Implement "osd_sink_pad_buffer_probe" from "deepstream-test1" to "deepstream-app"
I’m using deepstream-app for detects objects from RTSP IP camera, streaming output via RTSP Port and save the output in .mp4 file.
Fine!
But i must use “osd_sink_pad_buffer_probe” in deepstream-test1 for “extract metadata received on OSD sink pad and update params for drawing rectangle, object information etc…”
This is code:
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_number, num_rects, vehicle_count, person_count);
char strLog[1024];
snprintf(strLog, sizeof(strLog), "Frame Number = %d Number of objects = %d "
FILE *out = fopen("log.txt", "a");
  fprintf(out, "%s", strLog);
  fclose(out);
    frame_number++;
    return GST_PAD_PROBE_OK;
Is possibile implement this function in deepstream-app?
You may add the code in
deepstream_sdk_v4.0_jetson\sources\apps\apps-common\src\deepstream_osd_bin.c
and rebuild deepstream-app.
By the way, could you check this and share the information?
In “deepstream_osd_bin.c” I don’t find the function:
    gpointer u_data)
There is only:
gboolean create_osd_bin (NvDsOSDConfig * config, NvDsOSDBin * bin)
You need to refer to deepstream-test1 and adapt the code into deepstream-app.
