We did not make any changes in bootloader/UEFI.
We tested it now with the DevKit (with a 32GB AGX Orin Module) with the same result.
Flash log:
flash_log.txt (569.4 KB)
Without FDT entry:
cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 pcie_aspm=off
cat /proc/device-tree/nvidia,dtsfilename
BOOTLOADER_DTB
With FDT entry:
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
FDT /boot/dtb/kernel_tegra234-p3737-0000+p3701-0004-nv_.dtb
KERNEL_DTB
And our jetson-agx-orin-devkit.conf looks the following:
# SPDX-FileCopyrightText: Copyright (c) 2022-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: BSD-3-Clause
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its
# contributors may be used to endorse or promote products derived from
# this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
# SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
# CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
# OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# concord-upstream.conf: configuration for "P3701 + P3737"
# (T234 P3710).
source "${LDK_DIR}/p3737-0000-p3701-0000.conf.common";
update_flash_args_p3737_0000_p3701_0000()
# Select the Base DTB based on SKU
if [ "${board_sku}" = "0000" ]; then
# Enable VRS11 DCM mode for CPU/GPU/CV rails
PMIC_CONFIG="tegra234-mb1-bct-pmic-p3701-0005.dts";
DTB_FILE=tegra234-p3737-0000+p3701-0000-nv.dtb;
elif [ "${board_sku}" = "0001" ] || [ "${board_sku}" = "0002" ]; then
elif [ "${board_sku}" = "0004" ]; then
DTB_FILE=tegra234-p3737-0000+p3701-0004-nv_.dtb;
elif [ "${board_sku}" = "0005" ]; then
DTB_FILE=tegra234-p3737-0000+p3701-0005-nv.dtb;
else
echo "Error: Unrecognized module SKU ${board_sku}";
exit 1;
fi
TBCDTB_FILE=tegra234-p3737-0000+p3701-0004-nv_bootloader.dtb;
# update_flash_args:
update_flash_args()
update_flash_args_common
TBCDTB_FILE="${DTB_FILE}";
OVERLAY_DTB_FILE="L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo";
In the DTB file tegra234-p3737-0000+p3701-0004-nv_.dtb we only added nvidia,dtsfilename=KERNEL_DTB and in the DTB file tegra234-p3737-0000+p3701-0004-nv_bootloader.dtb nvidia,dtsfilename=BOOTLOADER_DTB.
