I am using deepstream version 5.0.
I am trying to draw rectangles on the frame using NvDsDisplayMeta and I can see these rectangles on eglsink display but when I am trying to encode this frame and write to the disk then those images don’t contain these drawn rectangles.
Below is the code
* Called when element recieves an input buffer from upstream element.
static GstFlowReturn gst_processor_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
GstProcessor *processor = GST_PROCESSOR (btrans);
GstMapInfo in_map_info;
GstFlowReturn flow_ret = GST_FLOW_ERROR;
gdouble scale_ratio = 1.0;
NvBufSurface *surface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_frame = NULL;
guint i = 0;
processor->frame_num++;
CHECK_CUDA_STATUS (cudaSetDevice (processor->gpu_id),
"Unable to set cuda device");
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
surface = (NvBufSurface *) in_map_info.data;
if (CHECK_NVDS_MEMORY_AND_GPUID (processor, surface))
goto error;
batch_meta = gst_buffer_get_nvds_batch_meta (inbuf);
if (batch_meta == nullptr) {
GST_ELEMENT_ERROR (processor, STREAM, FAILED,
("NvDsBatchMeta not found for input buffer."), (NULL));
return GST_FLOW_ERROR;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *) (l_frame->data);
// process frame_meta for detections
//remove all previous objects
nvds_clear_obj_meta_list(frame_meta, frame_meta->obj_meta_list);
NvDsBatchMeta *frame_batch_meta = frame_meta->base_meta.batch_meta;
NvDsDisplayMeta * display_meta = nvds_acquire_display_meta_from_pool(frame_batch_meta);
NvDsObjectMeta *object_meta = nvds_acquire_obj_meta_from_pool(frame_batch_meta);
NvOSD_RectParams * rect_params = NULL;
**// Code to draw rectangles on the image.**
rect_params = &display_meta->rect_params[0];
rect_params->left = 100;
rect_params->top = 100;
rect_params->width = 300;
rect_params->height = 300;
rect_params->has_bg_color = 0;
rect_params->bg_color = (NvOSD_ColorParams) { 1, 1, 0, 0.4 };
rect_params->border_width = 10;
rect_params->border_color = (NvOSD_ColorParams) {1, 0.03921568627, 0.05882352941, 0.98};;
display_meta->num_rects = 1;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
auto enc_ctx_handle = nvds_obj_enc_create_context();
NvOSD_RectParams & encoding_params = object_meta->rect_params;
encoding_params.left = 5;
encoding_params.top = 5;
encoding_params.width = 500
encoding_params.height = 500;
encoding_params.has_bg_color = 0;
encoding_params.bg_color = (NvOSD_ColorParams) { 1, 1, 0, 0.4 };
encoding_params.border_width = 2;
encoding_params.border_color = (NvOSD_ColorParams) {1, 0.03921568627, 0.05882352941, 0.98};
**// Code to encode and write this frame to disk but rectangles aren't in the image.**
nvds_add_obj_meta_to_frame(frame_meta, object_meta, NULL);
NvDsObjEncUsrArgs userData = { 0 };
userData.saveImg = TRUE;
userData.attachUsrMeta = TRUE;
userData.objNum = 1;
std::string save_path = "user_data/EventImages/basic/basic_" + std::to_string(rand()) + ".jpg";
strcpy(userData.fileNameImg, save_path.c_str());
nvds_obj_enc_process(enc_ctx_handle, &userData, surface, object_meta, frame_meta);
nvds_obj_enc_finish(enc_ctx_handle);
i++;
flow_ret = GST_FLOW_OK;
error:
gst_buffer_unmap (inbuf, &in_map_info);
return flow_ret;
Any idea what I am doing wrong here?
