I am using auvidea jn30a with jetson nano dev module, I connected two raspberry pi cameras to the auvidea ports, but only one i recieve output from
i checked “ls /dev/video*” and it gives only “/dev/video0”
what should i do to get the two cameras working together ?
imx219.zip (45.1 KB)
You need to check the device tree to confirm it have 2 sensors support.
How to check the device tree?
Please also note that the two cameras are working in the same port if I switched between them, they are both the same sensor
Raspberry Pi camera v2.1
sensor IMX219 which is supported by jetson nano
sudo apt-get update
sudo apt-get install device-tree-compiler
sudo dtc -I fs -O dts -o imx219.dts /proc/device-tree
Check the modules in the tegra-camera-platform
I got this results
imx219.dts: Warning (unit_address_vs_reg): Node /reserved-memory/fb0_carveout has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /reserved-memory/ramoops_carveout has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /reserved-memory/fb1_carveout has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /reserved-memory/iram-carveout has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /ptm has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/admaif@0x702d0000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/amx@702d3100 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7300 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/i2s@702d1000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/iqc@702de000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/i2s@702d1300 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/dmic@702d4200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/adx@702d3900 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/mvc@702da000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/sfc@702d2400 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/amx@702d3000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7500 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/i2s@702d1200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/dmic@702d4100 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/amixer@702dbb00 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/sfc@702d2000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/ope@702d8400 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/adx@702d3800 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/iqc@702de200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/mvc@702da200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/sfc@702d2600 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7100 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/ope@702d8000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7400 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/i2s@702d1100 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/dmic@702d4000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/i2s@702d1400 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/sfc@702d2200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/spkprot@702d8c00 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /ahub/afc@702d7000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /clock has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /lens_imx219@RBPCV2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /gpu has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csie has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csic has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csia has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csif has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csid has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /camera-pcl/dpd/csib has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /adma@702e2000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /usb_cd has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /eeprom-manager/bus@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /tegra_cec has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/throttle_dev@gpu_high has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/throttle@critical has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/fuse_war@fuse_rev_0_1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/throttle@heavy has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/throttle_dev@cpu_high has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /soctherm@0x700E2000/fuse_war@fuse_rev_2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /chosen/plugin-manager/ids/connection/i2c@7000c500 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /chosen/plugin-manager/ids/connection/i2c@7000c500/module@0x50 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub/ope@702d8400/mbdrc@702d8600 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub/ope@702d8400/peq@702d8500 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub/mvc@0x702da200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub/ope@702d8000/mbdrc@702d8200 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/ahub/ope@702d8000/peq@702d8100 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /aconnect@702c0000/adsp has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@5 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@5/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@5/override@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@5/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@8 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@8/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@3/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@3/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@6 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@6/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@1/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-b00@2/overrides@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-pins@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-pins@3/overrides@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@0/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@0/override@0/overlay/channel@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@0/override@0/overlay/channel@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@11 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@8 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@6 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@14 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@4 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@12 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@10 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@9 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@7 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@15 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@5 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@13 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@9/override@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@8 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@6 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@10 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@4 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/override@12 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@9 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@7 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@11 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-common@0/overrides@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@4 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@4/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@4/override@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@4/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment-e2614-a00@1/overrides@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@7 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@7/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@2/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@2/override@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragment@2/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@11 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@28 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@18 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@8 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@26 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@16 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@6 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@24 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@14 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@4 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@22 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@12 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@30 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@20 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@10 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@29 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@19 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@9 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@27 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@17 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@7 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@25 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@15 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@5 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@23 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@13 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@31 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /plugin-manager/fragement@10/override@21 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /sata@70020000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /external-memory-controller@7001b000/emc-table@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /external-memory-controller@7001b000/emc-table@0/emc-table@1600000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /external-memory-controller@7001b000/emc-table@0/emc-table@204000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /external-memory-controller@7001b000/emc-table@0/emc-table-derated@204000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /external-memory-controller@7001b000/emc-table@0/emc-table-derated@1600000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi/channel@0/ports/port@1/endpoint@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi/channel@0/ports/port@0/endpoint@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi/channel@1/ports/port@3/endpoint@3 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvcsi/channel@1/ports/port@2/endpoint@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvjpg has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/dsi has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/dpaux has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/tsec has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/sor1 has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvenc has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/sor has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/sor/dp-display/dp-lt-settings/lt-setting@2 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/sor/dp-display/dp-lt-settings/lt-setting@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/sor/dp-display/dp-lt-settings/lt-setting@1 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/vic has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/vi has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/dpaux1 has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/tsecb has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /host1x/nvdec has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000c500/battery-charger@6b has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /mc has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /mipical has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000d000/max77620@3c/pinmux@0 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000d000/max77620@3c/fps/fps0 has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000d000/max77620@3c/fps/fps1 has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000d000/max77620@3c/fps/fps2 has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /iommu has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /dfll-max77621@70110000 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /rtc has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /interrupt-controller has a reg or ranges property, but no unit name
imx219.dts: Warning (unit_address_vs_reg): Node /i2c@7000c400/iqs263@44 has a unit name, but no reg property
imx219.dts: Warning (unit_address_vs_reg): Node /mselect has a reg or ranges property, but no unit name
imx219.dts: Warning (pci_bridge): Node /pcie@1003000/pci@2,0 missing bus-range for PCI bridge
imx219.dts: Warning (pci_bridge): Node /pcie@1003000/pci@1,0 missing bus-range for PCI bridge
imx219.dts: Warning (unit_address_format): Failed prerequisite ‘pci_bridge’
imx219.dts: Warning (pci_device_reg): Failed prerequisite ‘pci_bridge’
imx219.dts: Warning (pci_device_bus_num): Failed prerequisite ‘pci_bridge’
imx219.dts: Warning (simple_bus_reg): Node /extcon/disp-state missing or empty reg/ranges property
imx219.dts: Warning (simple_bus_reg): Node /mods-simple-bus/mods-clocks missing or empty reg/ranges property
imx219.dts: Warning (simple_bus_reg): Node /host1x/nvcsi missing or empty reg/ranges property
imx219.dts: Warning (simple_bus_reg): Node /host1x/nvjpg simple-bus unit address format error, expected “54380000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/dsi simple-bus unit address format error, expected “54300000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/dpaux simple-bus unit address format error, expected “545c0000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/tsec simple-bus unit address format error, expected “54500000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/sor1 simple-bus unit address format error, expected “54580000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/nvenc simple-bus unit address format error, expected “544c0000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/sor simple-bus unit address format error, expected “54540000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/vic simple-bus unit address format error, expected “54340000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/vi-bypass missing or empty reg/ranges property
imx219.dts: Warning (simple_bus_reg): Node /host1x/vi simple-bus unit address format error, expected “54080000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/vi/ports missing or empty reg/ranges property
imx219.dts: Warning (simple_bus_reg): Node /host1x/dpaux1 simple-bus unit address format error, expected “54040000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/tsecb simple-bus unit address format error, expected “54100000”
imx219.dts: Warning (simple_bus_reg): Node /host1x/nvdec simple-bus unit address format error, expected “54480000”
imx219.dts: Warning (simple_bus_reg): Node /regulators/regulator@10 simple-bus unit address format error, expected “a”
imx219.dts: Warning (gpios_property): property ‘gpio’ size (15) is invalid, expected multiple of 4 in node /symbols
imx219.dts: Warning (gpios_property): Missing property ‘#gpio-cells’ in node /thermal-zones/AO-therm/trips/gpu-scaling5 or bad phandle (referred from /plugin-manager/fragment-e2614-pins@3/overrides@0/overlay:gpios[0])
Attached the dts file should be good to check.
Sorry I can’t understand you correctly do you mean “should I attach the dts files here ?” if yes where can I find this files? , sorry I am not familiar with the dts stuff of nano.
This command gen the imx219.dts file.
please check the .dts file is attached now to the topic.
Could you try to add the status = “okay” to the module1 like module0 to try.
Also check the dmesg | grep -i imx219 to check if any error.
Should I update this in the generated file then type “dmesg | grep -i imx219” only ?
I mean after boot to Ubuntu check the kernel message to check if two imx219 probe well or not.
Sorry but i can’t get how to do this, what do you mean by " Could you try to add the status = “okay” "?
do you mean to modify this in the imx219.dts generated file then reboot ? if this is the way will this modify it in the jetson driver for imx219 sensor to load 2 cameras ?
sorry if I can’t get what you meant exactly but I need more detailed steps please.
What I mean is modify the device tree of the kernel source and build the new dtb to flash the device to try.
Have a reference to below link to know the detail. And did you check the kernel message to check the imx219 probe inforation?
