• GTX 1070
• DeepStream 5.1
• TensorRT 7.2.3
• Nvidia Driver 465
I used the code here: (GitHub - preronamajumder/deepstream-lpr-python-version: Python version for NVIDIA Deepstream's LPR. https://developer.nvidia.com/blog/creating-a-real-time-license-plate-detection-and-recognition-app/), which is the python version of (GitHub - NVIDIA-AI-IOT/deepstream_lpr_app: Sample app code for LPR deployment on DeepStream), to do some experiments.
I changed the second gie’s mode to my own model and then added the code:
sgie_src_pad=sgie1.get_static_pad("src")
if not sgie_src_pad:
sys.stderr.write(" Unable to get sgie 1 pad \n")
else:
sgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, sgie_src_pad_buffer_probe, 0, args)
I tried to darw the shape of the cars on the output parser function sgie_src_pad_buffer_probe.
However, the code below doesn’t work because user_mete is None:
frame_number=0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
lp_dict = {}
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
#for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
# l_frame = l_frame->next)
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
print("Frame Number is ", frame_meta.frame_num)
print("Source id is ", frame_meta.source_id)
print("Batch id is ", frame_meta.batch_id)
print("Source Frame Width ", frame_meta.source_frame_width)
print("Source Frame Height ", frame_meta.source_frame_height)
print("Num object meta ", frame_meta.num_obj_meta)
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
user_meta_list = obj_meta.obj_user_meta_list
print(user_meta_list)
I also tried another way to get the user meta data but still got None:
l_user = frame_meta.frame_user_meta_list
print(l_user)
Why this happened? I only add my own call back function and change the sgie1’s model and config file. At least shouldn’t it give me some mete data so I can convert them to tensor even it is wrong data?
To be more clearly, the pgie detect the car, the second gie should get the input of the car with the bounding box, and output a matrix of the car’s shape. How should I get the output data which is a matrix of my secondary gie?
