**• Hardware Platform---------> GPU
**• DeepStream Version------->6.1.1 • JetPack Version (valid for Jetson only)
**• TensorRT Version------>8.4.0
**• NVIDIA GPU Driver Version ---->525. • Issue Type( questions, new requirements, bugs)
Hola !
I want to access tensormeta for pgie and as well as sgie. I’m using “PYTHON”
as a language. my pipeline as sample as of now I have pgie1------>sgie1------>sgie2 ----->
How I can access for both 3 model tensormeta
I know for pgie we can get ----> frame_user_meta_list
and for sgie we can get -------> obj_user_meta_list
while l_user_meta:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
# l_label = class_meta.label_info_list
print("user_meta",user_meta)
if(user_meta.base_meta.meta_type!= pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META):
continue
tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
# print("Unique id-------->tensor_--Meta: {}".format(tensor_meta.unique_id))
# Boxes in the tensor meta should be in network resolution which is
# found in tensor_meta.network_info. Use this info to scale boxes to
# the input frame resolution.
if tensor_meta.unique_id ==3:
print("AAAAAAAAAAAAAAAAAAAAAAAAAAGGGGGGGGGGGGGEEEEEEEEEEEE")
layers_info = []
for i in range(tensor_meta.num_output_layers):
layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
layers_info.append(layer)
print("layers name: {}".format(layer.layerName))
if tensor_meta.unique_id ==2:
print("GGGGGGGGGGGGEEEEEEEEEEEENNNNNDDDDDDDDDDEEEEEEEEEEEERRRRRRRRRRRR")
layers_info = []
I want to access sgie1 and sgie2 !
you are correct both are classification model but i want to access both meta data and sent it to somewhere else But in test two you don’t mention How we can access meta data … I try to give you more information …
how for both model I can access tensormeta this is my question for 1 I’m able to get it
nvinfer plugin will call nvds_add_classifier_meta_to_object to add classifcaiton meta to object meta, you need to get object meta first, then get classification meta, please refer to deepstream sample deepstream-preprocess-test’s pgie_src_pad_buffer_probe.
#Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_MASK:0,
PGIE_CLASS_ID_FACE:0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
# if not batch_meta:
# return Gst.PadProbeReturn.OK
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
continue
# print("Frame Number is ", frame_meta.frame_num)
# print("Source id is ", frame_meta.source_id)
# print("Batch id is ", frame_meta.batch_id)
# print("Source Frame Width ", frame_meta.source_frame_width)
# print("Source Frame Height ", frame_meta.source_frame_height)
# print("Num object meta ", frame_meta.num_obj_meta)
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
# print('obj_meta.class_id',obj_meta.class_id)
continue
l_user_meta = obj_meta.obj_user_meta_list
print("l_user_meta",l_user_meta)
while l_user_meta:
continue
while user_meta:
while tensor_meta:
layers_info = []
layers_info = []
try:
l_obj = l_obj.next
break
try:
l_frame = l_frame.next
break
#print("Frame Number =", frame_number, "Face Count =", obj_counter[PGIE_CLASS_ID_Face],)
THIS IS MY FUNCTION WHAT I MAKE TO ACCESS TENSOR META FOR SGIE1 AND SGIE2
only sgie1 layer is printing (it’s unique id is 3 )
sgie2 (it’s unique id is 2 )
It’s not printing for sgie2
Look through the code and tell me where am making mistake !
Okey ! what I know ,“classifier_meta_list” will work on with out tensor meta
But when we put sgie_config_file —> output-tensor-meta=1
for this we can access tensor
for that obj_meta to
IF YOU go through TENSOR META
The Gst-nvinfer plugin can attach raw output tensor data generated by a TensorRT inference engine as metadata. It is added as an NvDsInferTensorMeta in the frame_user_meta_list member of NvDsFrameMeta for primary (full frame) mode, or in the obj_user_meta_list member of NvDsObjectMeta for secondary (object) mode.
for that obj_meta.obj_user_meta_list
for each individual tensor
if output-tensor-meta is 1 you need to add classification meta yourself, please refer to \opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-infer-tensor-meta-test\deepstream_infer_tensor_meta_test.cpp
