@WayneWWW
Below, I share the dmesg output.
~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5496-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29868(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568472K/4159488K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 115880K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001674] Console: colour dummy device 80x25
[ 0.001685] console [tty0] enabled
[ 0.001690] bootconsole [uart8250] disabled
[ 0.001709] kmemleak: Kernel memory leak detector disabled
[ 0.001727] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001739] pid_max: default: 32768 minimum: 301
[ 0.002178] Security Framework initialized
[ 0.002398] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002406] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003505] ftrace: allocating 47077 entries in 184 pages
[ 0.170870] sched-energy: CPU device node has no sched-energy-costs
[ 0.170901] ASID allocator initialised with 65536 entries
[ 0.207577] tegra-id: chipid=22117.
[ 0.207588] tegra-id: opt_subrevision=0.
[ 0.207606] Tegra Speedo/IDDQ fuse revision 4
[ 0.207612] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.207617] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.207622] Tegra: CPU Speedo Value 2061, SoC Speedo Value 1952, GPU Speedo Value 2057
[ 0.207627] Tegra: CPU IDDQ Value 1664, SoC IDDQ Value 1800, GPU IDDQ Value 2175
[ 0.207646] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.207662] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.207668] DTB Build time: Jul 26 2021 12:16:29
[ 0.257064] CPU1: Booted secondary processor [411fd071]
[ 0.288955] CPU2: Booted secondary processor [411fd071]
[ 0.320938] CPU3: Booted secondary processor [411fd071]
[ 0.321023] Brought up 4 CPUs
[ 0.321029] SMP: Total of 4 processors activated.
[ 0.321037] CPU features: detected feature: 32-bit EL0 Support
[ 0.321293] CPU: All CPU(s) started at EL2
[ 0.321310] alternatives: patching kernel code
[ 0.329373] devtmpfs: initialized
[ 0.366766] Initilizing CustomIPI irq domain
[ 0.367080] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.367100] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.377661] pinctrl core: initialized pinctrl subsystem
[ 0.378235] OS set in device tree is not L4T.
[ 0.378655] regulator-dummy: no parameters
[ 0.378922] Initializing plugin-manager
[ 0.379080] Plugin module not found
[ 0.379269] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.379765] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.380726] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.380934] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.381617] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.385033] NET: Registered protocol family 16
[ 0.386336] pstore: using zlib compression
[ 0.386378] console [pstore-1] enabled
[ 0.386383] pstore: Registered ramoops as persistent store backend
[ 0.386388] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401082] cpuidle: using governor menu
[ 0.405138] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406756] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.406778] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409542] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.411902] Serial: AMBA PL011 UART driver
[ 0.412404] tegra_powergate_init: DONE
[ 0.412419] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.412425] DTB Build time: Jul 26 2021 12:16:29
[ 0.414249] Tegra reboot handler registered.
[ 0.418772] iommu: Adding device tegra-carveouts to group 0
[ 0.418908] platform tegra-carveouts: domain=ffffffc0f941e3d8 allocates as[0]=ffffffc0f94380a8
[ 0.419251] iommu: Adding device smmu_test to group 1
[ 0.419300] platform smmu_test: domain=ffffffc0f941e618 allocates as[0]=ffffffc0f9438110
[ 0.420111] mc: mapped MMIO address: 0xffffff8008041000 → 0x70019000
[ 0.420170] mc: mapped MMIO address: 0xffffff8008067000 → 0x7001c000
[ 0.420231] mc: mapped MMIO address: 0xffffff800807b000 → 0x7001d000
[ 0.420240] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.420261] mc-err: mcerr ops are set to t21x
[ 0.430943] iommu: Adding device 70090000.xusb to group 2
[ 0.431220] iommu: Adding device 70006000.serial to group 3
[ 0.431302] platform 70006000.serial: domain=ffffffc0f94bd558 allocates as[0]=ffffffc0f9438178
[ 0.431726] iommu: Adding device 70006040.serial to group 4
[ 0.432000] iommu: Adding device 70006200.serial to group 5
[ 0.432222] iommu: Adding device sound to group 6
[ 0.432270] platform sound: domain=ffffffc0f94bda98 allocates as[0]=ffffffc0f94381e0
[ 0.432838] iommu: Adding device 7000d400.spi to group 7
[ 0.433122] iommu: Adding device 7000d600.spi to group 8
[ 0.433398] iommu: Adding device 70410000.spi to group 9
[ 0.433702] iommu: Adding device 50000000.host1x to group 10
[ 0.433979] iommu: Adding device 54080000.vi to group 11
[ 0.434366] iommu: Adding device 54600000.isp to group 12
[ 0.434664] iommu: Adding device 54680000.isp to group 13
[ 0.434936] iommu: Adding device tegradc.0 to group 14
[ 0.434990] platform tegradc.0: domain=ffffffc0f94c89d8 allocates as[0]=ffffffc0f9438248
[ 0.435503] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435806] iommu: Adding device tegradc.1 to group 15
[ 0.435854] platform tegradc.1: domain=ffffffc0f94c8c18 allocates as[0]=ffffffc0f94382b0
[ 0.436358] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.436605] iommu: Adding device 54340000.vic to group 16
[ 0.436806] iommu: Adding device 544c0000.nvenc to group 17
[ 0.437071] iommu: Adding device 54500000.tsec to group 18
[ 0.437292] iommu: Adding device 54100000.tsecb to group 19
[ 0.437513] iommu: Adding device 54480000.nvdec to group 20
[ 0.437705] iommu: Adding device 54380000.nvjpg to group 21
[ 0.438766] iommu: Adding device 546c0000.i2c to group 22
[ 0.439094] iommu: Adding device 57000000.gpu to group 23
[ 0.439147] platform 57000000.gpu: domain=ffffffc0f94d2c18 allocates as[0]=ffffffc0f9438318
[ 0.439182] platform 57000000.gpu: domain=ffffffc0f94d2c18 allocates as[1]=ffffffc0f9438380
[ 0.439224] platform 57000000.gpu: domain=ffffffc0f94d2c18 allocates as[2]=ffffffc0f94383e8
[ 0.439281] platform 57000000.gpu: domain=ffffffc0f94d2c18 allocates as[3]=ffffffc0f9438450
[ 0.440142] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.440151] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.440164] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.440167] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.440172] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.493141] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.493149] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493171] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493234] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493530] iommu: Adding device 70012000.se to group 24
[ 0.494388] iommu: Adding device 7000c000.i2c to group 25
[ 0.494710] iommu: Adding device 7000c400.i2c to group 26
[ 0.495049] iommu: Adding device 7000c500.i2c to group 27
[ 0.495354] iommu: Adding device 7000c700.i2c to group 28
[ 0.495653] iommu: Adding device 7000d000.i2c to group 29
[ 0.495958] iommu: Adding device 7000d100.i2c to group 30
[ 0.496308] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.496358] platform sdhci-tegra.0: domain=ffffffc0f955de58 allocates as[0]=ffffffc0f94384b8
[ 0.497328] iommu: Adding device 700d0000.xudc to group 32
[ 0.501571] vdd-ac-bat: 5000 mV
[ 0.502087] vdd-5v0-sys: 5000 mV
[ 0.502982] vdd-5v0-hdmi: 5000 mV
[ 0.503407] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.503718] vdd-1v8-sys: 1800 mV
[ 0.504188] vdd-fan: 5000 mV
[ 0.504404] vdd-fan: supplied by vdd-5v0-sys
[ 0.504710] vdd-usb-vbus: 5000 mV
[ 0.504991] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.505337] vdd-usb-vbus2: 5000 mV
[ 0.538020] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540203] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.541406] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.541432] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.541452] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.541818] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.549675] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.550021] SCSI subsystem initialized
[ 0.550186] libata version 3.00 loaded.
[ 0.550420] usbcore: registered new interface driver usbfs
[ 0.550463] usbcore: registered new interface driver hub
[ 0.550499] usbcore: registered new device driver usb
[ 0.554601] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.560356] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.561176] random: fast init done
[ 0.561394] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564253] vdd-ddr-1v1: 1150 mV
[ 0.568245] vdd-pre-reg-1v35: 1350 mV
[ 0.572250] vdd-1v8: 1800 mV
[ 0.576241] avdd-sys-1v2: 1200 mV
[ 0.580245] vdd-pex-1v0: 1050 mV
[ 0.580878] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.581402] max77620-ldo3: at 3100 mV
[ 0.584247] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.584779] max77620-ldo5: at 3100 mV
[ 0.588249] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.592240] avdd-1v05-pll: 1050 mV
[ 0.596246] avdd-io-hdmi-dp: 1050 mV
[ 0.598941] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.599222] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.599500] max77620 4-003c: max77620 probe successful
[ 0.602186] media: Linux media interface: v0.10
[ 0.602247] Linux video capture interface: v2.00
[ 0.603234] pps_core: LinuxPPS API ver. 1 registered
[ 0.603239] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.603263] PTP clock support registered
[ 0.606608] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.607477] Advanced Linux Sound Architecture Driver Initialized.
[ 0.608094] Bluetooth: Core ver 2.22
[ 0.608141] NET: Registered protocol family 31
[ 0.608146] Bluetooth: HCI device and connection manager initialized
[ 0.608161] Bluetooth: HCI socket layer initialized
[ 0.608169] Bluetooth: L2CAP socket layer initialized
[ 0.608197] Bluetooth: SCO socket layer initialized
[ 0.609977] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.609992] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.610039] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.610053] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.613395] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.614488] vdd-3v3-sys: 3300 mV
[ 0.614836] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.614886] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.617147] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.617638] vdd-3v3-sd: 3300 mV
[ 0.618032] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.618752] avdd-io-edp-1v05: 1050 mV
[ 0.619114] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.619267] vdd-usb-hub-en: 5000 mV
[ 0.619609] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.620786] camchar: rtcpu character device driver loaded
[ 0.621584] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.622908] clocksource: Switched to clocksource arch_sys_counter
[ 0.662977] VFS: Disk quotas dquot_6.6.0
[ 0.663109] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.663610] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.664062] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.664079] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.664263] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.664270] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.664281] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.664313] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.664319] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.664333] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.664341] nvmap_page_pool_init: Total RAM pages: 1010902
[ 0.664346] nvmap_page_pool_init: nvmap page pool size: 126362 pages (493 MB)
[ 0.664432] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.664920] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.665825] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.673949] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.674393] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.674752] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.675055] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.675242] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.675514] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.675519] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.675957] NET: Registered protocol family 2
[ 0.676934] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.677145] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.677639] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.677782] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.677863] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.678264] NET: Registered protocol family 1
[ 0.678964] RPC: Registered named UNIX socket transport module.
[ 0.678969] RPC: Registered udp transport module.
[ 0.678972] RPC: Registered tcp transport module.
[ 0.678977] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.678988] PCI: CLS 0 bytes, default 64
[ 0.679223] Trying to unpack rootfs image as initramfs…
[ 0.983037] Freeing initrd memory: 6992K
[ 0.992950] host1x 50000000.host1x: initialized
[ 0.994769] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.997976] audit: initializing netlink subsys (disabled)
[ 0.998047] audit: type=2000 audit(0.847:1): initialized
[ 0.998723] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.008663] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.010145] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.010990] 9p: Installing v9fs 9p2000 file system support
[ 1.014191] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.014305] io scheduler noop registered
[ 1.014593] io scheduler cfq registered (default)
[ 1.017329] gic 702f9000.agic: GIC IRQ controller registered
[ 1.020712] iommu: Adding device 702ef000.adsp to group 33
[ 1.029745] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.029898] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.030521] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9a69413
[ 1.030530] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.032207] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.032310] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.032414] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.032604] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.032696] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.032786] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.032879] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.032964] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.033054] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.033136] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.039401] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.041044] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.042990] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.044270] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.044612] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.045802] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.046024] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.046256] Adding domain tsec-pd to PM domain host1x-pd
[ 1.048620] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.049667] tsec 54500000.tsec: initialized
[ 1.051239] tsec 54100000.tsecb: initialized
[ 1.051981] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.055377] nvdec 54480000.nvdec: initialized
[ 1.056434] Adding domain vic03-pd to PM domain host1x-pd
[ 1.056614] Adding domain msenc-pd to PM domain host1x-pd
[ 1.056773] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.060836] falcon 54340000.vic: initialized
[ 1.062033] falcon 544c0000.nvenc: initialized
[ 1.063375] falcon 54380000.nvjpg: initialized
[ 1.067604] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.067680] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.067713] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.067985] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.067988] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.067993] tegra_cec 70015000.tegra_cec: probed
[ 1.068080] display board info: id 0x0, fab 0x0
[ 1.068141] generic_infoframe_type: 0x87
[ 1.068279] tegradc tegradc.0: DT parsed successfully
[ 1.068329] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id=0
[ 1.072243] tegradc tegradc.0: probed
[ 1.072965] Console: switching to colour frame buffer device 80x30
[ 1.073001] tegradc tegradc.0: fb registered
[ 1.074209] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.074302] tegradc tegradc.1: No lt-data, using default setting
[ 1.074333] tegradc tegradc.1: No hpd-gpio in DT
[ 1.074366] tegradc tegradc.1: DT parsed successfully
[ 1.074420] tegradc tegradc.1: Display dc.ffffff800ad40000 registered with id=1
[ 1.076222] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.076394] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.581958] Host read timeout at address 545c00c4
[ 1.583501] tegradc tegradc.1: probed
[ 1.583917] tegradc tegradc.1: fb registered
[ 1.584614] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.585405] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.585412] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.585720] kfuse 7000fc00.kfuse: initialized
[ 1.586647] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.587475] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.587814] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.588469] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.588480] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.588862] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.589275] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.590112] vdd-gpu: applied init 1000000uV constraint
[ 1.590119] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.590461] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.590731] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.592207] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.592243] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.594338] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.594444] No Device Node present for smmu client: serial8250 !!
[ 1.594455] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.594492] iommu: Adding device serial8250 to group 35
[ 1.597035] console [ttyS0] disabled
[ 1.597145] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.600292] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[ 1.601027] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.602478] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.603556] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.605009] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.605015] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.605661] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.607115] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.608564] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.610013] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.610017] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.610663] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.612120] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.613570] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.615019] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.615024] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.615671] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.617120] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.618568] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.620017] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.620021] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.620026] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.620485] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.620490] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.688108] console [ttyS0] enabled
[ 1.689233] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.689563] serial-tegra 70006200.serial: RX in PIO mode
[ 1.689664] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.690686] [drm] Initialized
[ 1.702430] brd: module loaded
[ 1.707815] loop: module loaded
[ 1.707931] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.708044] tegra_profiler: auth: init
[ 1.709402] THERMAL EST: found 2 subdevs
[ 1.709412] THERMAL EST num_resources: 0
[ 1.709419] [THERMAL EST subdev 0]
[ 1.709427] [THERMAL EST subdev 1]
[ 1.709885] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.709888] THERMAL EST: thz register success.
[ 1.710061] THERMAL EST: end of probe, return err: 0
[ 1.711781] sd: No Scsi addr parsed to reserve index
[ 1.711865] hisi_sas: driver version v1.6
[ 1.716929] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.718113] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.718124] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.721173] libphy: Fixed MDIO Bus: probed
[ 1.721974] tun: Universal TUN/TAP device driver, 1.6
[ 1.721979] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.722968] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.722979] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.723088] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.723092] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.723140] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.723144] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.723198] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.723202] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.723246] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.723250] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.724427] PPP generic driver version 2.4.2
[ 1.724627] PPP BSD Compression module registered
[ 1.724634] PPP Deflate Compression module registered
[ 1.724672] PPP MPPE Compression module registered
[ 1.724679] NET: Registered protocol family 24
[ 1.724748] usbcore: registered new interface driver r8152
[ 1.724794] usbcore: registered new interface driver asix
[ 1.724847] usbcore: registered new interface driver ax88179_178a
[ 1.724886] usbcore: registered new interface driver cdc_ether
[ 1.724924] usbcore: registered new interface driver net1080
[ 1.724960] usbcore: registered new interface driver cdc_subset
[ 1.725002] usbcore: registered new interface driver zaurus
[ 1.725063] usbcore: registered new interface driver cdc_ncm
[ 1.725230] VFIO - User Level meta-driver version: 0.3
[ 1.726449] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.726472] ehci-pci: EHCI PCI platform driver
[ 1.726518] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.726530] ohci-pci: OHCI PCI platform driver
[ 1.726569] ohci-platform: OHCI generic platform driver
[ 1.729662] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.730310] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.730943] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.731586] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9123800 id
[ 1.731616] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.733091] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.734553] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.735015] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[ 1.735076] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.735114] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.735898] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.735958] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.736013] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.736158] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.736165] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.736169] usb usb1: Product: xHCI Host Controller
[ 1.736173] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.736177] usb usb1: SerialNumber: 70090000.xusb
[ 1.736876] hub 1-0:1.0: USB hub found
[ 1.736920] hub 1-0:1.0: 5 ports detected
[ 1.737019] usbcore: registered new interface driver uas
[ 1.737107] usbcore: registered new interface driver usb-storage
[ 1.737219] usbcore: registered new interface driver usbserial
[ 1.737956] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.737970] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.738075] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.738164] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.738170] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.738174] usb usb2: Product: xHCI Host Controller
[ 1.738178] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.738181] usb usb2: SerialNumber: 70090000.xusb
[ 1.738717] hub 2-0:1.0: USB hub found
[ 1.738747] hub 2-0:1.0: 4 ports detected
[ 1.739541] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.739547] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.741838] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.742378] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.743580] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.743595] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.744108] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.744409] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.744576] mousedev: PS/2 mouse device common for all mice
[ 1.744687] usbcore: registered new interface driver xpad
[ 1.751570] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.753018] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.754464] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.755543] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.761848] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.770767] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.772216] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.773662] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.775115] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.781397] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.790321] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.791781] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.793236] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.794690] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.800965] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.809237] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.816985] hpd: edid read prepare failed
[ 1.820832] hpd: DC from connected to disconnected
[ 1.839063] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.839392] usb usb2: usb_suspend_both: status 0
[ 1.843491] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.846010] rtc rtc1: alarm rtc device
[ 1.846034] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.846067] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.846762] i2c /dev entries driver
[ 1.848849] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.849223] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.849229] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.850117] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.873459] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.873555] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.881175] imx219 7-0010: board setup failed
[ 1.885613] imx219: probe of 7-0010 failed with error -121
[ 1.886236] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.909528] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.909621] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.917186] imx219 8-0010: board setup failed
[ 1.921620] imx219: probe of 8-0010 failed with error -121
[ 1.923189] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.925706] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.925713] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.926174] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.926191] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.926201] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.926344] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.926355] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.926364] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.926535] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.926548] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.926554] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.926729] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.927624] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.927687] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.927715] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.927733] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.927743] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.928687] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.928709] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.928908] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.928970] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.929413] parse_throttle_dt_data: Num cap clks = 6
[ 1.929420] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.929435] parse_throttle_dt_data: clk=gpu type=4
[ 1.929463] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.929485] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.929508] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.929513] parse_throttle_dt_data: clk=emc type=3
[ 1.929908] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.930020] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.930173] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.931017] FAN dev name: pwm-fan
[ 1.931090] FAN:gpio request success.
[ 1.931148] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.931479] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.931652] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.931664] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.931766] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.931772] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.931778] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.931783] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.931788] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.931793] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.931797] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.931802] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.931807] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.931813] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.934653] device-mapper: uevent: version 1.0.3
[ 1.935170] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.940704] tegra210-cpufreq cpufreq: probe()…completed
[ 1.941433] sdhci: Secure Digital Host Controller Interface driver
[ 1.941435] sdhci: Copyright(c) Pierre Ossman
[ 1.941437] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.941931] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.942286] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.942413] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.946537] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.947138] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.948270] usbcore: registered new interface driver usbhid
[ 1.948272] usbhid: USB HID core driver
[ 1.950401] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.950569] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.952601] nvpmodel: initialized successfully
[ 1.953684] usbcore: registered new interface driver snd-usb-audio
[ 1.953740] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.953745] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.953762] iommu: Adding device snd-soc-dummy to group 36
[ 1.959272] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.970905] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.978179] OPE platform probe
[ 1.978263] OPE platform probe successful
[ 1.978518] OPE platform probe
[ 1.978600] OPE platform probe successful
[ 1.991183] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 2.002660] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.002792] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.002997] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.003130] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.003257] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.003384] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.003512] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.003636] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.003771] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.003896] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.015314] u32 classifier
[ 2.015316] Actions configured
[ 2.015390] Initializing XFRM netlink socket
[ 2.016091] NET: Registered protocol family 10
[ 2.016751] NET: Registered protocol family 17
[ 2.016762] NET: Registered protocol family 15
[ 2.016836] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.016882] Bluetooth: RFCOMM socket layer initialized
[ 2.016892] Bluetooth: RFCOMM ver 1.11
[ 2.016898] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.016902] Bluetooth: HIDP socket layer initialized
[ 2.016936] 9pnet: Installing 9P2000 support
[ 2.016975] Key type dns_resolver registered
[ 2.017376] Registered cp15_barrier emulation handler
[ 2.017383] Registered setend emulation handler
[ 2.018441] registered taskstats version 1
[ 2.018986] Adding domain ve2-pd to PM domain host1x-pd
[ 2.019239] Adding domain ve-pd to PM domain host1x-pd
[ 2.022137] isp 54600000.isp: initialized
[ 2.023523] isp 54680000.isp: initialized
[ 2.033959] last reset is due to power on reset
[ 2.033964] KERNEL: PMC reset status reg: 0x0
[ 2.034025] BL: PMC reset status reg: 0x0
[ 2.034027] BL: PMIC poweroff Event Recorder: 0x40
[ 2.035522] clk_cbus_recalc_rate: no gbus parent
[ 2.035528] clk_cbus_round_rate: no gbus parent
[ 2.035530] clk_cbus_round_rate: no gbus parent
[ 2.035537] clk_cbus_recalc_rate: no gbus parent
[ 2.035636] clk_cbus_recalc_rate: no gbus parent
[ 2.035639] clk_cbus_round_rate: no gbus parent
[ 2.035641] clk_cbus_round_rate: no gbus parent
[ 2.035645] clk_cbus_recalc_rate: no gbus parent
[ 2.036334] tegra_dvfs: GPU-cap: registered
[ 2.036397] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.036400] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 2.036403] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.037800] tegra_dvfs: vdd-gpu-vts: registered
[ 2.038492] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 2.039101] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 2.039585] input: gpio-keys as /devices/gpio-keys/input/input1
[ 2.062959] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.072179] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:12 UTC (946688412)
[ 2.073147] vi 54080000.vi: vi_probe: ++
[ 2.076596] vi 54080000.vi: initialized
[ 2.078658] vi 54080000.vi: subdev nvcsi–2 bound
[ 2.078763] vi 54080000.vi: subdev nvcsi–1 bound
[ 2.080237] Disable partitions left on by BL
[ 2.080240] disb
[ 2.080287] bwmgr: missing cdev-type property
[ 2.080411] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.080418] DRAM derating cdev registered.
[ 2.081271] ALSA device list:
[ 2.081275] #0: tegra-hda at 0x70038000 irq 83
[ 2.081277] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.084403] Freeing unused kernel memory: 8640K
[ 2.092190] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.092196] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.092200] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.092203] usb 1-2: Manufacturer: Generic
[ 2.093102] hub 1-2:1.0: USB hub found
[ 2.093682] hub 1-2:1.0: 4 ports detected
[ 2.099710] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.099715] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.109025] Root device found: mmcblk0p1
[ 2.193753] mmc0: hw tuning done …
[ 2.193800] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.198218] mmcblk0: mmc0:aaaa SC400 367 GiB
[ 2.204001] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.207310] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.239571] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 2.239577] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.239580] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 2.239583] usb 2-1: Manufacturer: Generic
[ 2.243304] hub 2-1:1.0: USB hub found
[ 2.244081] hub 2-1:1.0: 4 ports detected
[ 2.313933] Found dev node: /dev/mmcblk0p1
[ 2.376595] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.378511] Rootfs mounted over mmcblk0p1
[ 2.378928] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.382974] usb 1-2.3: new high-speed USB device number 3 using tegra-xusb
[ 2.394926] usb 2-1: usb_suspend_both: status 0
[ 2.395091] usb usb2: usb_suspend_both: status 0
[ 2.404578] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608
[ 2.404584] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.404587] usb 1-2.3: Product: USB2.0 Hub
[ 2.405551] hub 1-2.3:1.0: USB hub found
[ 2.405834] hub 1-2.3:1.0: 4 ports detected
[ 2.413394] Switching from initrd to actual rootfs
[ 2.630190] systemd[1]: System time before build time, advancing clock.
[ 2.652503] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.665259] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.689311] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.690119] systemd[1]: Detected architecture arm64.
[ 2.695251] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 2.715226] systemd[1]: Set hostname to .
[ 2.716193] usb 2-1.1: New USB device found, idVendor=2676, idProduct=ba02
[ 2.716198] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.716202] usb 2-1.1: Product: acA1920-150um
[ 2.716204] usb 2-1.1: Manufacturer: Basler
[ 2.716207] usb 2-1.1: SerialNumber: 40022036
[ 2.789066] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.790977] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.794935] usb 1-2.3.2: new full-speed USB device number 4 using tegra-xusb
[ 2.818349] usb 1-2.3.2: New USB device found, idVendor=046d, idProduct=c534
[ 2.818355] usb 1-2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.818358] usb 1-2.3.2: Product: USB Receiver
[ 2.818361] usb 1-2.3.2: Manufacturer: Logitech
[ 2.835425] tegradc tegradc.1: blank - powerdown
[ 2.835435] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 2.835438] Extcon DP: HPD disabled
[ 2.835440] hpd: hpd_switch 0
[ 2.835443] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 2.855944] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.855953] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.896230] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.896235] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.896238] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.896242] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.896245] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.896264] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.896322] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.896458] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.896566] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.896589] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.896619] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.896639] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.896773] pci 0000:01:00.0: supports D1 D2
[ 2.896776] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.906998] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.907023] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.907027] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.907033] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.907050] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.907066] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.907073] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.907076] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.907080] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.907323] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.907326] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.907331] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.907411] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.907588] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.907605] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.921991] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.922055] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:3c:f9:e6 from device tree
[ 2.922468] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.922482] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.030126] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.031528] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.031637] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.033437] systemd[1]: Created slice User and Session Slice.
[ 3.033479] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.033500] systemd[1]: Reached target User and Group Name Lookups.
[ 3.034307] systemd[1]: Created slice System Slice.
[ 3.034519] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.113388] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.239810] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.372857] systemd-journald[2018]: Received request to flush runtime journal from PID 1
[ 4.145527] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.0/0003:046D:C534.0001/input/input2
[ 4.203632] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-70090000.xusb-2.3.2/input0
[ 4.206960] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.1/0003:046D:C534.0002/input/input3
[ 4.247170] using random self ethernet address
[ 4.252953] using random host ethernet address
[ 4.267373] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-70090000.xusb-2.3.2/input1
[ 4.333260] random: crng init done
[ 4.336663] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.346944] usb 1-2.3.4: new full-speed USB device number 5 using tegra-xusb
[ 4.372920] usb 1-2.3.4: New USB device found, idVendor=045e, idProduct=0745
[ 4.372927] usb 1-2.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.372932] usb 1-2.3.4: Product: Microsoft® 2.4GHz Transceiver v8.0
[ 4.372937] usb 1-2.3.4: Manufacturer: Microsoft
[ 4.376544] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.0/0003:045E:0745.0003/input/input4
[ 4.435405] hid-generic 0003:045E:0745.0003: input,hidraw2: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-70090000.xusb-2.3.4/input0
[ 4.441755] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.1/0003:045E:0745.0004/input/input5
[ 4.499368] hid-generic 0003:045E:0745.0004: input,hidraw3: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-70090000.xusb-2.3.4/input1
[ 4.515406] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.2/0003:045E:0745.0005/input/input6
[ 4.579205] hid-generic 0003:045E:0745.0005: input,hidraw4: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-70090000.xusb-2.3.4/input2
[ 4.787764] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.787786] cpu-throttle-alert cooling device registered.
[ 4.787917] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.787933] gpu-throttle-alert cooling device registered.
[ 4.788083] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.788095] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.788108] hot-surface-alert cooling device registered.
[ 6.141489] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.142816] eth0: 0xffffff800ab8d000, 48:b0:2d:3c:f9:e6, IRQ 407
[ 6.199511] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.383945] Mass Storage Function, version: 2009/09/11
[ 6.383952] LUN: removable file: (no medium)
[ 6.390211] using random self ethernet address
[ 6.398947] using random host ethernet address
[ 6.508691] rndis0: HOST MAC c2:fb:1a:cd:87:08
[ 6.513226] rndis0: MAC c2:fb:1a:cd:87:09
[ 6.515799] usb0: HOST MAC c2:fb:1a:cd:87:0a
[ 6.515832] usb0: MAC c2:fb:1a:cd:87:0b
[ 6.515854] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 6.516622] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 6.516642] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.516672] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 6.516896] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 6.516919] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 6.517444] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 6.517455] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 6.517687] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 6.521815] l4tbr0: port 1(rndis0) entered blocking state
[ 6.521820] l4tbr0: port 1(rndis0) entered disabled state
[ 6.521994] device rndis0 entered promiscuous mode
[ 6.527185] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.532863] l4tbr0: port 2(usb0) entered blocking state
[ 6.532868] l4tbr0: port 2(usb0) entered disabled state
[ 6.552015] device usb0 entered promiscuous mode
[ 6.557881] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.223595] zram: Added device: zram0
[ 7.224243] zram: Added device: zram1
[ 7.225484] zram: Added device: zram2
[ 7.225913] zram: Added device: zram3
[ 7.251214] zram0: detected capacity change from 0 to 1048576000
[ 7.594017] Adding 1023996k swap on /dev/zram0. Priority:5 extents:1 across:1023996k SS
[ 7.600827] zram1: detected capacity change from 0 to 1048576000
[ 7.613556] Adding 1023996k swap on /dev/zram1. Priority:5 extents:1 across:1023996k SS
[ 7.619046] zram2: detected capacity change from 0 to 1048576000
[ 7.629477] Adding 1023996k swap on /dev/zram2. Priority:5 extents:1 across:1023996k SS
[ 7.635501] zram3: detected capacity change from 0 to 1048576000
[ 7.647375] Adding 1023996k swap on /dev/zram3. Priority:5 extents:1 across:1023996k SS
[ 8.242928] r8168: eth0: link up
[ 8.242984] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.036170] tegradc tegradc.0: blank - powerdown
[ 10.036178] tegradc tegradc.1: blank - powerdown
[ 10.682545] Bridge firewalling registered
[ 10.712093] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 11.017188] Netfilter messages via NETLINK v0.30.
[ 11.022388] ctnetlink v0.93: registering with nfnetlink.
[ 11.249473] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 12.593470] fuse init (API version 7.26)
[ 12.670123] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.092882] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.092893] Bluetooth: BNEP socket layer initialized
[ 33.909615] vdd-fan: disabling
[ 33.909660] vdd-usb-vbus: disabling
[ 33.909693] vdd-usb-vbus2: disabling
[ 33.909797] vddio-sdmmc3-ap: disabling
[ 33.910509] avdd-io-edp-1v05: disabling
[ 33.910543] vdd-usb-hub-en: disabling
