On the Jetson Nano, Deepstream-5.0 is not saving the images. I have tried the deepstream-image-meta-test app , But the mage is not going to save only the green image is getting on each object detection. I want to implement the image saving on deepstream-app c++ code.
can anyone help me on this?
Hardware Platform (Jetson / GPU): DeepStream Version: JetPack Version (valid for Jetson only): TensorRT Version: NVIDIA GPU Driver Version (valid for GPU only): Issue Type( questions, new requirements, bugs): How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Can you report the problem with the following template? Especially the steps to reproduce the problem.
The deepstream-image-meta-test sample has been tested before being released. For us, the sample app can work. So we need you provide the details to reproduce the problem. Please fill the information to the template.
Hardware Platform (Jetson / GPU):Jetson Nano DeepStream Version: deepstream-5.0 (5.0.1-1) JetPack Version (valid for Jetson only): jetpack 4.4 TensorRT Version:7.1.3-1+cuda10.2 NVIDIA GPU Driver Version (valid for GPU only):nvidia-l4t-tools (32.4.3-20200924161615 Issue Type( questions, new requirements, bugs): deepstream-image-meta-test app , But the mage is not going to save only the green image is getting on each object detection How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) deepstream-image-meta-test rtsp://xxx.xxx.x.x/xx Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)deepstream-image-meta-test
Hey guys, also have the exact same issue with image saving from an RSTP stream with the following specs:
Codec: H264 - MPEG-4 AVC (part 10) (h264)
Color primaries: ITU-R BT.709
Color space: ITU-R BT.709 Range
No issues from the included sample stream files:
sample_1080p_h264.mp4
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
