• Ubuntu 24.04 x86_64 laptop with ADA 2000
• DeepStream 8.0
• TensorRT - does not matter here, but 10.9.0.34-1+cuda12.8
• NVIDIA GPU Driver - 570.195.03-0ubuntu1
• OpenCV 4.12 with CUDA support
• Issue Type - Example has a problem:-(
I know, the OpenCV support is kind of deprecated. But it’s still in the code and it should work when enabled.
The gst-dsexample-cuda creates a GPU buffer/mat for for OpenCV to work on. That mat is then handed to the sample library code. But the input frame is never copied there:-( From what I’ve seen the get_converted_mat() should prepare the input for the library, and it does most of it.
I changed the code around line 603 a bit to actually populate the cvgpumat;-) The original just leaves the converted mat in the local variable and forgets about it.
#ifdef WITH_OPENCV
/* In place GPU operation on the transformed buffer.
Visual output will be different to original input.
in_mat =
cv::cuda::GpuMat (dsexample->processing_height, dsexample->processing_width,
CV_8UC4, (void *) dsexample->inter_buf->surfaceList[0].dataPtr,
dsexample->inter_buf->surfaceList[0].pitch);
// XXX MARCO
cv::cuda::cvtColor(in_mat, *dsexample->cvgpumat, cv::COLOR_RGBA2BGR);
//Swapped R and B channels
cv::cuda::swapChannels(in_mat, aDstOrder);
// XXX MARCO
cudaMemcpy(dsexample->cvgpumat->data, in_mat.data, dsexample->processing_height *
dsexample->processing_width * RGBA_BYTES_PER_PIXEL, cudaMemcpyDeviceToDevice);
/* In place GPU operation can also be verified by directly using the input buffer.
in_mat =
cv::cuda::GpuMat (ip_surf.surfaceList[0].height, ip_surf.surfaceList[0].width,
CV_8UC4, (void *) ip_surf.surfaceList[0].dataPtr,
ip_surf.surfaceList[0].pitch);
#endif
I’m only interested inthe RGB/BGR channels, so I do the conversion there.
– Marco
