How to deepcopy NvDsFrameMeta to another thread?deepstream-transfer-learning-app is too slowly!
RTX 2060
• DeepStream Version
ds 6.0
• TensorRT Version
tensorrt 8
470.141.03
question
RUN deepstream-transfer-learning-app with set source=30
I want to save the images from the inference video to my disk. I used the example from deepstream-transfer-learning-app’ code . Its core code is as follows:
static void
after_pgie_image_meta_save(AppCtx *appCtx, GstBuffer *buf,
                           NvDsBatchMeta *batch_meta, guint index)
    GstMapInfo inmap = GST_MAP_INFO_INIT;
    if (!gst_buffer_map(buf, &inmap, GST_MAP_READ))
        std::cerr << "input buffer mapinfo failed\n";
        return;
    NvBufSurface *ip_surf = (NvBufSurface *)inmap.data;
    gst_buffer_unmap(buf, &inmap);
    bool isWrite = false;
    NvDsObjectMeta *obj_meta = NULL;
    NvDsMetaList *l_frame = NULL;
    NvDsMetaList *l_obj = NULL;
    if (!isInitEncContext)
        obj_ctx_handle_ = nvds_obj_enc_create_context();
        isInitEncContext = true;
    auto start_t = std::chrono::high_resolution_clock::now();
    /// Creating a special object meta in order to save a full frame
    if (picCount % 150 == 0)
        for (NvDsMetaList *l_frame = batch_meta->frame_meta_list; l_frame != nullptr;
             l_frame = l_frame->next)
            NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
            guint num_rects = 0;
            bool at_least_one_confidence_is_within_range = false;
            if (at_least_one_confidence_is_within_range)
                unsigned dummy_counter = 0;
                isWrite = true;
                NvDsObjEncUsrArgs userData = {0};
                /* To be set by user */
                userData.saveImg = TRUE;
                userData.attachUsrMeta = FALSE;
                /* Set if Image scaling Required */
                userData.scaleImg = FALSE;
                userData.scaledWidth = 0;
                userData.scaledHeight = 0;
                std::stringstream ss;
                ss << "camera" << frame_meta->pad_index << "_" << (picCount / 150) << ".jpg";
                std::string path = ss.str();
                if (path.size() >= sizeof(userData.fileNameImg))
                    std::cerr << "Folder path too long (path: " << path
                              << ", size: " << path.size() << ") could not save image.\n"
                              << "Should be less than " << sizeof(userData.fileNameImg) << " characters.";
                    return;
                path.copy(userData.fileNameImg, path.size());
                userData.fileNameImg[path.size()] = '\0';
                userData.objNum = picCount;
                userData.quality = 80;
                NvDsObjectMeta dummy_obj_meta;
                dummy_obj_meta.rect_params.width = ip_surf->surfaceList[frame_meta->batch_id].width;
                dummy_obj_meta.rect_params.height = ip_surf->surfaceList[frame_meta->batch_id].height;
                dummy_obj_meta.rect_params.top = 0;
                dummy_obj_meta.rect_params.left = 0;
                nvds_obj_enc_process(obj_ctx_handle_, &userData, ip_surf, &dummy_obj_meta, frame_meta);
                std::cout << "camera :" << frame_meta->pad_index << " writed,frame :" << picCount << std::endl;
        if (isWrite)
            auto over_t = std::chrono::high_resolution_clock::now();
            std::chrono::duration<double, std::milli> elapsed = over_t - start_t;
            std::cout << "total time:" << elapsed.count() << "ms!" << std::endl;
            nvds_obj_enc_finish(obj_ctx_handle_);
    } // end of picCount %150
    picCount++;
The example of deepstream-transfer-learning-app has some problems, nvds_obj_enc_process is used in after_pgie_image_meta_save, if there are many images, it will still block the pipline. For example, 30 images might take 3 seconds.
So, I want to make a copy of NvDsFrameMeta and send it to the consumer thread. The question is: how should I deep copy the copied data structure of NvDsFrameMeta (do I also copy the data in the gpu?), can you give me some sample code? Thanks!
Do you mean you want to do “nvds_obj_enc_process” in another thread? It is better to copy the whole GstBuffer to new created GstBuffer
yes!I want to use “nvds_obj_enc_process” in another thread。but how to copy the whole GstBuffer to new created GstBuffer?could u give me some code for sample?
I User deepcopy for GstBuffer,But I got this error when gst_buffer_unref.
[NvTiler::Composite] ERROR: 360; NvBufSurfTransformComposite failed(-1)
ERROR from tiled_display_tiler: GstNvTiler: FATAL ERROR; NvTiler::Composite failed
Debug info: gstnvtiler.cpp(666): gst_nvmultistreamtiler_transform (): /GstPipeline:pipeline/GstBin:tiled_display_bin/GstNvMultiStreamTiler:tiled_display_tiler
And ,my code like this:
static void
    if (g_img_meta_consumer.get_is_stopped())
        std::cerr << "Could not save image and metadata: "
                  << "Consumer is stopped.\n";
        return;
    GstBuffer *new_buf = gst_buffer_copy_deep(buf);
    if (!gst_buffer_map(new_buf, &inmap, GST_MAP_READ))
            return;
    gst_buffer_unmap(new_buf, &inmap);
    gst_buffer_unref(new_buf);
hope u give me some help!
This is not copy. Please create NvBufSurface as the sample in nvdsexample /opt/nvidia/deepstream/deepdtream/sources/gst-plugins/gst-dsexample
