• DeepStream Version:5.1
• TensorRT Version:7.2
• NVIDIA GPU Driver Version (valid for GPU only):470
• Issue Type( questions, new requirements, bugs):bugs
From deepstream-5.1/sources/apps/sample_apps/deepstream-image-meta-test/deepstream_image_meta_test.c
static GstPadProbeReturn
pgie_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer ctx)
GstBuffer *buf = (GstBuffer *) info->data;
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
GST_ERROR ("input buffer mapinfo failed");
return GST_FLOW_ERROR; // <---- INCORRECT RETURN TYPE
NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
gst_buffer_unmap (buf, &inmap);
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
guint num_rects = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
/* Conditions that user needs to set to encode the detected objects of
* interest. Here, by default all the detected objects are encoded.
* For demonstration, we will encode the first object in the frame */
if ((obj_meta->class_id == PGIE_CLASS_ID_PERSON
&& num_rects == 1) {
NvDsObjEncUsrArgs userData = { 0 };
/* To be set by user */
userData.saveImg = save_img;
userData.attachUsrMeta = attach_user_meta;
/* Set if Image scaling Required */
userData.scaleImg = FALSE;
userData.scaledWidth = 0;
userData.scaledHeight = 0;
/* Preset */
userData.objNum = num_rects;
/*Main Function Call */
nvds_obj_enc_process (ctx, &userData, ip_surf, obj_meta, frame_meta);
nvds_obj_enc_finish (ctx);
return GST_PAD_PROBE_OK;
The returned value on error is GST_FLOW_ERROR
which is not among the valid return values of type GstPadProbeReturn
typedef enum
GST_PAD_PROBE_DROP,
GST_PAD_PROBE_OK,
GST_PAD_PROBE_REMOVE,
GST_PAD_PROBE_PASS,
GST_PAD_PROBE_HANDLED
} GstPadProbeReturn;
I think instead of GST_FLOW_ERROR
, the function should return GST_PAD_PROBE_OK
on error to skip this probe?
