Hi!
I successfully ran the program of example in deepstream_python_apps.I found that each sample program is an input video stream. So, can you give me a sample code for inputting pictures?
• DeepStream Version
• TensorRT Version
This just need to change the src with other src pluging, e.g. filesrc , multifilesrc , it’s common GStreamer issue, please feel free to change it by yourself.
Hi!
Sorry, I’ve just touched these configurations. So, can you modify the pipeline of example Test1 and give the specific code? Thank you very much.
Hi!
This is my own pipeline. The main function is to input a picture for analysis, but it always reports errors. How can I modify it? thank!
GObject.threads_init()
Gst.init(None)
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating Source \n ")
source = Gst.ElementFactory.make("filesrc", "file-source")
if not source:
sys.stderr.write(" Unable to create Source \n")
source.set_property('location', "./1.jpg")
pipeline.add(source)
decoder = Gst.ElementFactory.make("jpegdec", "vorbis-decoder")
if not decoder:
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
pgie.set_property('config-file-path', "config_infer_primary_peoplenet.txt")
pipeline.add(pgie)
print("Creating filter1 \n ")
caps1 = Gst.Caps.from_string("image/jpeg,,framerate=(fraction)30/1")
filter = Gst.ElementFactory.make("capsfilter", "filter")
if not filter:
sys.stderr.write(" Unable to get the caps filter \n")
filter.set_property("caps", caps1)
pipeline.add(filter)
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
pipeline.add(nvvidconv)
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
pipeline.add(nvosd)
sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
sink.set_property('enable-last-sample', False)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
source.link(decoder)
decoder.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
Hi @837331759 ,
Sorry for delay!
please refer to - deepstream_python_apps/apps/deepstream-test1 at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub , this is a sample GST command:
gst-launch-1.0 filesrc location=test.jpg ! jpegparse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=config_infer_primary.txt ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! jpegenc ! jpegparse ! filesink location=out.jpg
