Description
Hi, I am using Deepstream5.0 with my custom onnx model on x86 machine. While running the inference there is an error regarding TensorRT reshape…
I had successfully ran the same model with Deepstream4.0.2 previously and did same upgrades with DS5.0.
The error is -
create pipeline
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: (Unnamed Layer* 233) [Shuffle]: reshaping failed for tensor: 879
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: shapeMachine.cpp (160) - Shape Error in executeReshape: reshape would change volume
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: Instruction: RESHAPE{1 19840 2} {9920 2}
0:00:01.052997295 5611 0x55ccb9839640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/home/inkers/rahul/inkFR2.0/launchconfigs/Primary_UpperBody/meanfixed640_372/mnetv2_372x640_simplified.onnx_b2_gpu0_fp32.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [FullDims Engine Info]: layers num: 7
0 INPUT kFLOAT image 3x372x640 min: 1x3x372x640 opt: 2x3x372x640 Max: 2x3x372x640
1 OUTPUT kFLOAT face_bbox -1x5 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT face_landm -1x15 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT person_bbox -1x5 min: 0 opt: 0 Max: 0
4 OUTPUT kFLOAT person_landm -1x15 min: 0 opt: 0 Max: 0
5 OUTPUT kFLOAT face_cls 9920x2 min: 0 opt: 0 Max: 0
6 OUTPUT kFLOAT person_cls 9920x2 min: 0 opt: 0 Max: 0
0:00:01.053130285 5611 0x55ccb9839640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /home/inkers/rahul/inkFR2.0/launchconfigs/Primary_UpperBody/meanfixed640_372/mnetv2_372x640_simplified.onnx_b2_gpu0_fp32.engine
inkfr3-app: nvdsinfer_context_impl.cpp:1301: NvDsInferStatus nvdsinfer::NvDsInferContextImpl::allocateBuffers(): Assertion `bindingDims.numElements > 0’ failed.
Environment
TensorRT Version: 7.2.1
GPU Type: Descrete
Nvidia Driver Version: 450.102.04
CUDA Version: 10.2
CUDNN Version: 7.6.5
Operating System + Version: Ubuntu18.04 running on x86.
Python Version (if applicable): python3.6
TensorFlow Version (if applicable): Not used
PyTorch Version (if applicable): Not used
Baremetal or Container (if container which image + tag): not used
If required i can share the changes done in files.
