I try to fix several code from ajayskabadi2012 code and I have an error too.
Here is my code
static GstPadProbeReturn
gie_img_prob_new (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
GstMapInfo inmap = GST_MAP_INFO_INIT;
NvDsObjEncCtxHandle ctx = (NvDsObjEncCtxHandle) u_data;
NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
gst_buffer_unmap (buf, &inmap);
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
GST_ERROR ("input buffer mapinfo failed");
return GST_PAD_PROBE_OK;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* Conditions that user needs to set to encode the detected objects of
* interest. Here, by default all the detected objects are encoded.
* For demonstration, we will encode the first object in the frame */
if (obj_meta->class_id == 0 || obj_meta->class_id == 2 || obj_meta->class_id == 3 || obj_meta->class_id == 5 || obj_meta->class_id == 7) {
printf("%d\n", obj_meta->class_id);
NvDsObjEncUsrArgs userData = { 0 };
/* To be set by user */
userData.saveImg = FALSE;
userData.attachUsrMeta = TRUE;
/* Preset */
userData.objNum = 1;
/*Main Function Call */
**nvds_obj_enc_process (ctx, &userData, ip_surf, obj_meta, frame_meta);**
nvds_obj_enc_finish (ctx);
and here is code inside create_common_elements function.
NvDsObjEncCtxHandle obj_ctx_handle = nvds_obj_enc_create_context();
if (!obj_ctx_handle) {
g_print ("Unable to create context\n");
return -1;
NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.primary_bbox_buffer_probe_id,
pipeline->common_elements.primary_gie_bin.bin, "src",
gie_img_prob_new, GST_PAD_PROBE_TYPE_BUFFER,
obj_ctx_handle);
Other code works very well but when it refer to ‘ctx’, it cause segmentation fault.
