Using “source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt”
Config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
# 0 - cuda pinned/host memory
# 1 - cuda device memory
# 2 - cuda unified memory
cuda-memory-type=1
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../streams/sample_720p.mp4
num-sources=4
gpu-id=0
cuda-memory-type=1
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
cuda-memory-type=1
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=mp4 2=mkv
container=2
## only mpeg4 is supported right now.
codec=1
sync=0
bitrate=4000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
cuda-memory-type=1
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
cuda-memory-type=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b4_int8.engine
labelfile-path=../../models/Primary_Detector/labels.txt
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
cuda-memory-type=1
config-file=config_infer_primary.txt
[tracker]
enable=1
tracker-width=640
tracker-height=368
gpu-id=0
[secondary-gie0]
enable=1
model-engine-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_i$
labelfile-path=../../models/Secondary_VehicleTypes/labels.txt
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=../../models/Secondary_CarColor/resnet18.caffemodel_b16_int8.$
labelfile-path=../../models/Secondary_CarColor/labels.txt
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_carcolor.txt
[secondary-gie2]
enable=1
model-engine-file=../../models/Secondary_CarMake/resnet18.caffemodel_b16_int8.e$
labelfile-path=../../models/Secondary_CarMake/labels.txt
batch-size=16
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_secondary_carmake.txt
[tests]
file-loop=0
Can you suggest me a way to upload the out.mp4 video to here?
I do not the see the video, also, what do you mean no on-screen display? don’t you use sink type 3=File for
output? if you use this type, will output to the file, let’s say one mp4 file. if you want to output to the screen, you should use sink type 2=EglSink
I tried to execute the default config source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt which is using sink0 type 2 (EglSink), but giving me the following error.
* ERROR: <main:564>: Failed to set pipeline to PAUSED
Quitting
App run failed
just like you use in docker, deepstream-app -c /path to config/source30_720p_dec_infer-resnet_tiled_display_int8.txt
change sink type to 2=EglSink in the config, please make sure you follow the README within the deepstream package.
If you need to output to screen, yes, you need one nvidia graphic card which support display,
a hacky way to use Tesla p4 for virtual display, but just suggest for developments, since it
will take some percent of device memory, finally impact the inference perf in this case deepstream,
sudo nvidia-xconfig --query-gpu-info
Number of GPUs: 2
GPU #0:
UUID : GPU-b58f5878-b235-c28e-4e2a-44d8623d133a
PCI BusID : PCI:3:0:0
Number of Display Devices: 0
GPU #1:
UUID : GPU-55bc88aa-fc94-0e86-9319-abd5fadf49ab
PCI BusID : PCI:4:0:0
sudo nvidia-xconfig --busid=PCI:4:0:0 --allow-empty-initial-configuration
reboot system, install nomachine from your windows system, and also need install nomachine on your
linux server which have p4 installed, and login to desktop using nomachine from windows system.
