I have a GeForce GTX 750 Ti and want to do Dynamic Parallelism with it ; however, when my code runs, NSight desactivates breakpoints due to preemption mode.
I desactivated preemption mode, it still didn’t work, and I figured out I should make my GPU headless.
The problem is, I don’t have the needed second GPU, and my motherboard doesn’t support two GPUs at the same time anyway.
My questions are :
What kind of GPU can I use to display, alongside the headless 750 Ti ?
If you cannot install two GPUs in the system and you want to debug a CUDA application using CUDA Dynamic Parallelism you will likely have to run Nsight VSE on a second computer and remote debug the system with the 750Ti.
