Thanks for the quick reply,
I wrote wrong info in the first message since i wrote it late last night from home,
Now i am at work and can elaborate more.
I have an jetson evm version: DAAF-A02
And the the evm module version: DAAA-A02
I have production modules version: DAAA-B01
So the production modules can not fit in this EVM version.
I downloaded JetPack_4.2.2_Linux_GA_P3448 and compiled it without change, no problem
I have used the following command in order to program the EVM module:
./flash.sh jetson-nano-qspi-sd internal
Everything programs Ok, I can see during the programming that the SDK has selected the following DTB:
tegra210-p3448-0000-p3449-0000-a02.dtb
I have the Imx219 disconnected from the the board on purpose and when I boot i can see it attempting to probe the IMX219:
Starting kernel …
[ 1.028385] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.539696] Host read timeout at address 545c00c4
[ 2.724679] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.655792] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.674684] imx219 6-0010: board setup failed
[ 4.762144] using random self ethernet address
[ 4.767258] using random host ethernet address
[ 4.818360] using random self ethernet address
[ 4.822899] using random host ethernet address
I have also programmed the production modules using our hardware that is almost identical to the EVM,
I have used the following command to program the production module:
./flash.sh jetson-nano-emmc internal
tegra210-p3448-0002-p3449-0000-b00.dtb
I have the Imx219 disconnected from the the board on purpose and when I boot i can see it attempting to probe the Dual IMX219 not the Single IMX219:
Starting kernel …
[ 1.039378] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.550734] Host read timeout at address 545c00c4
[ 2.354594] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.138696] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.153787] imx219 7-0010: board setup failed
[ 3.191149] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.205631] imx219 8-0010: board setup failed
[ 3.555653] using random self ethernet address
[ 3.560139] using random host ethernet address
[ 3.623505] using random self ethernet address
[ 3.628090] using random host ethernet address
[ 3.648823] random: crng init done
[ 3.652230] random: 7 urandom warning(s) missed due to ratelimiting
How can this be ? i thought that they should behave the same, i.e. it should attempt to detect the single camera on the production module also and not the Dual camera.
How can i make it attempt to probe the single camera and not the dual camera ?
Amir
