Errors with reading pb file in TensorRT and readNetFromTensorflow in C++
I have Python code along with TensorRT with Docker container 20.03, which has CUDA 10.2 and TensorRT 7.0.0
from __future__ import print_function
import warnings
import matplotlib.pyplot as plt
import numpy as np
import pandas as pd
from imutils.paths import list_images
from keras import backend as K
from keras.callbacks import CSVLogger
from keras.layers import *
from keras.models import Model
from keras.optimizers import Adam
from scipy.io import loadmat
from scipy.misc import imread
from skimage.io import imsave
from skimage.transform import resize
import cv2
import tensorflow as tf
Ny=1024
target_size = (Ny, Ny)
warnings.filterwarnings('ignore')
LR= 1e-4
E, BS = 2,4
def get_unet(img_rows, img_cols):
    inputs = Input((img_rows, img_cols, 1))
    conv1 = Conv2D(32, (3, 3), activation='relu', padding='same')(inputs)
    conv1 = BatchNormalization()(conv1)
    conv1 = Conv2D(32, (3, 3), activation='relu', padding='same')(conv1)
    pool1 = MaxPooling2D(pool_size=(2, 2))(conv1)
    conv2 = Conv2D(64, (3, 3), activation='relu', padding='same')(pool1)
    conv2 = BatchNormalization()(conv2)
    conv2 = Conv2D(64, (3, 3), activation='relu', padding='same')(conv2)
    pool2 = MaxPooling2D(pool_size=(2, 2))(conv2)
    conv3 = Conv2D(128, (3, 3), activation='relu', padding='same')(pool2)
    conv3 = BatchNormalization()(conv3)
    conv3 = Conv2D(128, (3, 3), activation='relu', padding='same')(conv3)
    pool3 = MaxPooling2D(pool_size=(2, 2))(conv3)
    conv4 = Conv2D(256, (3, 3), activation='relu', padding='same')(pool3)
    conv4 = BatchNormalization()(conv4)
    conv4 = Conv2D(256, (3, 3), activation='relu', padding='same')(conv4)
    pool4 = MaxPooling2D(pool_size=(2, 2))(conv4)
    conv5 = Conv2D(512, (3, 3), activation='relu', padding='same')(pool4)
    conv5 = BatchNormalization()(conv5)
    conv5 = Conv2D(512, (3, 3), activation='relu', padding='same')(conv5)
    conv5 = Dropout(0.5)(conv5)
    up6 = concatenate([UpSampling2D(size=(2, 2))(conv5), conv4], axis=3)
    conv6 = Conv2D(256, (3, 3), activation='relu', padding='same')(up6)
    conv6 = Conv2D(256, (3, 3), activation='relu', padding='same')(conv6)
    up7 = concatenate([UpSampling2D(size=(2, 2))(conv6), conv3], axis=3)
    conv7 = Conv2D(128, (3, 3), activation='relu', padding='same')(up7)
    conv7 = Conv2D(128, (3, 3), activation='relu', padding='same')(conv7)
    up8 = concatenate([UpSampling2D(size=(2, 2))(conv7), conv2], axis=3)
    conv8 = Conv2D(64, (3, 3), activation='relu', padding='same')(up8)
    conv8 = Conv2D(64, (3, 3), activation='relu', padding='same')(conv8)
    up9 = concatenate([UpSampling2D(size=(2, 2))(conv8), conv1], axis=3)
    conv9 = Conv2D(32, (3, 3), activation='relu', padding='same')(up9)
    conv9 = Conv2D(32, (3, 3), activation='relu', padding='same')(conv9)
    conv10 = Conv2D(1, (1, 1), activation='sigmoid')(conv9)
        conv9=inputs
    model = Model(inputs=[inputs], outputs=[conv10])
    model.compile(optimizer=Adam(lr=LR),
                      loss='binary_crossentropy',
                      metrics=['binary_crossentropy'])
    return model
train_images=np.zeros([1, 1024,1024,1], dtype=float)
annot_train=np.zeros([1, 1024,1024,1], dtype=float)
test_images=np.zeros([1, 1024,1024,1], dtype=float)
annot_test=np.zeros([1, 1024,1024,1], dtype=float)
img = cv2.imread('owlResized.bmp', 0)/255.0
label = cv2.imread('owlResized.bmp', 0)/255.0
train_images[0,:,:,0], annot_train[0,:,:,0] =img, label
test_images[0,:,:,0], annot_test[0,:,:,0] =img, label
print("finished reading")
C = np.concatenate([annot_test, annot_train])
I = np.concatenate([test_images, train_images])
unet = get_unet(Ny, Ny)
filepath="W-E_{epoch:02d}-L_{loss:.6f}"+outName+".h5"
history = unet.fit(I, C, verbose=2, epochs=E, batch_size=BS, validation_split=0.1)
#save pb
unet.save('owlSimple', overwrite=True, include_optimizer=False, save_format='tf')
Then did
python3 -m tf2onnx.convert --opset 12 --saved-model ./owlSimple --output owlSimple12.onnx
I also tried opset of 9,10,11. They all seemed to convert successfully
When I tried to run opsets 11 and 12 in TensorRT, I would get as error:
ERROR: ModelImporter.cpp:92 In function parseGraph:
[8] Assertion failed: convertOnnxWeights(initializer, &weights, ctx)
ERROR: could not parse the model.
setBindingDimensions
With opset 10, I got:
While parsing node number 45 [Resize]:
ERROR: builtin_op_importers.cpp:2412 In function importResize:
[8] Assertion failed: scales.is_weights() && "Resize scales must be an initializer!"
and with Opset9 I got
While parsing node number 45 [Upsample]:
ERROR: builtin_op_importers.cpp:3240 In function importUpsample:
[8] Assertion failed: scales_input.is_weights()
I got those errors even when I did
wget https://raw.githubusercontent.com/rmccorm4/tensorrt-utils/master/OSS/build_OSS.sh
source build_OSS.sh
If I further simplified the Unet by replacing the Unet with
conv9=inputs
as seen in the commented out code above, then I get these errors when running the various opsets in TensorRT:
 input_2:0: dynamic input is missing dimensions in profile 0.
 Network validation failed.
The TensorRT C++ I used is (It is based on code from How To Run Inference Using TensorRT C++ API | LearnOpenCV):
#include <iostream>
#include <fstream>
#include <NvInfer.h>
#include <NvInferRuntime.h>
#include <memory>
#include <NvOnnxParser.h>
#include <vector>
#include <cuda_runtime_api.h>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/core/cuda.hpp>
#include <opencv2/cudawarping.hpp>
#include <opencv2/core.hpp>
#include <opencv2/cudaarithm.hpp>
#include <algorithm>
#include <numeric>
#include <opencv2/dnn/dnn.hpp>
#include <opencv2/opencv.hpp>
#include <opencv2/cudaimgproc.hpp>
using namespace cv;
// utilities ----------------------------------------------------------------------------------------------------------
// class to log errors, warnings, and other information during the build and inference phases
class Logger : public nvinfer1::ILogger
public:
    void log(Severity severity, const char* msg) override {
        // remove this 'if' if you need more logged info
        if ((severity == Severity::kERROR) || (severity == Severity::kINTERNAL_ERROR)) {
            std::cout << msg << "\n";
} gLogger;
// destroy TensorRT objects if something goes wrong
struct TRTDestroy
    template <class T>
    void operator()(T* obj) const
        if (obj)
            obj->destroy();
template <class T>
using TRTUniquePtr = std::unique_ptr<T, TRTDestroy>;
// calculate size of tensor
size_t getSizeByDim(const nvinfer1::Dims& dims)
    size_t size = 1;
    for (size_t i = 0; i < dims.nbDims; ++i)
        size *= dims.d[i];
    return size;
// get classes names
std::vector<std::string> getClassNames(const std::string& imagenet_classes)
    std::ifstream classes_file(imagenet_classes);
    std::vector<std::string> classes;
    if (!classes_file.good())
        std::cerr << "ERROR: can't read file with classes names.\n";
        return classes;
    std::string class_name;
    while (std::getline(classes_file, class_name))
        classes.push_back(class_name);
    return classes;
// preprocessing stage ------------------------------------------------------------------------------------------------
void preprocessImage(const std::string& image_path, float* gpu_input, const nvinfer1::Dims& dims)
    // read input image
    cv::Mat frame = cv::imread(image_path);
    if (frame.empty())
        std::cerr << "Input image " << image_path << " load failed\n";
        return;
    cv::cuda::GpuMat gpu_frame;
    gpu_frame.upload(frame);
    int channels=1;
    auto input_width = dims.d[1];
    auto input_height = dims.d[0];
    auto input_size = cv::Size(input_width, input_height);
    cv::cuda::GpuMat resized=gpu_frame;
    //normalize
    cv::cuda::GpuMat flt_image;
    resized.convertTo(flt_image, CV_32FC1, 1.f / 255.f);
    std::vector<cv::cuda::GpuMat> chw;
    for (size_t i = 0; i < channels; ++i)
        chw.emplace_back(cv::cuda::GpuMat(input_size, CV_32FC1, gpu_input + i * input_width * input_height));
    cv::cuda::split(flt_image, chw);
// post-processing stage ----------------------------------------------------------------------------------------------
void postprocessResults(float *gpu_output, const nvinfer1::Dims &dims, int batch_size)
    std::vector<float> cpu_output(getSizeByDim(dims) * batch_size);
    cudaMemcpy(cpu_output.data(), gpu_output, cpu_output.size() * sizeof(float), cudaMemcpyDeviceToHost);
    auto rows = dims.d[1];
    auto cols = dims.d[2];
    cv::Mat Finalmat = cv::Mat(rows, cols, CV_32FC1); // initialize matrix of uchar of 1-channel where you will store vec data
    //copy vector to mat
    memcpy(Finalmat.data, cpu_output.data(), cpu_output.size()*sizeof(float));
    Finalmat.convertTo(Finalmat, CV_8UC3, 255.0);
    cv::imwrite("trt_output.bmp", Finalmat);
// initialize TensorRT Context and Engine and parse ONNX model --------------------------------------------------------------------
void parseOnnxModel(const std::string& model_path, TRTUniquePtr<nvinfer1::ICudaEngine>& engine,
                    TRTUniquePtr<nvinfer1::IExecutionContext>& context)
    nvinfer1::IBuilder *builder = nvinfer1::createInferBuilder(gLogger);
    const auto explicitBatch = 1U << static_cast<uint32_t>(nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
    nvinfer1::INetworkDefinition *network = builder->createNetworkV2(explicitBatch);
    TRTUniquePtr<nvonnxparser::IParser> parser{nvonnxparser::createParser(*network, gLogger)};
    // parse ONNX
    if (!parser->parseFromFile(model_path.c_str(), static_cast<int>(nvinfer1::ILogger::Severity::kINFO)))
        std::cerr << "ERROR: could not parse the model.\n";
        return;
    //create Config to configure engine parameters such as max memory or set FP16 mode
    TRTUniquePtr<nvinfer1::IBuilderConfig> config{builder->createBuilderConfig()};
    nvinfer1::IOptimizationProfile* profile = builder->createOptimizationProfile();
    profile->setDimensions("input_1", nvinfer1::OptProfileSelector::kMIN, nvinfer1::Dims4(1,1024,1024,1));
    profile->setDimensions("input_1", nvinfer1::OptProfileSelector::kOPT, nvinfer1::Dims4(1,1024,1024,1));
    profile->setDimensions("input_1", nvinfer1::OptProfileSelector::kMAX, nvinfer1::Dims4(1,1024,1024,1));
    config->addOptimizationProfile(profile);
    // allow TensorRT to use up to 1GB of GPU memory for tactic selection.
    config->setMaxWorkspaceSize(1ULL << 30);
    // use FP16 mode if possible
    if (builder->platformHasFastFp16())
        config->setFlag(nvinfer1::BuilderFlag::kFP16);
    // we have only one image in batch
    builder->setMaxBatchSize(1);
    // generate TensorRT engine optimized for the target platform
    engine.reset(builder->buildEngineWithConfig(*network, *config));
    context.reset(engine->createExecutionContext());
// main pipeline ------------------------------------------------------------------------------------------------------
int main(int argc, char* argv[])
    if (argc < 3)
        std::cerr << "usage: " << argv[0] << " [model_name].onnx [image_name].jpg\n";
        return -1;
    std::string model_path(argv[1]);
    std::string image_path(argv[2]);
    int batch_size = 1;
    TRTUniquePtr<nvinfer1::ICudaEngine> engine{nullptr};
    TRTUniquePtr<nvinfer1::IExecutionContext> context{nullptr};
    parseOnnxModel(model_path, engine, context);
    // get sizes of input and output and allocate memory required for input data and for output data
    std::vector<nvinfer1::Dims> input_dims; // we expect only one input
    std::vector<nvinfer1::Dims> output_dims; // and one output
    context->setBindingDimensions(0, nvinfer1::Dims4(1, 1024,1024, 1));
    //getNbBindings is number of binding indices
    // buffers for input and output data
    std::vector<void*> buffers(engine->getNbBindings());
    for (size_t i = 0; i < engine->getNbBindings(); ++i)
        if (engine->bindingIsInput(i))
            input_dims.emplace_back(context->getBindingDimensions(i));
        else
            output_dims.emplace_back(context->getBindingDimensions(i));
        auto binding_size = getSizeByDim(context->getBindingDimensions(i)) * batch_size * sizeof(float);
        auto status = cudaMalloc(&buffers[i], binding_size);
        if (status)
            std::cout<<"cudaMalloc worked\n";
    if (input_dims.empty() || output_dims.empty())
        std::cerr << "Expect at least one input and one output for network\n";
        return -1;
    preprocessImage(image_path, (float *) buffers[0], input_dims[0]);
    postprocessResults((float *) buffers[1], output_dims[0], batch_size);
    for (void* buf : buffers)
        cudaFree(buf);
    return 0;
I then tried to open the pb file with readNetFromTensorflow. I have saved_model.pb in /workspace/owlSimple/saved_model.pb and in /workspace. In /workspace, I’ve tried
    dnn:Net nt = cv::dnn::readNetFromTensorflow("saved_model.pb");
    dnn:Net nt = cv::dnn::readNetFromTensorflow("owlSimple/saved_model.pb");
    dnn:Net nt = cv::dnn::readNetFromTensorflow("./owlSimple/saved_model.pb");
    dnn:Net nt = cv::dnn::readNetFromTensorflow("/workspace/owlSimple/saved_model.pb");
    dnn:Net nt = cv::dnn::readNetFromTensorflow("/owlSimple/saved_model.pb");
But all of them are giving the same error of
String field 'opencv_tensorflow.FunctionDef.Node.ret' contains invalid UTF-8 data when parsing a protocol buffer. Use the 'bytes' type if you intend to send raw bytes.
what(): OpenCV(4.5.1-pre) /workspace/opencv/modules/dnn/src/tensorflow/tf_io.cpp:42: error: (-2:Unspecified error) FAILED: ReadProtoFromBinaryFile(param_file, param). Failed to parse GraphDef file: owlSimple/saved_model.pb in function 'ReadTFNetParamsFromBinaryFileOrDie'
Hi @mke489,
Please convert your pb file to onnx
and then convert it to trt.
If the issue still persist, please share onnx model.
for your reference ONNX-TensorRT
Thank you.
Hi @mke489,
This is a known issue and fix will be available in future release.
Meanwhile you can refer to the below link to resolve it.
Thank you.
can anyone help?
