How to save object to jpg file in Deepstream-test5-app
Hi everyone, in deepstream-test5-app i want to save object and put this path to payload for generate
thank
and this is old my post How to custom Json message sent to kafka server
• DeepStream Version
• TensorRT Version
• Hardware Platform Jetson
• DeepStream Version 5.0
• JetPack Version 4.4.1
• TensorRT 7.1.3
• Issue Type: new requirements
• Requirement details: How to save object to image in deepstream-test5-app
sorry, i am lost. i has update information
Please refer to the sample codes deepstream-image-meta-test. The image is generated in pgie_src_pad_buffer_probe() and saved as image file in osd_sink_pad_buffer_probe().
i had refer to deepstream-image-meta-test but no image saved, this is my gstnvmsgconv.c (23.2 KB) save image code from line 478 to 512
This is a plugin, you just implemented reading image data from the user meta part. Where did you generate mage and put the image data into user meta?
i has read funcion pgie_src_pad_buffer_probe() but i don’t now how to appy it to
gst_nvmsgconv_transform_ip(), can you help me
You can implement your own specific app, to generate image user meta in pgie_src_pad_buffer_probe() with nvinfer plugin and use your customized nvmsgconv plugin to handle the image user meta.
please suggest to me how to work with pgie_src_pad_buffer_probe() in nvinfer plugin
The better way is to use pgie_src_pad_buffer_probe() in application with nvinfer src pad.
deepstream-image-meta-test is already the sample.
so difficult with pgie_src_pad_buffer_probe() in deepstream-test5-app-main.c and gstnvmsgconv.c, So different way i can get image at gstdsexample.cpp, are you think sgtnvmsgconv.c can get image like gstdsexample
can you give me an example code for save image in deepstream-test5-app flow your way, thanks so much
@Fiona.Chen @DaneLLL, please help me
You may refer to Encoding jpeg image after OSD causes segfault
deepstream-test5 is a dynamic pipeline app, it is very hard to insert image saving into deepstream-test5 because there is limitation with nvds_obj_enc_create_context() interface.
if get image at OSD i think so difficult to get image path for custom payload to json message broker
It is a sample. You need to find the correct place to put pgie_src_pad_buffer_probe() according to your actual pipeline.
how about Gstdsexample can apply to Gstnvmsgconv for save image. In Gstdsexample i had save image work well.
Can i use Gstdsexample in Gstnvmsgconv like a lib ?
The dsexample can be a sample for you to modify gstnvmsgconv
