we met a problem in out application with dynamic stream addition/removal, here is our pipiline structure:
{…,live_stream_i,…}—>nvstreammux—>pgie–>nvtracker–>nvstreamdemux–> {…,output_stream_i,…}–> etc_i
different from the exmaple https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete, besides uridecodebin, there are also dynamic del/add of GSTelements after nvstreamdemux of pipeline in each stream. our problem is:
removal of stream was ok, but after addition of stream, the stream just played for a while(several seconds), then stoped. once removal of a running stream and addition of next stream (played for a while then stoped ), the stoped stream recovered. and the problem only occured in rtmp live source, while rtsp is ok.
could you give me some advices? thanks!
