I’m trying to build a measure tool (does omniverse already has it? I can’t find it) that displays a line between two points. I can already get those two points, and render labels inside viewport by creating ui.Window(name = “Viewport”). I would like to know how do I create a line between two 3D points and display a value on top of this line.
In case you want to build anything else, you can use the omni.ui.scene
API to build lines and other shapes.
You can find the documentation here: omni.ui.scene module — kit-sdk 103.1 documentation
We have examples here: GitHub - NVIDIA-Omniverse/kit-extension-sample-ui-scene: Sample Repository to create Kit Extension using the ui.scene API
