Getting metadata of NvdsAnalyticsMeta plugin in python
• Hardware Platform (Jetson / GPU) - dGPU (RTX2070)
• DeepStream Version - 5.0
• TensorRT Version - 7.0.0
• NVIDIA GPU Driver Version (valid for GPU only) - 440
Hi
I am trying to get new analytics plugin working in python and based on CPP example have been able to create a app, and on running i can see the analytics happening on screen, but have been unable to get the meta data of plugin, i am sharing the probe function which i have taken reference to port to python along with my python function.
/* nvdsanalytics_src_pad_buffer_probe  will extract metadata received on tiler sink pad
 * and extract nvanalytics metadata etc. */
static GstPadProbeReturn
nvdsanalytics_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        std::stringstream out_string;
        vehicle_count = 0;
        num_rects = 0;
        person_count = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
            // Access attached user meta for each object
            for (NvDsMetaList *l_user_meta = obj_meta->obj_user_meta_list; l_user_meta != NULL;
                    l_user_meta = l_user_meta->next) {
                NvDsUserMeta *user_meta = (NvDsUserMeta *) (l_user_meta->data);
                if(user_meta->base_meta.meta_type == NVDS_USER_OBJ_META_NVDSANALYTICS)
                    NvDsAnalyticsObjInfo * user_meta_data = (NvDsAnalyticsObjInfo *)user_meta->user_meta_data;
                    if (user_meta_data->dirStatus.length()){
                        g_print ("object %lu moving in %s\n", obj_meta->object_id, user_meta_data->dirStatus.c_str());
        /* Iterate user metadata in frames to search analytics metadata */
        for (NvDsMetaList * l_user = frame_meta->frame_user_meta_list;
                l_user != NULL; l_user = l_user->next) {
            NvDsUserMeta *user_meta = (NvDsUserMeta *) l_user->data;
            if (user_meta->base_meta.meta_type != NVDS_USER_FRAME_META_NVDSANALYTICS)
                continue;
            /* convert to  metadata */
            NvDsAnalyticsFrameMeta *meta =
                (NvDsAnalyticsFrameMeta *) user_meta->user_meta_data;
            /* Get the labels from nvdsanalytics config file */
            for (std::pair<std::string, uint32_t> status : meta->objInROIcnt){
                out_string << "Objs in ROI ";
                out_string << status.first;
                out_string << " = ";
                out_string << status.second;
            for (std::pair<std::string, uint32_t> status : meta->objLCCumCnt){
                out_string << " LineCrossing Cumulative ";
            for (std::pair<std::string, uint32_t> status : meta->objLCCurrCnt){
                out_string << " LineCrossing Current Frame ";
            for (std::pair<std::string, bool> status : meta->ocStatus){
                out_string << " Overcrowding status ";
        g_print ("Frame Number = %d of Stream = %d, Number of objects = %d "
                "Vehicle Count = %d Person Count = %d %s\n",
            frame_meta->frame_num, frame_meta->pad_index,
            num_rects, vehicle_count, person_count, out_string.str().c_str());
    return GST_PAD_PROBE_OK;
python code
# nvdsanalytics_src_pad_buffer_probe
# tiler_sink_pad_buffer_probe  will extract metadata received on tiler src pad
# and update params for drawing rectangle, object information etc.
def nvdsanalytics_src_pad_buffer_probe(pad,info,u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            break
        l_user = frame_meta.frame_user_meta_list
        while l_user is not None:
            try:
                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                if user_meta.base_meta.meta_type != pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
                    continue
                meta = pyds.NvDsAnalyticsFrameMeta()
                print(meta.objInROIcnt)
                break
            try:
                l_user=l_user.next
            except sStopIteration:
                break
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
I am not able to understand how to implement this as no casting function is available for NvDsAnalyticsFrameMeta and stuck on this line
NvDsAnalyticsFrameMeta *meta =(NvDsAnalyticsFrameMeta *) user_meta->user_meta_data;
Or am i doing something wrong here ?
We are checking internally
pls refer Deepstream 5.0 python bindings for Gst-nvdsanalytics access meta data
