12 15:23:57.794090819 +0800
+++ deepstream_preprocess_test.py 2024-06-12 15:24:54.493681793 +0800
@@ -85,19 +85,6 @@
except StopIteration:
break
- l_user = frame_meta.frame_user_meta_list
- print(l_user)
- while l_user is not None:
- try:
- user_meta = pyds.NvDsUserMeta.cast(l_user.data)
- except StopIteration:
- break
- if user_meta.base_meta.meta_type != pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META:
- continue
- tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
- print(tensor_meta)
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
