Hi Guys,
On TX2 it was very easy to add kernel boot parameters through extlinux.conf file. On Xavier, how I can do it, which exactly file to modify and how to update it?
Hi Guys,
The boot structure is still evolving on the Xavier, and currently you need to use the flash.sh script to add kernel or device tree. Exact details may change depending on which release, but see the official docs for R31.1. Right now the kernel and device tree are in partitions, and U-Boot is not currently used (this doesn’t mean it won’t be added back in, but for now CBoot does the work which is why the flash tool is required).
FYI, cloning a backup is your friend if you worry, and some operations replace the rootfs, so it is better to worry a little bit.
To follow up on this, how would one change kernel boot options?
For my use-case I would like to add “usbcore.usbfs_memory_mb=1000” to the boot line to support a particular high speed camera. Do I need to re-flash my Xavier to accomplish this? Any pointers on which file I would need to edit on the host prior to re-flashing?
This was exactly my question, I aslo need to add a couple of kernel boot parameters. On TX2 it was extlinux.conf (APPEND …). On Xavier, which file is holding kernel boot parameters? I already understood that we will need to burn kernel or DTB but which file to modify?
May I suggest a way? Here are steps which should work -
dtc
command as below:dtc
command again to build dtb file:Thank you Anish,
Sounds like a plan, I will try and update.
Hi Anish,
This doesn’t work for me. First of all, after trying to convert to DTS, I got a lot of warnings:
root@jetson-0423418049130:/home/nvidia# dtc -I fs -O dts -o /tmp/devicetree.dts /sys/firmware/devicetree/base
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /aconnect@2a41000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /aconnect@2a41000/ahub has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /aconnect@2a41000/ahub/ope@2908000/peq@2908100 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /aconnect@2a41000/ahub/ope@2908000/mbdrc@2908200 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /reserved-memory/grid-of-semaphores has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /aon@c000000/ivc-channels@80000000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /bpmp_i2c/spmic@3c/pinmux@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /bpmp_i2c/spmic@3c/fps/fps0 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /bpmp_i2c/spmic@3c/fps/fps1 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /bpmp_i2c/spmic@3c/fps/fps2 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /shuntv-offset/conditional_offset@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@2/eeprom@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@2/eeprom@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@0/eeprom@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@0/eeprom@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@1/eeprom@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@1/eeprom@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@1/eeprom@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /tegra-cvnas has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /camera-ivc-channels/dbg@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /camera-ivc-channels/echo@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /camera-ivc-channels/ivccapture@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /camera-ivc-channels/dbg@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /camera-ivc-channels/ivccontrol@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /e3333_lens_ov5693@P5V27C has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragemen-tegra-wdt-dis/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-rp/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-rp/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-rp/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3377@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3326@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-p2822-B00/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-p2822-B00/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-p2822-B00/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement-soft-wdt/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2/overrides@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2/overrides@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-isp/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@71 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3331@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c1-rp/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888-mods/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888-mods/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-cv/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/pwm-fan-polarity/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/pwm-fan-polarity/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-dla/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-dla/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@18 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@26 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@16 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@24 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@22 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@20 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@19 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@27 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@17 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@25 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@23 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx390@0/override@21 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2822-cam0-rst@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-tegra-ufs-lane10/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/ufs-cd/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/usb-vbus-en0-gpio-value/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1/overrides@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1/overrides@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-disable-uphy-rx-idle/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@16 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement-tegra-wdt-en/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@68 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@58 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@48 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@38 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@66 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@28 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@56 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@18 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@46 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@36 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@64 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@26 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@54 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@16 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@44 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@72 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@34 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@62 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@24 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@52 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@42 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@70 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@32 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@60 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@22 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@50 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@40 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@69 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@30 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@59 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@20 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@49 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@39 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@67 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@29 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@57 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@19 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@47 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@37 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@65 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@27 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@55 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@17 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@45 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@73 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@35 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@63 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@25 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@53 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@43 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@71 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@33 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@61 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@23 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@51 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@41 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@31 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e3333@0/override@21 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-pva/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-pva/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx185@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-p2888@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@18 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@26 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@16 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@24 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@14 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@22 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@12 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@20 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@19 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@17 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@25 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@15 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@23 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@13 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-imx274-dual@0/override@21 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-nvenc/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-fs-disable-nvenc/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-ep/override@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-ep/override@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-pcie-c5-ep/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement-pmic-wdt-en/override@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /combined-uart has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /thermal-zones/Tdiode_tegra/trips/eqos-m40@-40000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /thermal-zones/Tdiode_tegra/trips/eqos-p30@30000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /thermal-zones/Tdiode_tegra/trips/eqos-p100@100000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /thermal-zones/Tdiode_tegra/trips/eqos-p65@65000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /thermal-zones/Tdiode_tegra/trips/eqos-m5@-5000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /bpmp has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /tegra_nvlink_controller has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/pva1 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/dpaux@155F0000/pinmux@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/vi-thi@15f00000 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/sor3 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/sor1 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/dc_common has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/tegra_cec has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/sor has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/pva0 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@4/ports/port@1/endpoint@9 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@4/ports/port@0/endpoint@8 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@2/ports/port@1/endpoint@5 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@2/ports/port@0/endpoint@4 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@0/ports/port@1/endpoint@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@0/ports/port@0/endpoint@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@5/ports/port@1/endpoint@11 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@5/ports/port@0/endpoint@10 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@3/ports/port@1/endpoint@7 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@3/ports/port@0/endpoint@6 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@1/ports/port@1/endpoint@3 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi@15a00000/channel@1/ports/port@0/endpoint@2 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/sor2 has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/slvs-ec@15ac0000/streams/stream@0/ports/port@1/endpoint@1 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /host1x/slvs-ec@15ac0000/streams/stream@0/ports/port@0/endpoint@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /tegra_hv_xhci_debug@0 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /mc has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /e3326_lens_ov5693@P5V27C has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /gv11b has a reg or ranges property, but no unit name
/tmp/devicetree.dts: Warning (unit_address_vs_reg): Node /lens_imx274@A6V26 has a unit name, but no reg property
/tmp/devicetree.dts: Warning (unit_address_format): Node /miscreg@00100000 unit name should not have leading 0s
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@141a0000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@14100000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@14140000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@14180000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@14120000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (pci_device_reg): Node /pcie@14160000/prod-settings missing PCI reg property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03eb0000 simple-bus unit address format error, expected "3eb0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03ef0000 simple-bus unit address format error, expected "3ef0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03f10000 simple-bus unit address format error, expected "3f10000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03ec0000 simple-bus unit address format error, expected "3ec0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03f20000 simple-bus unit address format error, expected "3f20000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03ed0000 simple-bus unit address format error, expected "3ed0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03ee0000 simple-bus unit address format error, expected "3ee0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /nvhs_p2u/p2u@03f00000 simple-bus unit address format error, expected "3f00000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /mods-simple-bus/mods-clocks missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@200 simple-bus unit address format error, expected "c8"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@106 simple-bus unit address format error, expected "6a"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@114 simple-bus unit address format error, expected "72"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@104 simple-bus unit address format error, expected "68"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@112 simple-bus unit address format error, expected "70"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@102 simple-bus unit address format error, expected "66"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@110 simple-bus unit address format error, expected "6e"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@109 simple-bus unit address format error, expected "6d"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@107 simple-bus unit address format error, expected "6b"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@105 simple-bus unit address format error, expected "69"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@113 simple-bus unit address format error, expected "71"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@111 simple-bus unit address format error, expected "6f"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@101 simple-bus unit address format error, expected "65"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /fixed-regulators/regulator@108 simple-bus unit address format error, expected "6c"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/prod-settings missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/pva1 simple-bus unit address format error, expected "16800000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx3 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/dpaux@155F0000 simple-bus unit address format error, expected "155f0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx1 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/vi-thi@15f00000 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/sor3 simple-bus unit address format error, expected "15bc0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/sor1 simple-bus unit address format error, expected "15b40000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/dc_common simple-bus unit address format error, expected "15200000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/tegra_cec simple-bus unit address format error, expected "3960000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx6 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx4 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/sor simple-bus unit address format error, expected "15b00000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/dpaux@155D0000 simple-bus unit address format error, expected "155d0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/pva0 simple-bus unit address format error, expected "16000000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx2 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx0 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/sor2 simple-bus unit address format error, expected "15b80000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/disp_imp_table missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/dpaux@155E0000 simple-bus unit address format error, expected "155e0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx7 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /host1x/ctx5 missing or empty reg/ranges property
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e40000 simple-bus unit address format error, expected "3e40000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e80000 simple-bus unit address format error, expected "3e80000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e10000 simple-bus unit address format error, expected "3e10000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e50000 simple-bus unit address format error, expected "3e50000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e90000 simple-bus unit address format error, expected "3e90000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e20000 simple-bus unit address format error, expected "3e20000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e60000 simple-bus unit address format error, expected "3e60000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03f30000 simple-bus unit address format error, expected "3f30000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03ea0000 simple-bus unit address format error, expected "3ea0000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e30000 simple-bus unit address format error, expected "3e30000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03e70000 simple-bus unit address format error, expected "3e70000"
/tmp/devicetree.dts: Warning (simple_bus_reg): Node /hsio_p2u/p2u@03f40000 simple-bus unit address format error, expected "3f40000"
/tmp/devicetree.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /host1x/dpaux@155F0000/pinmux@0 or bad phandle (referred from /plugin-manager/fragment-p2822-cam0-rst@0/override@1/_overlay_:gpios[0])
/tmp/devicetree.dts: Warning (gpios_property): Missing property '#gpio-cells' in node /host1x/dpaux@155F0000/pinmux@0 or bad phandle (referred from /plugin-manager/fragment-p2822-cam0-rst@0/override@0/_overlay_:gpios[0])
Then it looks like it flash successful, bit boot is hangs on:
tegra-xusb 3610000.xhci: cannnot find firmware....retrying after 1 second
Ok, I tired to search for correct DTB/DTS, I just added my parameters to “flash.sh” script. It worked.
Is there a way to change the kernel paramaters without recompiling the device tree? I just want to change the consoleblank timeout value persistently.
When U-Boot was running this was not too difficult. Without U-Boot you are probably limited to the device tree, or perhaps an echo to the right location for the specific driver in “/sys” (in other words, “probably not, but if you are ambitious, maybe”).
EDIT: Some boot related settings which are in “/proc/sys/” can simply be added to “/etc/sysctl.conf”.
