Hello everyone,
Some days ago i switched from Linux Mint (Cinnamon DE
on Xorg) to Arch linux (Hyprland WM on wayland).
My laptop has a NVIDIA dedicated GPU and an intel integrated GPU. On Linux Mint everything was fine and i was using the closed-source nvidia drivers of the 535 series.
On Arch i struggled a lot to make the nvidia GPU automatically switch to D3 mode when not used.
The driver version I’m currently using on arch is 555.58.02. I tried to setup my system so that everything would run on the iGPU by default. However I still want to be able to run programs on my nvidia dGPU using PRIME so I don’t want to disable it.
Since my nvidia GPU supports D3 power management my goal was to make it sleep when not used and wake up if I wanted to use it.
After some days of trying a lot of different things with no success I finally managed to accomplish that but I noticed some possibly buggy behaviours:
- I had to set the
nvidia_drmmodule to be loaded withmodeset=0as a parameter otherwise it would keep the GPU onD0power status. - I had to either run
nvidia-persistenced.servicewith the--no-persistence-modeflag or simply disable it, otherwise the GPU would remain onD0power status in this case too. - The
nvidiadriver is not able to detect information correctly:cat /proc/driver/nvidia/gpus/0000:01:00.0/powershowsRuntime D3 status: Not supportedandVideo Memory Self Refresh: Not supported. Not sure what this means since on Linux Mint they are both shown as supported. - If
nvidia_drmis launched withmodeset=0thenvidiadriver just shows a lot of question marks when doingcat /proc/driver/nvidia/gpus/0000:01:00.0/power
Feel free to ask for more info, thanks.
bug-report.gz (232.8 KB)
