ok thats weird lol
I will look for drop hose tomorrow
thanks
ok thats weird lol
thanks
this is where I am at.
rxgb world textures jpg on models want to change to dds along with alpha textures
could not find drophose yet may try in the map editor
nope still cant find it
Yep! For BC3 (non-RXGB), that should be correct. (If you have the standalone version and run "C:\Program Files\NVIDIA Corporation\NVIDIA Texture Tools\nvtt_export.exe" --help in a command line, it’ll print out all of the possible format names. BC3 is “bc3”; BC3N RXGB is “bc3n-rxgb”; BC1A is “bc1a”, and BC1 (without transparency) is “bc1”.
–Neil
thanks sorry took me forever to be able to login
have you tried rxgb on model textures at all ?
use to work for me, now its not
Hi @y2keeth,
The important thing seems to be to match up the format between the original files and the files you want to replace them with. BC1 and BC3 seem to be the most common; RXGB is pretty rare. For instance, the only file in pak003.pk4 that uses RXGB is models\characters\marine\eye_local.dds, which is a normal map. Replacing non-RXGB files with RXGB data will probably fail, it seems like.
Hope this helps,
–Neil
worked once
ended up using jpgs
if you want to check it out
I want to replace the tga’s with dds. rxgb seamed the closest to tga quality
got a favor to ask could you check the stock model textures characters\ marine for any helmet .dds files if you have more than 2 p[ease send them to me
Hi @y2keeth ! In the first 10 pak files, I see the 3 helmet normal maps in pak009.pk4/progimg/addnormals/models/characters/marine and pak010.pk4/progimg/downsize/models/characters/marine. However, I don’t think I’m allowed to send out files from Steam games and can’t provide this level of support – sorry! (Note that the helmet normal maps in pak009.pk4 are indeed RXGB DDS files, though!)
–Neil
not what i am looking for any way thanks
like helmet_d.dds and the h ands s files, and the other d’s they dont seam to exist
when i set use pre compressed textures to on the helmets are black, all the other textures seem to work fine
wish I knew what I did here lol
is bc3_unorm(77) rxgb? under input info
