Hi! I want to enable a new vertex attrib array to pass the texture index to my shader but when I want to do it, the driver crash!
void RenderTarget::drawVertexBuffer(VertexBuffer& vertexBuffer, RenderStates states) {
if (vertexBuffer.getVertexCount() == 0) {
return;
if (activate(true))
if (!m_cache.glStatesSet)
resetGLStates();
// Apply the view
if (m_cache.viewChanged)
applyCurrentView();
if (states.blendMode != m_cache.lastBlendMode)
applyBlendMode(states.blendMode);
// Apply the texture
sf::Uint64 textureId = states.texture ? states.texture->getNativeHandle() : 0;
if (textureId != m_cache.lastTextureId)
applyTexture(states.texture);
// Apply the shader
if (states.shader)
applyShader(states.shader);
if (m_versionMajor > 3 || m_versionMajor == 3 && m_versionMinor >= 3)
glCheck(glBindVertexArray(m_vao));
if (m_cache.lastVboBuffer != &vertexBuffer) {
if (m_versionMajor > 3 || m_versionMajor == 3 && m_versionMinor >= 3) {
glCheck(glBindBuffer(GL_ARRAY_BUFFER, vertexBuffer.vboVertexBuffer));
glCheck(glEnableVertexAttribArray(0));
glCheck(glEnableVertexAttribArray(1));
glCheck(glEnableVertexAttribArray(2));
glCheck(glVertexAttribPointer(0, 3,GL_FLOAT,GL_FALSE,sizeof(Vertex), (GLvoid*) 0));
glCheck(glVertexAttribPointer(1, 4,GL_UNSIGNED_BYTE,GL_TRUE,sizeof(Vertex),(GLvoid*) 12));
glCheck(glVertexAttribPointer(2, 2, GL_FLOAT, GL_FALSE, sizeof(Vertex), (GLvoid*) 16));
glCheck(glEnableVertexAttribArray(3));
glCheck(glBindBuffer(GL_ARRAY_BUFFER, vertexBuffer.vboNormalBuffer));
glCheck(glVertexAttribPointer(3, 3, GL_FLOAT, GL_FALSE, sizeof(sf::Vector3f), (GLvoid*) 0));
glCheck(glEnableVertexAttribArray(4));
/*glCheck(glBindBuffer(GL_ARRAY_BUFFER, vertexBuffer.vboTextureIndexesBuffer));
glCheck(glVertexAttribPointer(4, 1, GL_UNSIGNED_INT,GL_FALSE,sizeof(unsigned int),(GLvoid*) 0));
glCheck(glDisableVertexAttribArray(0));
glCheck(glDisableVertexAttribArray(1));
glCheck(glDisableVertexAttribArray(2));
glCheck(glDisableVertexAttribArray(3));
glCheck(glDisableVertexAttribArray(4));*/
glCheck(glBindBuffer(GL_ARRAY_BUFFER, 0));
} else {
glCheck(glEnableClientState(GL_COLOR_ARRAY));
glCheck(glEnableClientState(GL_TEXTURE_COORD_ARRAY));
glCheck(glEnableClientState(GL_VERTEX_ARRAY));
glCheck(glVertexPointer(3, GL_FLOAT, sizeof(Vertex), (GLvoid*) 0 ));
glCheck(glColorPointer(4, GL_UNSIGNED_BYTE, sizeof(Vertex), (GLvoid*) 12));
glCheck(glTexCoordPointer(2, GL_FLOAT, sizeof(Vertex),(GLvoid*) 16));
glCheck(glEnableClientState(GL_NORMAL_ARRAY));
glCheck(glNormalPointer(GL_FLOAT, sizeof(sf::Vector3f), (GLvoid*) 0));
glCheck(glDisableClientState(GL_COLOR_ARRAY));
glCheck(glDisableClientState(GL_TEXTURE_COORD_ARRAY));
glCheck(glDisableClientState(GL_VERTEX_ARRAY));
glCheck(glDisableClientState(GL_NORMAL_ARRAY));
m_cache.lastVboBuffer = &vertexBuffer;
//glCheck(glEnableVertexAttribArray(4));
} else {
// Find the OpenGL primitive type
static const GLenum modes[] = {GL_POINTS, GL_LINES, GL_LINE_STRIP, GL_TRIANGLES,
GL_TRIANGLE_STRIP, GL_TRIANGLE_FAN, GL_QUADS};
GLenum mode = modes[vertexBuffer.getPrimitiveType()];
if (vertexBuffer.m_indexes.size() > 0) {
glCheck(glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, vertexBuffer.vboIndexBuffer));
glCheck(glDrawElements(mode, vertexBuffer.m_indexes.size(), GL_UNSIGNED_INT, (GLvoid*) 0));
glCheck(glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, 0));
} else {
//std::cout<<"draw arrays"<<std::endl;
glCheck(glBindFramebuffer(GL_FRAMEBUFFER, m_framebufferId));
glCheck(glDrawArrays(mode, 0, vertexBuffer.getVertexCount()));
//glCheck(glDisableVertexAttribArray(4));
glCheck(glBindVertexArray(0));
} else {
When I comment this line : glEnableVertexAttribArray(4) it works.
