ray.chi
September 28, 2020, 3:59am
1
I can using my code on TensorRT6 in INT8 and TensorRT 7 in FP32, but I getting the error like the following image when I use TensorRT 7 in INT 8.
This is the verbose output.
Environment
TensorRT Version : 7.1.3
GPU Type : Jetson AGX iGPU
Nvidia Driver Version :
CUDA Version : 10.2
CUDNN Version : 8
Operating System + Version : Ubuntu 18.04
Here is a similar issue and it turns out to be an environment issue:
We try to reproduce this issue but the onnx model works good in our environment.
Here are our steps for your reference:
1. test.py
import tensorflow as tf
import keras2onnx
import onnx
batch_size = 1
input_height = 224
input_width = 224
input_layer = tf.keras.layers.Input(batch_shape=[batch_size, 3, input_height, input_width], dtype=tf.float32)
min = 0.5
x1 = tf.keras.layers.Conv2D(16, 5, padding="same", data_format="channels_first")(input_layer)
x2 = tf.keras.layers.Conv2D(1, 3, pad…
Would you mind to check if the suggestion helps for your use case also?
If the issue goes on, please share the detail steps with us for reproducing.
ray.chi
September 28, 2020, 9:17am
4
Hi~!
we’ve tried the way but still failed to solve the problem on Xavier NX. How could we diagnose the issue? We will attach our steps later. Thanks.
Ray
Hi @AastaLLL
I’m Ray’s coworker. I’m trying another way to solve this problem but I get other errors now. You can follow this post.
ERROR: builtin_op_importers.cpp:2179 In function importPad inputs.at(1).is_weights()
Hi, both
Have you solved this issue with the new approach?
No, still have same problem.
Would you mind sharing the detailed steps so we can reproduce this in our environment?
You can follow this reply. I have provided model and step in the following link.
We try to reproduce this issue in our environment.
But cannot download the onnx file shared in this comment .
Could you make the model public so we can download it?
I have sent you the download link by message.
Thanks. We get the model successfully.
Will update here for any progress.
We can reproduce this issue in our environment.
Based on below topic, this issue can be avoided by setting the opset version into 9 .
opened 05:14PM - 17 Mar 20 UTC
closed 05:41AM - 01 Jul 22 UTC
Component: ONNX
Conversion: torch.onnx
Release: 7.x
triaged
## Description
My current workflow is `pytorch -> onnx -> tensorrt` and I e… ncounter an issue with the `nn.ConstantPad2D` operation that results in the following error:
While parsing node number 23 [Pad -> "24"]:
--- Begin node ---
input: "input"
input: "22"
input: "23"
output: "24"
op_type: "Pad"
attribute {
s: "constant"
type: STRING
--- End node ---
ERROR: /mypath/onnx-tensorrt/builtin_op_importers.cpp:2106 In function importPad:
[8] Assertion failed: inputs.at(1).is_weights()
[03/12/2020-09:06:29] [E] Failed to parse onnx file
[03/12/2020-09:06:29] [E] Parsing model failed
[03/12/2020-09:06:29] [E] Engine creation failed
[03/12/2020-09:06:29] [E] Engine set up failed
## Environment
OS: Ubuntu 18.04
torch: 1.4.0
onnx: 1.6.0
tensorrt: 7.0.0
cuda: 10.0
python: 2.7
## Steps To Reproduce
```python
# github_repro_example.py
import onnx
import argparse
import torch
import torch.nn as nn
class MinimalModel(nn.Module):
def __init__(self):
super(MinimalModel, self).__init__()
self.constant_zero_pad = nn.ConstantPad2d((1, 0, 0, 0), 0)
def forward(self, input_tensor):
return self.constant_zero_pad(input_tensor)
if __name__ == "__main__":
parser = argparse.ArgumentParser(description='PSMNet')
parser.add_argument('output_onnx')
args = parser.parse_args()
minimal_model = MinimalModel()
minimal_model = nn.DataParallel(minimal_model)
minimal_model.cuda()
# Random deep feature
input_tensor = torch.rand((1, 32, 128, 128))
# Check model can do a forward pass
minimal_model(input_tensor)
# Export to onnx
torch.onnx.export(
minimal_model.module,
(input_tensor),
args.output_onnx,
export_params=True, verbose=True, training=False, opset_version=11
original_model = onnx.load(args.output_onnx)
onnx.checker.check_model(original_model)
Run with:
python2 github_repro_example.py ./test.onnx
Run it through tensorrt
trtexec --explicitBatch --onnx ./test.onnx --verbose
Which will result in the above error.
# Related issues
https://github.com/onnx/onnx-tensorrt/issues/378
https://github.com/onnx/onnx-tensorrt/issues/411
Could you check if it helps first?
Apologies for the late reply. I’ve been busy last week.
I have tried it but still got errors like the following picture.
The root cause is from the Pad_51 layer.
Please noted that the parameters of padding layer need to be a pre-defined constant rather than a tensor input.
Based on your model, the padding parameter is defined as tensor with some runtime calculation although the value is a constant.
A workaround for this is to calculate the tensor 226 value and replace it with a constant input.
This can be achieved by using our ONNX graphsurgeon API:
Thanks for your reply. I’ll give it a try this week and tell you the result.
I’m trying to follow your workaround but I get some problem. I think the workflow is using ONNX graphsurgeon to add a output to the “Cast_50” and using onnxruntime to get the “Cast_50” output. Then using onnx_graphsurgeon.Constant to replace it but I can’t add a output to the “Cast_50” because it only allow one output.
Is the workflow correct? If so, can you give me a sample or a hint to calculate the tensor 226 (Cast_50) ?
You should replace the Cast_50 node with a constant node directly.
The parameter can be calculated like this:
(204 constant) [0, 1, 0, 1] → (207 gather) [0] → …
Here is a online visualized tool can help you calculate the output.
I’ve calculated the Cast_50 output is [array([0, 0, 0, 0, 0, 0, 1, 1], dtype=int64)] and replaced tensor value with constant value and run it successfully by onnxruntime .
When I using trtexec to convert it from onnx to trt , I get a new error
[8] Assertion failed: mode == “constant” && value == 0.f && “This version of TensorRT only supports constant 0 padding!” .
It looks like the same error when setting the opset version into 9 (I’m using opset 11 now).
This is the model:
https://drive.google.com/file/d/1fG-2Y1fGZc5Gabw2dQzZjysi6SZumr-6/view?usp=sharing
The trtexec command is:
sudo ./trtexec --onnx=modified.onnx --verbose
The Drive doesn’t enable the permission.
Could you help to check it?
