Yeah, deepstream-image-meta-test runs well.
But similar image saving wanted to integrate with deepstream-app5, where followed below steps,
- Added required libraries along with the make
- Imported necessary files in deepstream-app ( Being deepstream-app5 a dependency for deepstream-app )
- Added Function gie_img_prob_new containing code similarly which is in deepstream-image-meta-test
Code:
In depstream-app/deepstream_app.c
//NEW FUNCTION ADDED
static GstPadProbeReturn
gie_img_prob_new (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
AppCtx *appCtx = (AppCtx *) u_data;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
if (!batch_meta) {
NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
return GST_PAD_PROBE_OK;
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
GST_ERROR ("input buffer mapinfo failed");
return GST_FLOW_ERROR;
NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
gst_buffer_unmap (buf, &inmap);
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
guint num_rects = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == 1) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == 0) {
person_count++;
num_rects++;
/* Conditions that user needs to set to encode the detected objects of
* interest. Here, by default all the detected objects are encoded.
* For demonstration, we will encode the first object in the frame */
if ((obj_meta->class_id == 0
|| obj_meta->class_id == 1) && num_rects == 1) {
NvDsObjEncUsrArgs userData = { 0 };
/* To be set by user */
userData.saveImg = save_img;
userData.attachUsrMeta = attach_user_meta;
/* Preset */
userData.objNum = num_rects;
/*Main Function Call */
nvds_obj_enc_process (u_data, &userData, ip_surf, obj_meta, frame_meta);
nvds_obj_enc_finish (u_data);
which is being called in create_common_elements function
static gboolean
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
GstElement * sink_elem, GstElement * src_elem,
bbox_generated_callback bbox_generated_post_analytics_cb)
gboolean ret = FALSE;
*sink_elem = *src_elem = NULL;
/*Creat Context for Object Encoding */
NvDsObjEncCtxHandle obj_ctx_handle = nvds_obj_enc_create_context ();
if (config->primary_gie_config.enable) {
if (config->num_secondary_gie_sub_bins > 0) {
if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
config->primary_gie_config.unique_id,
config->secondary_gie_sub_bin_config,
&pipeline->common_elements.secondary_gie_bin)) {
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline),
pipeline->common_elements.secondary_gie_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.secondary_gie_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
if (config->tracker_config.enable) {
if (!create_tracking_bin (&config->tracker_config,
&pipeline->common_elements.tracker_bin)) {
g_print ("creating tracker bin failed\n");
goto done;
pipeline->common_elements.tracker_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.tracker_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.tracker_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.tracker_bin.bin;
if (!create_primary_gie_bin (&config->primary_gie_config,
&pipeline->common_elements.primary_gie_bin)) {
goto done;
pipeline->common_elements.primary_gie_bin.bin);
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.primary_gie_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.primary_gie_bin.bin;
if (!*src_elem) {
*src_elem = pipeline->common_elements.primary_gie_bin.bin;
NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.
primary_bbox_buffer_probe_id,
pipeline->common_elements.primary_gie_bin.bin, "src",
gie_primary_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
pipeline->common_elements.appCtx);
if (!obj_ctx_handle) {
g_print ("Unable to create context\n");
return -1;
gie_img_prob_new, GST_PAD_PROBE_TYPE_BUFFER,
if(*src_elem) {
*src_elem, "src",
analytics_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
&pipeline->common_elements);
/* Add common message converter */
if (config->msg_conv_config.enable) {
NvDsSinkMsgConvBrokerConfig *convConfig = &config->msg_conv_config;
pipeline->common_elements.msg_conv = gst_element_factory_make (NVDS_ELEM_MSG_CONV, "common_msg_conv");
if (!pipeline->common_elements.msg_conv) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'common_msg_conv'");
goto done;
g_object_set (G_OBJECT (pipeline->common_elements.msg_conv),
"config", convConfig->config_file_path,
"msg2p-lib", (convConfig->conv_msg2p_lib ? convConfig->conv_msg2p_lib : "null"),
"payload-type", convConfig->conv_payload_type,
"comp-id", convConfig->conv_comp_id, NULL);
pipeline->common_elements.msg_conv);
NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.msg_conv);
*src_elem = pipeline->common_elements.msg_conv;
pipeline->common_elements.tee = gst_element_factory_make (NVDS_ELEM_TEE, "common_analytics_tee");
if (!pipeline->common_elements.tee) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'common_analytics_tee'");
goto done;
pipeline->common_elements.tee);
NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.tee);
*src_elem = pipeline->common_elements.tee;
/* Destroy context for Object Encoding */
nvds_obj_enc_destroy_context (obj_ctx_handle);
ret = TRUE;
done:
return ret;
Kindly help provide suggestions on implementing image saving in deepstream-app5.
Thank You,
