DSR is nice but Issues has been present till now
First of all, hello and sorry for posting this in here I kind of knew user to this developer page So excuse me if there are some mistakes in this post.
Basically, I have an issue with dsr factors From Nvidia control panels First of all, when I set the resolution to be on. to be at 4K. from the control panel settings by the way, I have a 1080p native resolution. and RTX 3070 laptop GPU. and then after I set 4K with the factors Then I will jump back to my game. in order to change the resolution beyond my native resolution which this is what the DSR is about. Ok, no issue Perfect stable frame rates at this 4K DSR. No lag at all. But here’s here come the problem. When I finished gaming and I just want to shut down the computer or even do a restart. Now, when the computer freshly booted. and I jumped back to my game, which of course the settings was saved. was saved at 4K. last time. Now the game stutters like crazy. and constant lagging. It is like the GPU doesn’t recognize the resolution after a restart or shut down the only solution that I came up so far is I have to change the resolution back to 1080p from the game settings and not only that still it is present but when I send it to 1080p and the next step I have to restart my computer in order to the GPU res Self and became afresh. boot kernel. Now when I jump back the game if you remember now it should be 1080p because before the shutdown or before the restart in order to overcome this issue, I have changed back to 10 adp. Now there is no problem that game works fine run fine. And then like the first time I can now change back from the menu of the game to the 4KDSR factors that I have specified before. Now again the game runs fine perfectly with No. issue. Now here. to come again the cycle. when I shut down the computer again or I just want to quit and do a restart now because the game settings save it at 4K. now when I jump back to a game after a restart or shut down it is like the first I’ve talked about it It will be constantly lagging and stuttering. So like I said, it is look like the graphic card doesn’t recognize the 4K DSR after a clean restart or shut down. now and before you respond to me I. have done literally everything fresh. clean windows install up the GPU drivers try different games and by the way it doesn’t happen with every game. I think. specifically it happens with Vulcan IPI systems and directed X12 games. which means not the directed echoes 11 or 10 or 9 which all their games it doesn’t happen to those games. Unfortunately it will only happens to Vulcan and directed X12 games. So no, I really search everything Did everything nothing will solve this issue and even through the Internet I have searched about it. It seems that no one having the same. issue or there isn’t even a post about such issue. so I don’t know Do you guys think this is a bug from Nvidia because I don’t think my system has any issue provided that I have did Windows update Windows reinstall I used. DDU 3rd app. party even to wipe everything shader cash everything everything restored the default settings played with the settings and by the way I haven’t even maxed out the graphic when I’m have constantly. lagging and stuttering at the DSR after the restart of the previously saved settings of the game which is at 4KDFR so I really hope you get what I said…
