Green Images are saved in deepstream-5.0 indeepstream-image-meta-test
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version v5.1.0
• JetPack Version (valid for Jetson only) Jetpack 4.4
• TensorRT Version 7.1.3-1+cuda-10.2
• NVIDIA GPU Driver Version (valid for GPU only) nvidia-l4t-tools (32.4.3-20200924161615)
• Issue Type( questions, new requirements, bugs) bug
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) deepstream-image-meta-test rtsp://xxx.xxx.x.x/xx
We will try to reproduce the problem.
The problem can be reproduced. We will response if there is any progress.
did you able to reproduce the problem
Yes. We can reproduce. We have created internal bug to track it. And the solution is under development.
How to slove this problem ? I meet the same problem.
Hello everyone, did you manage to solve the problem?
The case can work with JetPack4.5.1 and DS5.1 now.
Unfortunately, the problem is still there. I only change the video file in ds transfer learning app on Jetson Xavier nx, same specs 1080p mp4 (H264), but I still get green images. there is no problem with dGPU.
not yet
