Facenet with DeepStream Python Not Able to Parse Output Tensor Meta
I have integrate Facenet model with Peoplenet TLT model using deepstream-test2 Python sample app.
I used Peoplenet as primary detector and Facenet as secondary inference and removed the other two classifiers.
The app is running fine with no errors. But I wouldn’t able to parse the output tensor for Facenet. All the time l_user = obj_meta.obj_user_meta_list is None. I have enabled output tensor meta in the config file output-tensor-meta=1.
The prob I have added it on nvvidconv sink pad.
I didn’t change anything of the tracking config
This is the configuration file I’m using for Facenet.
[property]
gpu-id=0
net-scale-factor=0.0093215686274
model-engine-file=facenet_order.plan
#input-dims=3;160;160;0
#uff-input-blob-name=input_1
#force-implicit-batch-dim=1
batch-size=1
# 0=FP32 and 1=INT8 mode
network-mode=2
input-object-min-width=160
input-object-min-height=160
model-color-format=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=2
is-classifier=1
output-blob-names=Bottleneck_BatchNorm/batchnorm_1/add_1:0
classifier-async-mode=1
#classifier-threshold=0.51
process-mode=2
## 0=Detector, 1=Classifier, 2=Segmentation, 100=Other
network-type=1
# Enable tensor metadata output
#scaling-filter=0
#scaling-compute-hw=0
Porb method used on nvvidconv sink pad:
def sgie_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    #Intiallizing object counter with 0.
    obj_counter = {
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_FACE:0,
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        l_user = frame_meta.frame_user_meta_list
        print('frame_meta.frame_user_meta_list is: ', l_user)
        l_obj=frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            print(f'obj_meta.obj_user_meta_list {l_user}')
            try:
                l_obj=l_obj.next
                break
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
I have tried to set process-mode=1 to act as primary and classify whole frame. just to make sure Facenet is working. It worked and I was able to read the tensor output from l_user = frame_meta.frame_user_meta_list and get the output layer Bottleneck_BatchNorm/batchnorm_1/add_1:0. But not able to get it on secondary mode.
Jetson NX
• DeepStream Version
5.0
4.4.1
• TensorRT Version
7.1.3
Since “output-tensor-meta=1” means nvinfer will not use the default post-processing inside nvinfer, so no object will be insert into the meta. It will export the model input and output layers and need you to add the customized post-processing by yourself to generate correct object meta for the output.
deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub is the proper example of how to use “output-tensor-meta=1”.
For more information, you can refer to the C/C++ samples deepstream-infer-tensor-meta-test.
The related document: Python Sample Apps and Bindings Source Details — DeepStream 6.1.1 Release documentation
Gst-nvinfer — DeepStream 6.1.1 Release documentation
Thanks @Fiona.Chen for your replay.
This is exactly what I am trying to accomplish. I have followed both python deepstream-ssd-parser sample and the C++ sample deepstream-infer-tensor-meta-test. They helped me a lot. But, for some reason l_user = obj_meta.obj_user_meta_list is always None
From the docs:
When operating as secondary GIE, NvDsInferTensorMeta is attached to each each NvDsObjectMeta object’s obj_user_meta_list.
So I am trying to access the the obj_meta.obj_user_meta_list to get access to NvDsInferTensorMeta But obj_meta.obj_user_meta_list is always None.
Since I used “output-tensor-meta=1” and make it secondary with “process-mode=2” in classifier config file, then, obj_meta.obj_user_meta_list should be not None and contains user meta list that I will iterate over to search SGIE’s tensor data, is this right?
I have tried several times to change the config file parameters and change the position of the prob function without any success.
Image below show printing obj_meta.obj_user_meta_list value.
Can the c/c++ sample deepstream-infer-tensor-meta-test work in your platform?
We can not get the reason of the failure by your description. You need to provide the codes, configuration files and samples to make us to reproduce your problem.
Yes, it is working fine.
Ok sure, since all things I’m working on is open source, I will provide all the code.
I think I will provide a Github repository with code and steps, is Github better or you prefer uploading all the files here?
Github is OK
@Fiona.Chen I uploaded the code to this Github repo. GitHub - riotu-lab/deepstream-facenet: Demo app on using Deepstream 5.0 with Facenet . The Readme file contains the steps to reproduce the same error.
Thanks in advance.
There is no problem with your codes. I can get obj_user_meta with your codes.
For test purpose, please remove tracker from the pipeline.
I tested with /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264 and changed the SGIE to our prebuilt model.
My changed code. deepstream_test_2.py.txt (15.5 KB) default_sgie_config.txt (3.5 KB)
This is from my log which removed the tracker.
Frame Number=98 Number of Objects=41 Person_count=37 Face_count=0
obj_meta.obj_user_meta_list None
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192bf80>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f308>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f500>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f260>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f298>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f928>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f0a0>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f8b8>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f2d0>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192fa08>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f6c0>
obj_meta.obj_user_meta_list <pyds.GList object at 0x7fa37192f7a0>
Thanks a lot.
I have tried your config file and made the changes on deepstream_test_2.py, removed tracker. It worked on the Nvidia pre built model But, not on Facenet model.
I did some experiments today and noticed that when changing these properties in SGIE
input-object-min-width=0
input-object-min-height=0
The terminal hangs without working
When I set it to both 40, It run some frames and got some lists. Then it hangs without working.
input-object-min-width=40
input-object-min-height=40
Since I got some lists. this means that when both was 160, the engine was receiving images with less than 160*160 so, it ignore them.
seems it height and width problem. how to make cropped objects from PGIE get mapped to the needed SGIE infer-dims size?
What is your platform to run deepstream? Jetson or dGPU?
It is Jetson NX
Jetson has limitation of scaling. It can just scale 1/16 to 16 in one dimension. Does your SGIE accept 160x160 RGB data? If so the input object minimum width and height should be 10 and 10.
OK, I solve it
What I did is this:
instead of giving the .plan file in model-engine-file, I used onnx-file and give it an onnx file with dynamic batch size.
I set batch-size=16 and removed input-object-min-width and input-object-min-height.
Now it accepts all image sizes, I got all obj_meta.obj_user_meta_list and runs fast on Jetson NX.
Thanks for your help.
@Fiona.Chen I was able to do the custom processing needed on the tensor metadata successfully and now I need to attach the label to the metadata. But, It gave me error.
I was trying to convert code from the c++ sample deepstream-infer-tensor-meta-test example to Python
Code to save label to metadata
                # Generate classifer metadata and attach to obj_meta
                # Get NvDsClassifierMeta object
                classifier_meta = pyds.nvds_acquire_classifier_meta_from_pool(batch_meta)
                # Populate classifier_meta data with prediction result
                classifier_meta.unique_component_id = tensor_meta.unique_id
                # Get NvDsLabelInfo object
                label_info = pyds.nvds_acquire_label_info_meta_from_pool(batch_meta)
                #result is string
                label_info.result_label = result                # ERROR
                label_info.result_prob = 0
                label_info.result_class_id = 0
                pyds.nvds_add_label_info_meta_to_classifier(classifier_meta, label_info)
                pyds.nvds_add_classifier_meta_to_object(obj_meta, classifier_meta)
                print(obj_meta.text_params.display_text)
                display_text = obj_meta.text_params.display_text
                obj_meta.text_params.display_text = f'{display_text} {result}'
Error:
  File "deepstream_test_1.py", line 231, in sgie_sink_pad_buffer_probe
TypeError: (): incompatible function arguments. The following argument types are supported:
    1. (arg0: pyds.NvDsLabelInfo) -> None
Invoked with: <pyds.NvDsLabelInfo object at 0x7f54b0c650>, 'Anas'
Seems python binding of result_label in pyds.NvDsLabelInfo is a numpy array (int type) but not a string array.
seems result_label not able to be modified or replaced. I tried to use label_info.pResult_label it accept a string but when trying to print it giving me this error
  File "deepstream_test_1.py", line 233, in sgie_sink_pad_buffer_probe
    print(label_info.pResult_label)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf7 in position 1: invalid start byte
pResult_label is a pointer of char.
‘utf-8’ is not char type
So how I can store the predicted name in the label_info.result_label or label_info.pResult_label, Or if there any other valid way in python to store predicted name in the metadata.
I don’t have experience with C nor C++, your help is very much appreciated.
The current bindings for result_label are binded as numpy array, but you can bind them as string array by creating your own bindings by following the github page GitHub - mrtj/pyds_tracker_meta: pybind11 wrapper to access Nvidia DeepStream tracker meta info from Python., please replace pyds_tracker_meta with the following code in pyds_labelinfo.cpp and also make sure you do similarly in setup.py before making the build
#include <pybind11/pybind11.h>
#include <pybind11/stl.h>
#include "nvdsmeta.h"
#include <iostream>
#include "nvll_osd_struct.h"
using namespace std;
namespace py = pybind11;
PYBIND11_MODULE(pyds_labelinfo, m) {
    m.doc() = "pybind11 wrapper to access Nvidia DeepStream NvDsLabelInfo* classes";
#define STRING_CHAR_ARRAY(TYPE, FIELD)                             \
        [](const TYPE &self)->string {                             \
            return string(self.FIELD);                             \
        [](TYPE &self, std::string str) {                          \
            int strSize = str.size();                              \
            str.copy(self.FIELD, strSize);                         \
        py::return_value_policy::reference
	py::class_<NvDsLabelInfo>(m,"NvDsLabelInfo",py::module_local())
                .def(py::init<>())
                .def_readwrite("base_meta", &NvDsLabelInfo::base_meta)
                .def_readwrite("num_classes", &NvDsLabelInfo::num_classes)
                .def_property("result_label",STRING_CHAR_ARRAY(NvDsLabelInfo,result_label))
                .def("cast",[](void *data) {
                        return (NvDsLabelInfo*)data;},
                        py::return_value_policy::reference,pydsdoc::nvmeta::LabelInfoDoc::cast)
                .def_readwrite("pResult_label", &NvDsLabelInfo::pResult_label)
                .def_readwrite("result_class_id", &NvDsLabelInfo::result_class_id)
                .def_readwrite("label_id", &NvDsLabelInfo::label_id)
                .def_readwrite("result_prob", &NvDsLabelInfo::result_prob);
Once after making the build, using the pyds_labelinfo.so and the following code, you can set result_label as follows
label_info=pyds_labelinfo.cast(label_info)
I followed the same procedure and got the following error @Fiona.Chen
0:02:03.504320890 18720     0x29ded6d0 ERROR                nvinfer
gstnvinfer.cpp:613:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID
2]: Error in NvDsInferContextImpl::parseBoundingBox()
<nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 2]: Could not find output coverage layer
for parsing objects
please do update on your github repo that it’s not updated hence not working.
