Dear nvidia-Team,
I am having problems accessing a dwImageCUDA’s data in RGBA_UINT8 pitch configuration. The problem does not occur with RAW_UINT16.
I am aware that I cannot access the data from host directly, but copying any data from dptr[0] does not work, neither by cudaMemcpy (as it works for the RAW_UINT16 case) nor by cudaMemcpy2D, neither to device nor host. Both give error 700, which is Illegal Memory Access. It does not matter if I try for a subspace of the data or even only the first byte.
The image gotten from the camera gives all the right infos as far as I can see.
Format: 1012 (RGBA_UINT8)
Dimensions 1920x1208
Memory type 1 (Pitch)
Image type 2 (CUDA)
Element size 1
Number of Planes 1
Channels 4
Plane size 1920x1208
Pitch[0]: 7680
dptr[0] has a value, the others do not, neither does array[0]
Copying the data from RAW_UINT16 works with
the call
cudaMemcpy(dst, frame->dptr[0], 1920x1208x2, cudaMemcpyDeviceToX),
but not for RGBA_UINT8 with e.g.
cudaMemcpy(dst, frame->dptr[0], 1920x1208x4, cudaMemcpyDeviceToX) or
cudaMemcpy2D(dst, dstPitch, frame->dptr[0], frame->pitch[0], 1920x1208x4, cudaMemcpyDeviceToX)
I also tried dwImageStreamer as a converison tool to dwImageCPU (just for test purposes), but it crashes on the producerSend step without an error message.
I am starting the camera with the following parameter string:
output-format=yuv,isp-mode=yuv444-uint8,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,slave=0,camera-mask=1000,camera-count=4,mode=mailbox
RAW_UINT16 has the following changes:
output-format=raw+data,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,slave=0,camera-mask=1000,camera-count=4,mode=mailbox
Alternatively, I would also be happy with a performant transformation of the raw uint16 image to rgba_uint8, though I think having the driveworks function taking that processing step directly when grabbing the frame should be the most optimal path.
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.0.8846
other
Host Machine Version
native Ubuntu 18.04
other
