Hi everyone,
I am facing a problem with empty Tensor meta data. Based on
I built a small pipeline with two models (first one is a detector and second one is a classifier). My source is a video file (.h264 format). At the end of my pipeline I used
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
to print the user meta data list via
pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data).
where user_meta is of the form obj_meta.obj_user_meta_list.
However, for some frames the TensorMeta object is None although the detector found an object in the frame (there are some frames for which I actually get an array with the corresponding probabilities of the classifier). Moreover, there are also frames which contain no objects but anyway they contain TensorMeta data.
For a better understanding I post the osd_sink_pad_buffer_probe function:
PGIE_CLASS_ID_LUGGAGE = 1
def gst_meta_list_loop(func):
def wrapper(meta_list):
listiter = meta_list
while listiter:
try:
yield func(listiter.data)
listiter = listiter.next
except StopIteration:
break
return wrapper
@gst_meta_list_loop
def frame_meta_list(batch_meta_data):
“”" Used to obtain a generator object to loop over a batch_meta_data_list. “”"
return pyds.NvDsFrameMeta.cast(batch_meta_data)
@gst_meta_list_loop
def object_meta_list(object_meta_data):
“”" Used to obtain a generator object to loop over a object_meta_data_list. “”"
return pyds.NvDsObjectMeta.cast(object_meta_data)
@gst_meta_list_loop
def user_meta_list(object_meta_data):
return pyds.NvDsUserMeta.cast(object_meta_data)
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
# Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_LUGGAGE: 0
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
for frame_meta in frame_meta_list(batch_meta.frame_meta_list):
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
for obj_meta in object_meta_list(frame_meta.obj_meta_list):
for user_meta in user_meta_list(obj_meta.obj_user_meta_list):
tensor_data = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
layer = pyds.get_nvds_LayerInfo(tensor_meta, 0)
# Convert the tensor output meta to a numpy array containing the fingerprint
ptr = ctypes.cast(pyds.get_ptr(layer.buffer), ctypes.POINTER(ctypes.c_float))
probs = np.array(np.ctypeslib.as_array(ptr, shape=(layer.dims.numElements,)), copy=True)
print(probs)
obj_counter[obj_meta.class_id] += 1
print(num_rects)
return Gst.PadProbeReturn.OK
Thanks in advance for your help.
**• Hardware Platform Jetson TX2 *
• DeepStream Version 5.0
• JetPack Version 4.4
