ECID read failed
Is this could work?
didnt work
After check your log further, could you try one of options
  1. access into the system and run below commands
    # In the Orin NX device
    nvbootctrl get-current-slot
    # if slot is 1
    sudo nvbootctrl set-active-boot-slot 0
    • Put the device in recovery mode again.
    • Run the sdk manager.
  2. The other method is to short REC/GND manually and run the sdk manager again.
I cant access the system. After connecting with minicon, I cannot write or execute any command. I able to type after configuring minicom to echo keyboard.
Welcome to minicom 2.9
OPTIONS: I18n
Port /dev/ttyUSB0, 10:30:02
Press CTRL-A Z for help on special keys
[0000.065] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x0, rst_level: 0x0
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.110] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.156] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.166] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU type
[0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.198] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.202] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.232] I> FUSE_SKU_INFO_0 = 0xd3
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.243] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.253] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.259] I> BPMP NAFLL lock success.
[0000.262] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.267] I> Initializing PLLC2 for AXI_CBB.
[0000.271] I> AXI_CBB : src = 35, divisor = 0
[0000.275] I> Task: Voltage monitor
[0000.278] I> VMON: Vmon re-calibration and fine tuning done
[0000.284] I> Task: UPHY init
[0000.288] I> HSIO UPHY init done
[0000.291] W> Skipping GBE UPHY config
[0000.295] I> Task: Boot device init
[0000.298] I> Boot_device: QSPI_FLASH instance: 0
[0000.303] I> Qspi clock source : pllc_out0
[0000.307] I> QSPI Flash: Macronix 64MB
[0000.311] I> QSPI-0l initialized successfully
[0000.315] I> Task: TSC init
[0000.318] I> Task: Load membct
[0000.321] I> RAM_CODE 0x4000411
[0000.324] I> Loading MEMBCT
[0000.326] I> Slot: 0
[0000.328] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.334] I> Binary name: MEM-BCT-0
[0000.337] I> Size of crypto header is 8192
[0000.341] I> Size of crypto header is 8192
[0000.345] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.351] I> BCH of MEM-BCT-0 read from storage
[0000.356] I> BCH address is : 0x40050000
[0000.360] I> MEM-BCT-0 header integrity check is success
[0000.365] I> Binary magic in BCH component 0 is MEM0
[0000.370] I> component binary type is 0
[0000.373] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.380] I> MEM-BCT-0 binary is read from storage
[0000.385] I> MEM-BCT-0 binary integrity check is success
[0000.390] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.397] I> RAM_CODE 0x4000411
[0000.402] I> RAM_CODE 0x4000411
[0000.406] I> Task: Load Page retirement list
[0000.410] I> Task: SDRAM params override
[0000.414] I> Task: Save mem-bct info
[0000.417] I> Task: Carveout allocate
[0000.421] I> RCM blob carveout will not be allocated
[0000.426] I> Update CCPLEX IST carveout from MB1-BCT
[0000.430] I> ECC region[0]: Start:0x0, End:0x0
[0000.435] I> ECC region[1]: Start:0x0, End:0x0
[0000.439] I> ECC region[2]: Start:0x0, End:0x0
[0000.443] I> ECC region[3]: Start:0x0, End:0x0
[0000.447] I> ECC region[4]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.458] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.462] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.467] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.472] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.482] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.489] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.496] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.503] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.510] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.518] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.525] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.532] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.539] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.546] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.553] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.559] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.566] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.573] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.580] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.587] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.629] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.636] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.643] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.650] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.656] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.663] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.670] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.677] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.684] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.691] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.697] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.704] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.711] I> Task: Thermal check
[0000.714] I> Using min_chip_limit as min_tmon_limit
[0000.719] I> Using max_chip_limit as max_tmon_limit
[0000.723] I> BCT max_tmon_limit = 105
[0000.727] I> BCT min_tmon_limit = -28
[0000.730] I> BCT max_tmon_limit = 105
[0000.734] I> BCT min_tmon_limit = -28
[0000.737] I> SKU specific max_chip_limit = 105
[0000.742] I> SKU specific min_chip_limit = -28
[0000.746] I> BCT max_chip_limit = 105
[0000.749] I> BCT min_chip_limit = -28
[0000.753] I> enable_soctherm_polling = 0
[0000.757] I> max temp read = 33
[0000.760] I> min temp read = 32
[0000.763] I> Enabling thermtrip
[0000.766] I> Task: Update FSI SCR with thermal fuse data
[0000.771] I> Task: Enable WDT 5th expiry
[0000.774] I> Task: I2C register
[0000.777] I> Task: Set I2C bus freq
[0000.781] I> Task: Reset FSI
[0000.783] I> Task: Pinmux init
[0000.787] I> skipped mmio_addr = 0x9240008
[0000.791] I> skipped mmio_addr = 0x9240000
[0000.795] I> skipped mmio_addr = 0x9240010
[0000.799] I> skipped mmio_addr = 0x9240018
[0000.802] I> skipped mmio_addr = 0x9240020
[0000.806] I> skipped mmio_addr = 0x9240030
[0000.810] I> skipped mmio_addr = 0x9240028
[0000.814] I> skipped mmio_addr = 0x9240038
[0000.818] I> skipped mmio_addr = 0x9240040
[0000.822] I> skipped mmio_addr = 0x9240048
[0000.826] I> skipped mmio_addr = 0x9241000
[0000.830] I> skipped mmio_addr = 0x9241008
[0000.834] I> skipped mmio_addr = 0x9241010
[0000.838] I> skipped mmio_addr = 0x9241018
[0000.842] I> skipped mmio_addr = 0x9241020
[0000.846] I> skipped mmio_addr = 0x9241028
[0000.850] I> skipped mmio_addr = 0x9241030
[0000.854] I> skipped mmio_addr = 0x9241038
[0000.858] I> skipped mmio_addr = 0x9241040
[0000.862] I> skipped mmio_addr = 0x9242000
[0000.866] I> skipped mmio_addr = 0x9242008
[0000.869] I> Task: Prod config init
[0000.873] I> Task: Pad voltage init
[0000.876] I> Task: Prod init
[0000.879] I> Task: Program rst req config reg
[0000.883] I> Task: Common rail init
[0000.887] I> DONE: Thermal config
[0000.890] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.898] I> DONE: SOC rail config
[0000.902] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.908] I> DONE: MEMIO rail config
[0000.912] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.918] I> DONE: GPU rail info
[0000.922] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.928] I> DONE: CV rail info
[0000.931] I> Task: Mem clock src
[0000.934] I> Task: Misc. board config
[0000.938] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.944] I> Task: SDRAM init
[0000.947] I> MemoryType: 4 MemBctRevision: 2
[0000.954] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0000.961] I> MSS CAR: Init PLLM
[0000.964] I> MSS CAR: Init PLLHUB
[0000.969] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.980] I> SDRAM initialized!
[0000.983] I> SDRAM Size in Total 0x400000000
[0000.987] I> Task: Dram Ecc scrub
[0000.990] I> Task: DRAM alias check
[0000.997] I> Task: Program NSDRAM carveout
[0001.001] I> NSDRAM carveout encryption is enabled
[0001.006] I> Program NSDRAM carveout
[0001.009] I> Task: Register checker
[0001.013] I> Task: Enable clock-mon
[0001.017] I> FMON: Fmon re-programming done
[0001.021] I> Task: Mapper init
[0001.024] I> Task: SC7 Context Init
[0001.027] I> Task: CCPLEX IST init
[0001.030] I> Task: CPU WP0
[0001.033] I> Loading MCE
[0001.035] I> Slot: 0
[0001.037] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.043] I> Binary name: MCE
[0001.046] I> Size of crypto header is 8192
[0001.050] I> Size of crypto header is 8192
[0001.053] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.060] I> BCH of MCE read from storage
[0001.064] I> BCH address is : 0x4003e000
[0001.068] I> MCE header integrity check is success
[0001.072] I> Binary magic in BCH component 0 is MTSM
[0001.077] I> component binary type is 8
[0001.081] I> Size of crypto header is 8192
[0001.085] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.093] I> MCE binary is read from storage
[0001.097] I> MCE binary integrity check is success
[0001.102] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.108] I> Size of crypto header is 8192
[0001.119] I> Size of crypto header is 8192
[0001.123] I> Sending WP0 mailbox command to PSC
[0001.132] I> Task: XUSB Powergate
[0001.135] I> Skipping powergate XUSB.
[0001.139] I> Task: MB1 fixed firewalls
[0001.145] W> Firewall readback mismatch
[0001.150] I> Task: Load bpmp-fw
[0001.153] I> Slot: 0
[0001.155] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.161] I> Binary name: BPMP_FW
[0001.164] I> Size of crypto header is 8192
[0001.168] I> Size of crypto header is 8192
[0001.172] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.178] I> BCH of BPMP_FW read from storage
[0001.182] I> BCH address is : 0x807fe000
[0001.186] I> BPMP_FW header integrity check is success
[0001.191] I> Binary magic in BCH component 0 is BPMF
[0001.196] I> component binary type is 15
[0001.200] I> Size of crypto header is 8192
[0001.203] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.221] I> BPMP_FW binary is read from storage
[0001.227] I> BPMP_FW binary integrity check is success
[0001.232] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.239] I> Slot: 0
[0001.241] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.247] I> Binary name: BPMP_FW_DTB
[0001.250] I> Size of crypto header is 8192
[0001.254] I> Size of crypto header is 8192
[0001.258] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.264] I> BCH of BPMP_FW_DTB read from storage
[0001.269] I> BCH address is : 0x807fc000
[0001.273] I> BPMP_FW_DTB header integrity check is success
[0001.278] I> Binary magic in BCH component 0 is BPMD
[0001.283] I> component binary type is 16
[0001.286] I> Size of crypto header is 8192
[0001.290] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.301] I> BPMP_FW_DTB binary is read from storage
[0001.306] I> BPMP_FW_DTB binary integrity check is success
[0001.312] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.319] I> Task: BPMP fw ast config
[0001.322] I> Task: Load psc-fw
[0001.325] I> Slot: 0
[0001.327] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.333] I> Binary name: PSC_FW
[0001.336] I> Size of crypto header is 8192
[0001.340] I> Size of crypto header is 8192
[0001.344] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.350] I> BCH of PSC_FW read from storage
[0001.354] I> BCH address is : 0x80ffe000
[0001.358] I> PSC_FW header integrity check is success
[0001.363] I> Binary magic in BCH component 0 is PFWP
[0001.367] I> component binary type is 17
[0001.371] I> Size of crypto header is 8192
[0001.375] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.385] I> PSC_FW binary is read from storage
[0001.390] I> PSC_FW binary integrity check is success
[0001.395] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.401] I> Task: Load nvdec-fw
[0001.404] I> Slot: 0
[0001.406] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.412] I> Binary name: NVDEC
[0001.415] I> Size of crypto header is 8192
[0001.418] I> Size of crypto header is 8192
[0001.422] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.429] I> BCH of NVDEC read from storage
[0001.433] I> BCH address is : 0x800fe000
[0001.436] I> NVDEC header integrity check is success
[0001.441] I> Binary magic in BCH component 0 is NDEC
[0001.446] I> component binary type is 7
[0001.450] I> Size of crypto header is 8192
[0001.454] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.463] I> NVDEC binary is read from storage
[0001.468] I> NVDEC binary integrity check is success
[0001.473] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.479] I> Size of crypto header is 8192
[0001.490] I> Task: Load tsec-fw
[0001.493] I> TSEC-FW load support not enabled
[0001.498] I> Task: GPIO interrupt map
[0001.501] I> Task: SC7 context save
[0001.505] I> Slot: 0
[0001.507] I> Binary[27] block-0 (partition size: 0x100000)
[0001.512] I> Binary name: BR_BCT
[0001.515] I> Size of crypto header is 8192
[0001.519] I> Size of crypto header is 8192
[0001.523] I> Size of crypto header is 8192
[0001.527] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.533] I> BR_BCT binary is read from storage
[0001.537] I> BR_BCT binary integrity check is success
[0001.542] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.549] I> Slot: 0
[0001.551] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.556] I> Binary name: SC7-FW
[0001.559] I> Size of crypto header is 8192
[0001.563] I> Size of crypto header is 8192
[0001.567] I> Size of crypto header is 8192
[0001.571] I> Size of crypto header is 8192
[0001.575] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.581] I> BCH of SC7-FW read from storage
[0001.585] I> BCH address is : 0xa0002000
[0001.589] I> SC7-FW header integrity check is success
[0001.594] I> Binary magic in BCH component 0 is WB0B
[0001.599] I> component binary type is 13
[0001.603] I> Size of crypto header is 8192
[0001.606] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.615] I> SC7-FW binary is read from storage
[0001.619] I> SC7-FW binary integrity check is success
[0001.624] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.631] I> Slot: 0
[0001.633] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.638] I> Binary name: PSC_RF
[0001.641] I> Size of crypto header is 8192
[0001.645] I> Size of crypto header is 8192
[0001.649] I> Size of crypto header is 8192
[0001.653] I> Size of crypto header is 8192
[0001.657] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.663] I> BCH of PSC_RF read from storage
[0001.668] I> BCH address is : 0xa002fa00
[0001.671] I> PSC_RF header integrity check is success
[0001.676] I> Binary magic in BCH component 0 is PSCR
[0001.681] I> component binary type is 22
[0001.685] I> Size of crypto header is 8192
[0001.689] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[0001.696] I> PSC_RF binary is read from storage
[0001.701] I> PSC_RF binary integrity check is success
[0001.706] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.715] I> Task: Save WP0 payload to SC7 ctx
[0001.719] I> Task: Load MB2rf binary to SC7 ctx
[0001.724] I> Slot: 0
[0001.726] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.731] I> Binary name: MB2_RF
[0001.735] I> Size of crypto header is 8192
[0001.738] I> Size of crypto header is 8192
[0001.742] I> Size of crypto header is 8192
[0001.746] I> Size of crypto header is 8192
[0001.750] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.757] I> BCH of MB2_RF read from storage
[0001.761] I> BCH address is : 0xa00d5d10
[0001.764] I> MB2_RF header integrity check is success
[0001.769] I> Binary magic in BCH component 0 is MB2R
[0001.774] I> component binary type is 14
[0001.778] I> Size of crypto header is 8192
[0001.782] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.789] I> MB2_RF binary is read from storage
[0001.794] I> MB2_RF binary integrity check is success
[0001.799] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.805] I> Task: Save fuse alias data to SC7 ctx
[0001.810] I> Task: Save PMIC data to SC7 ctx
[0001.814] I> Task: Save Pinmux data to SC7 ctx
[0001.818] I> Task: Save Pad Voltage data to SC7 ctx
[0001.823] I> Task: Save controller prod data to SC7 ctx
[0001.828] I> Task: Save prod cfg data to SC7 ctx
[0001.833] I> Task: Save I2C bus freq data to SC7 ctx
[0001.837] I> Task: Save SOCTherm data to SC7 ctx
[0001.842] I> Task: Save FMON data to SC7 ctx
[0001.846] I> Task: Save VMON data to SC7 ctx
[0001.850] I> Task: Save TZDRAM data to SC7 ctx
[0001.854] I> Task: Save GPIO int data to SC7 ctx
[0001.859] I> Task: Save clock data to SC7 ctx
[0001.863] I> Task: Save debug data to SC7 ctx
[0001.867] I> Task: Save MBWT data to SC7 ctx
[0001.875] I> SC7 context save done
[0001.878] I> Task: Load MB2/Applet/FSKP
[0001.882] I> Loading MB2
[0001.885] I> Slot: 0
[0001.887] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.892] I> Binary name: MB2
[0001.895] I> Size of crypto header is 8192
[0001.899] I> Size of crypto header is 8192
[0001.903] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.909] I> BCH of MB2 read from storage
[0001.913] I> BCH address is : 0x8007e000
[0001.917] I> MB2 header integrity check is success
[0001.921] I> Binary magic in BCH component 0 is MB2B
[0001.926] I> component binary type is 6
[0001.930] I> Size of crypto header is 8192
[0001.934] I> strt_pg_num(8464) num_of_pgs(846) read_buf(0x80000000)
[0001.945] I> MB2 binary is read from storage
[0001.949] I> MB2 binary integrity check is success
[0001.954] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.960] I> Task: Map CCPLEX SHARED carveout
[0001.965] I> Task: Prepare MB2 params
[0001.968] I> Task: Dram ecc test
[0001.971] I> Task: Misc NV security settings
[0001.976] I> NVDEC sticky bits programming done
[0001.980] I> Successfully powergated NVDEC
[0001.984] I> Task: Disable/Reload WDT
[0001.987] I> Task: Program misc carveouts
[0001.991] I> Program IPC carveouts
[0001.995] I> Task: Disable SCPM/POD reset
[0001.999] I> SLCG Global override status := 0x0
[0002.003] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> Emulation:
I> Entry timestamp: 0x001f03fd
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x473801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x472e00000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x472a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40067a30)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x4739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x4738000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x4738400c0)
I> dce : will be decompressed at 0x47a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x4738800c0)
I> dce : decompressed to 12083328 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x47d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x472f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40067a30)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x4739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x4738000c0)
I> pva-fw : will be decompressed at 0x473180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
[0000.064] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x16, rst_level: 0x1
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.231] I> FUSE_SKU_INFO_0 = 0xd3
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.252] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.258] I> BPMP NAFLL lock success.
[0000.261] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.266] I> Initializing PLLC2 for AXI_CBB.
[0000.270] I> AXI_CBB : src = 35, divisor = 0
[0000.274] I> Task: Voltage monitor
[0000.277] I> VMON: Vmon re-calibration and fine tuning done
[0000.283] I> Task: UPHY init
[0000.294] I> Task: Boot device init
[0000.297] I> Boot_device: QSPI_FLASH instance: 0
[0000.302] I> Qspi clock source : pllc_out0
[0000.306] I> QSPI Flash: Macronix 64MB
[0000.310] I> QSPI-0l initialized successfully
[0000.314] I> Task: TSC init
[0000.317] I> Task: Load membct
[0000.320] I> RAM_CODE 0x4000411
[0000.323] I> Loading MEMBCT
[0000.326] I> Slot: 1
[0000.328] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.333] I> Binary name: MEM-BCT-0
[0000.336] I> Size of crypto header is 8192
[0000.340] I> Size of crypto header is 8192
[0000.344] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.355] I> BCH address is : 0x40050000
[0000.359] I> MEM-BCT-0 header integrity check is success
[0000.364] I> Binary magic in BCH component 0 is MEM0
[0000.369] I> component binary type is 0
[0000.373] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.379] I> MEM-BCT-0 binary is read from storage
[0000.384] I> MEM-BCT-0 binary integrity check is success
[0000.389] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.396] I> RAM_CODE 0x4000411
[0000.401] I> RAM_CODE 0x4000411
[0000.405] I> Task: Load Page retirement list
[0000.413] I> Task: Save mem-bct info
[0000.420] I> RCM blob carveout will not be allocated
[0000.425] I> Update CCPLEX IST carveout from MB1-BCT
[0000.434] I> ECC region[1]: Start:0x0, End:0x0
[0000.438] I> ECC region[2]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.457] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.517] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.524] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.531] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.538] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.545] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.552] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.593] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.669] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.683] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.710] I> Task: Thermal check
[0000.713] I> Using min_chip_limit as min_tmon_limit
[0000.718] I> Using max_chip_limit as max_tmon_limit
[0000.726] I> BCT min_tmon_limit = -28
[0000.733] I> BCT min_tmon_limit = -28
[0000.741] I> SKU specific min_chip_limit = -28
[0000.745] I> BCT max_chip_limit = 105
[0000.752] I> enable_soctherm_polling = 0
[0000.756] I> max temp read = 34
[0000.759] I> min temp read = 33
[0000.762] I> Enabling thermtrip
[0000.765] I> Task: Update FSI SCR with thermal fuse data
[0000.770] I> Task: Enable WDT 5th expiry
[0000.780] I> Task: Reset FSI
[0000.786] I> skipped mmio_addr = 0x9240008
[0000.790] I> skipped mmio_addr = 0x9240000
[0000.794] I> skipped mmio_addr = 0x9240010
[0000.798] I> skipped mmio_addr = 0x9240018
[0000.833] I> skipped mmio_addr = 0x9241010
[0000.837] I> skipped mmio_addr = 0x9241018
[0000.841] I> skipped mmio_addr = 0x9241020
[0000.845] I> skipped mmio_addr = 0x9241028
[0000.849] I> skipped mmio_addr = 0x9241030
[0000.853] I> skipped mmio_addr = 0x9241038
[0000.857] I> skipped mmio_addr = 0x9241040
[0000.861] I> skipped mmio_addr = 0x9242000
[0000.865] I> skipped mmio_addr = 0x9242008
[0000.872] I> Task: Pad voltage init
[0000.878] I> Task: Program rst req config reg
[0000.886] I> DONE: Thermal config
[0000.921] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.927] I> DONE: CV rail info
[0000.930] I> Task: Mem clock src
[0000.933] I> Task: Misc. board config
[0000.937] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.943] I> Task: SDRAM init
[0000.946] I> MemoryType: 4 MemBctRevision: 2
[0000.952] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0000.960] I> MSS CAR: Init PLLM
[0000.963] I> MSS CAR: Init PLLHUB
[0000.968] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.979] I> SDRAM initialized!
[0000.982] I> SDRAM Size in Total 0x400000000
[0000.986] I> Task: Dram Ecc scrub
[0000.989] I> Task: DRAM alias check
[0000.996] I> Task: Program NSDRAM carveout
[0001.000] I> NSDRAM carveout encryption is enabled
[0001.004] I> Program NSDRAM carveout
[0001.008] I> Task: Register checker
[0001.011] I> Task: Enable clock-mon
[0001.015] I> FMON: Fmon re-programming done
[0001.019] I> Task: Mapper init
[0001.022] I> Task: SC7 Context Init
[0001.026] I> Task: CCPLEX IST init
[0001.029] I> Task: CPU WP0
[0001.032] I> Loading MCE
[0001.034] I> Slot: 1
[0001.036] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.042] I> Binary name: MCE
[0001.044] I> Size of crypto header is 8192
[0001.048] I> Size of crypto header is 8192
[0001.052] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.059] I> BCH of MCE read from storage
[0001.062] I> BCH address is : 0x4003e000
[0001.066] I> MCE header integrity check is success
[0001.071] I> Binary magic in BCH component 0 is MTSM
[0001.076] I> component binary type is 8
[0001.079] I> Size of crypto header is 8192
[0001.083] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.092] I> MCE binary is read from storage
[0001.096] I> MCE binary integrity check is success
[0001.101] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.107] I> Size of crypto header is 8192
[0001.118] I> Size of crypto header is 8192
[0001.122] I> Sending WP0 mailbox command to PSC
[0001.131] I> Task: XUSB Powergate
[0001.134] I> Skipping powergate XUSB.
[0001.138] I> Task: MB1 fixed firewalls
[0001.144] W> Firewall readback mismatch
[0001.149] I> Task: Load bpmp-fw
[0001.152] I> Slot: 1
[0001.154] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.160] I> Binary name: BPMP_FW
[0001.163] I> Size of crypto header is 8192
[0001.167] I> Size of crypto header is 8192
[0001.171] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.177] I> BCH of BPMP_FW read from storage
[0001.181] I> BCH address is : 0x807fe000
[0001.185] I> BPMP_FW header integrity check is success
[0001.190] I> Binary magic in BCH component 0 is BPMF
[0001.195] I> component binary type is 15
[0001.198] I> Size of crypto header is 8192
[0001.202] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.220] I> BPMP_FW binary is read from storage
[0001.226] I> BPMP_FW binary integrity check is success
[0001.231] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.238] I> Slot: 1
[0001.240] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.246] I> Binary name: BPMP_FW_DTB
[0001.249] I> Size of crypto header is 8192
[0001.253] I> Size of crypto header is 8192
[0001.257] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.263] I> BCH of BPMP_FW_DTB read from storage
[0001.268] I> BCH address is : 0x807fc000
[0001.272] I> BPMP_FW_DTB header integrity check is success
[0001.277] I> Binary magic in BCH component 0 is BPMD
[0001.282] I> component binary type is 16
[0001.285] I> Size of crypto header is 8192
[0001.289] I> strt_pg_num(76048) num_of_pgs(733) read_buf(0x807a05f0)
[0001.300] I> BPMP_FW_DTB binary is read from storage
[0001.305] I> BPMP_FW_DTB binary integrity check is success
[0001.311] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.317] I> Task: BPMP fw ast config
[0001.321] I> Task: Load psc-fw
[0001.324] I> Slot: 1
[0001.326] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.332] I> Binary name: PSC_FW
[0001.335] I> Size of crypto header is 8192
[0001.339] I> Size of crypto header is 8192
[0001.342] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.349] I> BCH of PSC_FW read from storage
[0001.353] I> BCH address is : 0x80ffe000
[0001.357] I> PSC_FW header integrity check is success
[0001.362] I> Binary magic in BCH component 0 is PFWP
[0001.366] I> component binary type is 17
[0001.370] I> Size of crypto header is 8192
[0001.374] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.384] I> PSC_FW binary is read from storage
[0001.389] I> PSC_FW binary integrity check is success
[0001.393] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.400] I> Task: Load nvdec-fw
[0001.403] I> Slot: 1
[0001.405] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.411] I> Binary name: NVDEC
[0001.414] I> Size of crypto header is 8192
[0001.421] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.428] I> BCH of NVDEC read from storage
[0001.432] I> BCH address is : 0x800fe000
[0001.440] I> Binary magic in BCH component 0 is NDEC
[0001.445] I> component binary type is 7
[0001.449] I> Size of crypto header is 8192
[0001.453] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.462] I> NVDEC binary is read from storage
[0001.467] I> NVDEC binary integrity check is success
[0001.472] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.478] I> Size of crypto header is 8192
[0001.497] I> Task: GPIO interrupt map
[0001.504] I> Slot: 1
[0001.506] I> Binary[27] block-0 (partition size: 0x100000)
[0001.511] I> Binary name: BR_BCT
[0001.514] I> Size of crypto header is 8192
[0001.518] I> Size of crypto header is 8192
[0001.522] I> Size of crypto header is 8192
[0001.526] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.532] I> BR_BCT binary is read from storage
[0001.541] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.548] I> Slot: 1
[0001.550] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.555] I> Binary name: SC7-FW
[0001.558] I> Size of crypto header is 8192
[0001.562] I> Size of crypto header is 8192
[0001.566] I> Size of crypto header is 8192
[0001.570] I> Size of crypto header is 8192
[0001.574] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.580] I> BCH of SC7-FW read from storage
[0001.584] I> BCH address is : 0xa0002000
[0001.588] I> SC7-FW header integrity check is success
[0001.593] I> Binary magic in BCH component 0 is WB0B
[0001.598] I> component binary type is 13
[0001.602] I> Size of crypto header is 8192
[0001.606] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.614] I> SC7-FW binary is read from storage
[0001.630] I> Slot: 1
[0001.632] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.648] I> Size of crypto header is 8192
[0001.652] I> Size of crypto header is 8192
[0001.656] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[0001.667] I> BCH address is : 0xa002fa00
[0001.675] I> Binary magic in BCH component 0 is PSCR
[0001.680] I> component binary type is 22
[0001.684] I> Size of crypto header is 8192
[0001.688] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[0001.695] I> PSC_RF binary is read from storage
[0001.700] I> PSC_RF binary integrity check is success
[0001.705] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.714] I> Task: Save WP0 payload to SC7 ctx
[0001.723] I> Slot: 1
[0001.725] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.734] I> Size of crypto header is 8192
[0001.749] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.756] I> BCH of MB2_RF read from storage
[0001.760] I> BCH address is : 0xa00d5d10
[0001.773] I> component binary type is 14
[0001.777] I> Size of crypto header is 8192
[0001.781] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.793] I> MB2_RF binary integrity check is success
[0001.798] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.804] I> Task: Save fuse alias data to SC7 ctx
[0001.809] I> Task: Save PMIC data to SC7 ctx
[0001.813] I> Task: Save Pinmux data to SC7 ctx
[0001.822] I> Task: Save controller prod data to SC7 ctx
[0001.827] I> Task: Save prod cfg data to SC7 ctx
[0001.832] I> Task: Save I2C bus freq data to SC7 ctx
[0001.841] I> Task: Save FMON data to SC7 ctx
[0001.845] I> Task: Save VMON data to SC7 ctx
[0001.849] I> Task: Save TZDRAM data to SC7 ctx
[0001.858] I> Task: Save clock data to SC7 ctx
[0001.862] I> Task: Save debug data to SC7 ctx
[0001.866] I> Task: Save MBWT data to SC7 ctx
[0001.874] I> SC7 context save done
[0001.881] I> Loading MB2
[0001.884] I> Slot: 1
[0001.886] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.891] I> Binary name: MB2
[0001.894] I> Size of crypto header is 8192
[0001.898] I> Size of crypto header is 8192
[0001.902] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.908] I> BCH of MB2 read from storage
[0001.912] I> BCH address is : 0x8007e000
[0001.916] I> MB2 header integrity check is success
[0001.925] I> component binary type is 6
[0001.929] I> Size of crypto header is 8192
[0001.933] I> strt_pg_num(71440) num_of_pgs(846) read_buf(0x80000000)
[0001.944] I> MB2 binary is read from storage
[0001.964] I> Task: Prepare MB2 params
[0001.975] I> NVDEC sticky bits programming done
[0001.979] I> Successfully powergated NVDEC
[0001.983] I> Task: Disable/Reload WDT
[0001.994] I> Task: Disable SCPM/POD reset
[0001.998] I> SLCG Global override status := 0x0
I> Emulation:
I> Entry timestamp: 0x001efd5b
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x473801200)
I> Unpowergate done
I> Partition name: B_spe-fw
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x472e00000)
I> Partition name: B_rce-fw
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x472a00000)
I> Partition name: B_dce-fw
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x4739400d8)
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x4738000c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x4738400c0)
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x4738800c0)
I> Partition name: B_adsp-fw
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(121232) num_of_pgs(800) read_buf(0x47d800000)
I> Partition name: B_xusb-fw
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x472f00000)
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x4739400d8)
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x4738000c0)
I> Busy Spin
I tried other ways to connect together REC with GND without success of flashing.
Hi
The log show related to eeprom read error.
Do you confirm change the eeprom value as Jetson Orin NX and Nano Series — NVIDIA Jetson Linux Developer Guide 1 documentation suggest?
Hi David,
I had changed them before, but I still can’t flash the board.
root@grzegorzp-OptiPlex-9010:/home/grzegorzp# locate tegra234-mb2-bct-misc-p3767-0000.dts
/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/tegra234-mb2-bct-misc-p3767-0000.dts
/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
/home/grzegorzp/nvidia/nvidia_sdk/JetPack_6.2.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
/home/grzegorzp/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
...grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/tegra234-mb2-bct-misc-p3767-0000.dts *
/dts-v1/;
#include "tegra234-mb2-bct-common.dtsi"
        mb2-misc {
                eeprom {
                        cvm_eeprom_i2c_instance = <0>;
                        cvm_eeprom_i2c_slave_address = <0xa0>;
                        cvm_eeprom_read_size = <0x100>;
                        cvb_eeprom_i2c_instance = <0x0>;
                        cvb_eeprom_i2c_slave_address = <0xae>;
                        cvb_eeprom_read_size = <0x0>;
...wnloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
/dts-v1/;
        mb2-misc {
                eeprom {
inux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts *
/dts-v1/;
        mb2-misc {
                eeprom {
...inux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
/dts-v1/;
        mb2-misc {
                eeprom {...inux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
/dts-v1/;
        mb2-misc {
                eeprom {
/dts-v1/;
        mb2-misc {
                eeprom {
I tried to flash it again but without success with the use of SDK Manager. Logs below:
SDKM_logs_JetPack_6.2.1_Linux_for_Jetson_Orin_NX_16GB_2025-08-01_20-49-24.zip (288.1 KB)
20:50:11 INFO: [   0.3048 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
20:50:11 INFO: [   0.3053 ] BR_CID: 0x80012344705E00C83000000014FD8100
20:50:11 INFO: [   0.3933 ] Sending bct_br
20:50:21 ERROR: [   0.4816 ] ERROR: might be timeout in USB write.
20:50:21 ERROR: Error: Return value 3
20:50:21 INFO: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
20:50:21 ERROR: --- Error: Reading board information failed.
20:50:21 ERROR: 20:50:21.708 - Error: Parsing boardid failed.
20:50:21 INFO: 5
20:50:21 INFO: command finished successfully
20:50:21 ERROR: Bootrom status check failed.
20:50:26 DEBUG: running command < true >
20:50:26 INFO: command finished successfully
20:50:26 DEBUG: running command < sudo rm -rf '$HOME' >
20:50:26 INFO: All done!
I also tried with skipping the eeprom check. The process took longer as usual. I think it flashed some partition to NVME. Its interesting. :
root@grzegorzp-OptiPlex-9010:/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra# sudo SKIP_EEPROM_CHECK=1 BOARDID=3767 BOARDSKU=0000  ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit-super internal
Output is here:
terminal output flashing with SKIP EEPROM CHECK.txt (269.3 KB)
I switched the board into non recovery mode and tried booting. Minicom output:
[0000.066] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.146] I> Task: Secure debug controls
[0000.153] I> Task: Initialize SOC Therm
[0000.161] I> Task: Verify boot mode
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.177] I> Task: Print SKU type
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.254] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.279] I> VMON: Vmon re-calibration and fine tuning done
[0000.289] I> HSIO UPHY init done
[0000.292] W> Skipping GBE UPHY config
[0000.299] I> Boot_device: QSPI_FLASH instance: 0
[0000.308] I> QSPI Flash: Macronix 64MB
[0000.327] I> Slot: 0
[0000.329] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.338] I> Size of crypto header is 8192
[0000.342] I> Size of crypto header is 8192
[0000.346] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.352] I> BCH of MEM-BCT-0 read from storage
[0000.374] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.381] I> MEM-BCT-0 binary is read from storage
[0000.391] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.403] I> RAM_CODE 0x4000411
[0000.411] I> Task: SDRAM params override
[0000.418] I> Task: Carveout allocate
[0000.431] I> ECC region[0]: Start:0x0, End:0x0
[0000.444] I> ECC region[3]: Start:0x0, End:0x0
[0000.448] I> ECC region[4]: Start:0x0, End:0x0
[0000.463] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.483] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.490] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.497] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.504] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.511] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.560] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.567] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.574] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.581] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.588] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.657] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.664] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.698] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.705] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.724] I> BCT max_tmon_limit = 105
[0000.731] I> BCT max_tmon_limit = 105
[0000.738] I> SKU specific max_chip_limit = 105
[0000.750] I> BCT min_chip_limit = -28
[0000.757] I> max temp read = 32
[0000.760] I> min temp read = 31
[0000.775] I> Task: I2C register
[0000.778] I> Task: Set I2C bus freq
[0000.784] I> Task: Pinmux init
[0000.803] I> skipped mmio_addr = 0x9240020
[0000.807] I> skipped mmio_addr = 0x9240030
[0000.811] I> skipped mmio_addr = 0x9240028
[0000.815] I> skipped mmio_addr = 0x9240038
[0000.819] I> skipped mmio_addr = 0x9240040
[0000.823] I> skipped mmio_addr = 0x9240048
[0000.827] I> skipped mmio_addr = 0x9241000
[0000.831] I> skipped mmio_addr = 0x9241008
[0000.870] I> Task: Prod config init
[0000.877] I> Task: Prod init
[0000.884] I> Task: Common rail init
[0000.891] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.899] I> DONE: SOC rail config
[0000.903] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.909] I> DONE: MEMIO rail config
[0000.913] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.919] I> DONE: GPU rail info
[0000.923] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.929] I> DONE: CV rail info
[0000.932] I> Task: Mem clock src
[0000.935] I> Task: Misc. board config
[0000.939] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.991] I> Task: DRAM alias check
[0001.038] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.054] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.098] I> MCE binary integrity check is success
[0001.136] I> Skipping powergate XUSB.
[0001.204] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.228] I> BPMP_FW binary integrity check is success
[0001.233] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.287] I> Size of crypto header is 8192
[0001.291] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.307] I> BPMP_FW_DTB binary integrity check is success
[0001.368] I> component binary type is 17
[0001.419] I> Size of crypto header is 8192
[0001.423] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.437] I> NVDEC header integrity check is success
[0001.491] I> Task: Load tsec-fw
[0001.494] I> TSEC-FW load support not enabled
[0001.502] I> Task: SC7 context save
[0001.538] I> BR_BCT binary integrity check is success
[0001.586] I> BCH address is : 0xa0002000
[0001.607] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.620] I> SC7-FW binary integrity check is success
[0001.625] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.639] I> Binary name: PSC_RF
[0001.642] I> Size of crypto header is 8192
[0001.646] I> Size of crypto header is 8192
[0001.664] I> BCH of PSC_RF read from storage
[0001.672] I> PSC_RF header integrity check is success
[0001.720] I> Task: Load MB2rf binary to SC7 ctx
[0001.732] I> Binary name: MB2_RF
[0001.739] I> Size of crypto header is 8192
[0001.743] I> Size of crypto header is 8192
[0001.747] I> Size of crypto header is 8192
[0001.765] I> MB2_RF header integrity check is success
[0001.770] I> Binary magic in BCH component 0 is MB2R
[0001.790] I> MB2_RF binary is read from storage
[0001.806] I> Task: Save fuse alias data to SC7 ctx
[0001.819] I> Task: Save Pad Voltage data to SC7 ctx
[0001.838] I> Task: Save SOCTherm data to SC7 ctx
[0001.855] I> Task: Save GPIO int data to SC7 ctx
[0001.879] I> Task: Load MB2/Applet/FSKP
[0001.950] I> MB2 binary integrity check is success
[0001.969] I> Task: Dram ecc test
[0001.972] I> Task: Misc NV security settings
[0001.988] I> Task: Program misc carveouts
I> Emulation:
I> Entry timestamp: 0x001ef8ab
I> Unpowergate done
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via insta.
I> Busy Spin
[0000.062] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.068] I> t234-A01-1-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x16, rst_level: 0x1
[0000.090] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.100] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.107] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.117] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.142] I> Task: Secure debug controls
[0000.146] I> Task: strap war set
[0000.149] I> Task: Initialize SOC Therm
[0000.153] I> Task: Program NV master stream id
[0000.157] I> Task: Verify boot mode
[0000.163] I> Task: Alias fuses
[0000.166] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.190] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.216] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd3
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.250] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.256] I> BPMP NAFLL lock success.
[0000.259] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.264] I> Initializing PLLC2 for AXI_CBB.
[0000.268] I> AXI_CBB : src = 35, divisor = 0
[0000.272] I> Task: Voltage monitor
[0000.275] I> VMON: Vmon re-calibration and fine tuning done
[0000.281] I> Task: UPHY init
[0000.286] I> HSIO UPHY init done
[0000.289] W> Skipping GBE UPHY config
[0000.292] I> Task: Boot device init
[0000.296] I> Boot_device: QSPI_FLASH instance: 0
[0000.300] I> Qspi clock source : pllc_out0
[0000.304] I> QSPI Flash: Macronix 64MB
[0000.308] I> QSPI-0l initialized successfully
[0000.312] I> Task: TSC init
[0000.315] I> Task: Load membct
[0000.318] I> RAM_CODE 0x4000411
[0000.321] I> Loading MEMBCT
[0000.324] I> Slot: 1
[0000.326] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.331] I> Binary name: MEM-BCT-0
[0000.334] I> Size of crypto header is 8192
[0000.342] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.349] I> BCH of MEM-BCT-0 read from storage
[0000.353] I> BCH address is : 0x40050000
[0000.357] I> MEM-BCT-0 header integrity check is success
[0000.362] I> Binary magic in BCH component 0 is MEM0
[0000.367] I> component binary type is 0
[0000.371] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.378] I> MEM-BCT-0 binary is read from storage
[0000.382] I> MEM-BCT-0 binary integrity check is success
[0000.388] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.394] I> RAM_CODE 0x4000411
[0000.399] I> RAM_CODE 0x4000411
[0000.403] I> Task: Load Page retirement list
[0000.408] I> Task: SDRAM params override
[0000.411] I> Task: Save mem-bct info
[0000.415] I> Task: Carveout allocate
[0000.418] I> RCM blob carveout will not be allocated
[0000.423] I> Update CCPLEX IST carveout from MB1-BCT
[0000.428] I> ECC region[0]: Start:0x0, End:0x0
[0000.432] I> ECC region[1]: Start:0x0, End:0x0
[0000.436] I> ECC region[2]: Start:0x0, End:0x0
[0000.441] I> ECC region[3]: Start:0x0, End:0x0
[0000.445] I> ECC region[4]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.455] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.460] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.469] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.480] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.487] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.494] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.501] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.508] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.522] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.529] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.536] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.543] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.550] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.557] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.564] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.571] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.578] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.585] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.592] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.598] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.605] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.612] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.619] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.626] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.633] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.640] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.647] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.654] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.661] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.667] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.674] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.681] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.688] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.695] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.702] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.708] I> Task: Thermal check
[0000.711] I> Using min_chip_limit as min_tmon_limit
[0000.716] I> Using max_chip_limit as max_tmon_limit
[0000.721] I> BCT max_tmon_limit = 105
[0000.724] I> BCT min_tmon_limit = -28
[0000.728] I> BCT max_tmon_limit = 105
[0000.731] I> BCT min_tmon_limit = -28
[0000.735] I> SKU specific max_chip_limit = 105
[0000.739] I> SKU specific min_chip_limit = -28
[0000.743] I> BCT max_chip_limit = 105
[0000.747] I> BCT min_chip_limit = -28
[0000.750] I> enable_soctherm_polling = 0
[0000.754] I> max temp read = 33
[0000.757] I> min temp read = 32
[0000.760] I> Enabling thermtrip
[0000.763] I> Task: Update FSI SCR with thermal fuse data
[0000.768] I> Task: Enable WDT 5th expiry
[0000.772] I> Task: I2C register
[0000.775] I> Task: Set I2C bus freq
[0000.778] I> Task: Reset FSI
[0000.781] I> Task: Pinmux init
[0000.784] I> skipped mmio_addr = 0x9240008
[0000.788] I> skipped mmio_addr = 0x9240000
[0000.792] I> skipped mmio_addr = 0x9240010
[0000.796] I> skipped mmio_addr = 0x9240018
[0000.800] I> skipped mmio_addr = 0x9240020
[0000.804] I> skipped mmio_addr = 0x9240030
[0000.808] I> skipped mmio_addr = 0x9240028
[0000.812] I> skipped mmio_addr = 0x9240038
[0000.816] I> skipped mmio_addr = 0x9240040
[0000.820] I> skipped mmio_addr = 0x9240048
[0000.824] I> skipped mmio_addr = 0x9241000
[0000.828] I> skipped mmio_addr = 0x9241008
[0000.831] I> skipped mmio_addr = 0x9241010
[0000.835] I> skipped mmio_addr = 0x9241018
[0000.839] I> skipped mmio_addr = 0x9241020
[0000.843] I> skipped mmio_addr = 0x9241028
[0000.847] I> skipped mmio_addr = 0x9241030
[0000.851] I> skipped mmio_addr = 0x9241038
[0000.855] I> skipped mmio_addr = 0x9241040
[0000.859] I> skipped mmio_addr = 0x9242000
[0000.863] I> skipped mmio_addr = 0x9242008
[0000.867] I> Task: Prod config init
[0000.870] I> Task: Pad voltage init
[0000.874] I> Task: Prod init
[0000.876] I> Task: Program rst req config reg
[0000.881] I> Task: Common rail init
[0000.884] I> DONE: Thermal config
[0000.888] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.896] I> DONE: SOC rail config
[0000.900] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.906] I> DONE: MEMIO rail config
[0000.910] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.916] I> DONE: GPU rail info
[0000.920] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.926] I> DONE: CV rail info
[0000.929] I> Task: Mem clock src
[0000.932] I> Task: Misc. board config
[0000.936] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.942] I> Task: SDRAM init
[0000.945] I> MemoryType: 4 MemBctRevision: 2
[0000.951] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0000.959] I> MSS CAR: Init PLLM
[0000.962] I> MSS CAR: Init PLLHUB
[0000.967] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.978] I> SDRAM initialized!
[0000.981] I> SDRAM Size in Total 0x400000000
[0000.985] I> Task: Dram Ecc scrub
[0000.988] I> Task: DRAM alias check
[0000.995] I> Task: Program NSDRAM carveout
[0000.999] I> NSDRAM carveout encryption is enabled
[0001.003] I> Program NSDRAM carveout
[0001.007] I> Task: Register checker
[0001.010] I> Task: Enable clock-mon
[0001.014] I> FMON: Fmon re-programming done
[0001.018] I> Task: Mapper init
[0001.021] I> Task: SC7 Context Init
[0001.025] I> Task: CCPLEX IST init
[0001.028] I> Task: CPU WP0
[0001.031] I> Loading MCE
[0001.033] I> Slot: 1
[0001.035] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.041] I> Binary name: MCE
[0001.043] I> Size of crypto header is 8192
[0001.047] I> Size of crypto header is 8192
[0001.051] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.057] I> BCH of MCE read from storage
[0001.061] I> BCH address is : 0x4003e000
[0001.065] I> MCE header integrity check is success
[0001.070] I> Binary magic in BCH component 0 is MTSM
[0001.075] I> component binary type is 8
[0001.078] I> Size of crypto header is 8192
[0001.082] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.091] I> MCE binary is read from storage
[0001.095] I> MCE binary integrity check is success
[0001.100] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.106] I> Size of crypto header is 8192
[0001.117] I> Size of crypto header is 8192
[0001.121] I> Sending WP0 mailbox command to PSC
[0001.130] I> Task: XUSB Powergate
[0001.133] I> Skipping powergate XUSB.
[0001.137] I> Task: MB1 fixed firewalls
[0001.143] W> Firewall readback mismatch
[0001.148] I> Task: Load bpmp-fw
[0001.151] I> Slot: 1
[0001.153] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.159] I> Binary name: BPMP_FW
[0001.162] I> Size of crypto header is 8192
[0001.166] I> Size of crypto header is 8192
[0001.170] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.176] I> BCH of BPMP_FW read from storage
[0001.180] I> BCH address is : 0x807fe000
[0001.184] I> BPMP_FW header integrity check is success
[0001.189] I> Binary magic in BCH component 0 is BPMF
[0001.194] I> component binary type is 15
[0001.197] I> Size of crypto header is 8192
[0001.201] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.219] I> BPMP_FW binary is read from storage
[0001.225] I> BPMP_FW binary integrity check is success
[0001.230] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.237] I> Slot: 1
[0001.239] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.244] I> Binary name: BPMP_FW_DTB
[0001.248] I> Size of crypto header is 8192
[0001.252] I> Size of crypto header is 8192
[0001.256] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.262] I> BCH of BPMP_FW_DTB read from storage
[0001.267] I> BCH address is : 0x807fc000
[0001.271] I> BPMP_FW_DTB header integrity check is success
[0001.276] I> Binary magic in BCH component 0 is BPMD
[0001.281] I> component binary type is 16
[0001.284] I> Size of crypto header is 8192
[0001.288] I> strt_pg_num(76048) num_of_pgs(733) read_buf(0x807a05f0)
[0001.299] I> BPMP_FW_DTB binary is read from storage
[0001.304] I> BPMP_FW_DTB binary integrity check is success
[0001.310] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.316] I> Task: BPMP fw ast config
[0001.320] I> Task: Load psc-fw
[0001.323] I> Slot: 1
[0001.325] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.331] I> Binary name: PSC_FW
[0001.334] I> Size of crypto header is 8192
[0001.338] I> Size of crypto header is 8192
[0001.341] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.348] I> BCH of PSC_FW read from storage
[0001.352] I> BCH address is : 0x80ffe000
[0001.356] I> PSC_FW header integrity check is success
[0001.361] I> Binary magic in BCH component 0 is PFWP
[0001.365] I> component binary type is 17
[0001.369] I> Size of crypto header is 8192
[0001.373] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.383] I> PSC_FW binary is read from storage
[0001.388] I> PSC_FW binary integrity check is success
[0001.392] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.399] I> Task: Load nvdec-fw
[0001.402] I> Slot: 1
[0001.404] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.410] I> Binary name: NVDEC
[0001.413] I> Size of crypto header is 8192
[0001.417] I> Size of crypto header is 8192
[0001.420] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.427] I> BCH of NVDEC read from storage
[0001.431] I> BCH address is : 0x800fe000
[0001.435] I> NVDEC header integrity check is success
[0001.439] I> Binary magic in BCH component 0 is NDEC
[0001.444] I> component binary type is 7
[0001.448] I> Size of crypto header is 8192
[0001.452] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.461] I> NVDEC binary is read from storage
[0001.466] I> NVDEC binary integrity check is success
[0001.471] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.477] I> Size of crypto header is 8192
[0001.489] I> Task: Load tsec-fw
[0001.492] I> TSEC-FW load support not enabled
[0001.496] I> Task: GPIO interrupt map
[0001.500] I> Task: SC7 context save
[0001.503] I> Slot: 1
[0001.505] I> Binary[27] block-0 (partition size: 0x100000)
[0001.510] I> Binary name: BR_BCT
[0001.513] I> Size of crypto header is 8192
[0001.517] I> Size of crypto header is 8192
[0001.521] I> Size of crypto header is 8192
[0001.525] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.531] I> BR_BCT binary is read from storage
[0001.536] I> BR_BCT binary integrity check is success
[0001.540] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.547] I> Slot: 1
[0001.549] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.554] I> Binary name: SC7-FW
[0001.557] I> Size of crypto header is 8192
[0001.561] I> Size of crypto header is 8192
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.579] I> BCH of SC7-FW read from storage
[0001.583] I> BCH address is : 0xa0002000
[0001.587] I> SC7-FW header integrity check is success
[0001.592] I> Binary magic in BCH component 0 is WB0B
[0001.597] I> component binary type is 13
[0001.601] I> Size of crypto header is 8192
[0001.605] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.613] I> SC7-FW binary is read from storage
[0001.618] I> SC7-FW binary integrity check is success
[0001.623] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.629] I> Slot: 1
[0001.631] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.637] I> Binary name: PSC_RF
[0001.640] I> Size of crypto header is 8192
[0001.644] I> Size of crypto header is 8192
[0001.647] I> Size of crypto header is 8192
[0001.651] I> Size of crypto header is 8192
[0001.655] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[0001.662] I> BCH of PSC_RF read from storage
[0001.666] I> BCH address is : 0xa002fa00
[0001.670] I> PSC_RF header integrity check is success
[0001.674] I> Binary magic in BCH component 0 is PSCR
[0001.679] I> component binary type is 22
[0001.683] I> Size of crypto header is 8192
[0001.687] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[0001.694] I> PSC_RF binary is read from storage
[0001.699] I> PSC_RF binary integrity check is success
[0001.704] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.713] I> Task: Save WP0 payload to SC7 ctx
[0001.718] I> Task: Load MB2rf binary to SC7 ctx
[0001.722] I> Slot: 1
[0001.724] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.730] I> Binary name: MB2_RF
[0001.733] I> Size of crypto header is 8192
[0001.737] I> Size of crypto header is 8192
[0001.741] I> Size of crypto header is 8192
[0001.745] I> Size of crypto header is 8192
[0001.748] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.755] I> BCH of MB2_RF read from storage
[0001.759] I> BCH address is : 0xa00d5d10
[0001.763] I> MB2_RF header integrity check is success
[0001.768] I> Binary magic in BCH component 0 is MB2R
[0001.772] I> component binary type is 14
[0001.776] I> Size of crypto header is 8192
[0001.780] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.788] I> MB2_RF binary is read from storage
[0001.792] I> MB2_RF binary integrity check is success
[0001.797] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.803] I> Task: Save fuse alias data to SC7 ctx
[0001.808] I> Task: Save PMIC data to SC7 ctx
[0001.812] I> Task: Save Pinmux data to SC7 ctx
[0001.817] I> Task: Save Pad Voltage data to SC7 ctx
[0001.821] I> Task: Save controller prod data to SC7 ctx
[0001.826] I> Task: Save prod cfg data to SC7 ctx
[0001.831] I> Task: Save I2C bus freq data to SC7 ctx
[0001.836] I> Task: Save SOCTherm data to SC7 ctx
[0001.840] I> Task: Save FMON data to SC7 ctx
[0001.844] I> Task: Save VMON data to SC7 ctx
[0001.848] I> Task: Save TZDRAM data to SC7 ctx
[0001.853] I> Task: Save GPIO int data to SC7 ctx
[0001.857] I> Task: Save clock data to SC7 ctx
[0001.861] I> Task: Save debug data to SC7 ctx
[0001.865] I> Task: Save MBWT data to SC7 ctx
[0001.873] I> SC7 context save done
[0001.877] I> Task: Load MB2/Applet/FSKP
[0001.880] I> Loading MB2
[0001.883] I> Slot: 1
[0001.885] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.890] I> Binary name: MB2
[0001.893] I> Size of crypto header is 8192
[0001.897] I> Size of crypto header is 8192
[0001.901] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.907] I> BCH of MB2 read from storage
[0001.911] I> BCH address is : 0x8007e000
[0001.915] I> MB2 header integrity check is success
[0001.920] I> Binary magic in BCH component 0 is MB2B
[0001.924] I> component binary type is 6
[0001.928] I> Size of crypto header is 8192
[0001.932] I> strt_pg_num(71440) num_of_pgs(846) read_buf(0x80000000)
[0001.943] I> MB2 binary is read from storage
[0001.948] I> MB2 binary integrity check is success
[0001.953] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.959] I> Task: Map CCPLEX SHARED carveout
[0001.963] I> Task: Prepare MB2 params
[0001.967] I> Task: Dram ecc test
[0001.970] I> Task: Misc NV security settings
[0001.974] I> NVDEC sticky bits programming done
[0001.978] I> Successfully powergated NVDEC
[0001.982] I> Task: Disable/Reload WDT
[0001.986] I> Task: Program misc carveouts
[0001.990] I> Program IPC carveouts
[0001.993] I> Task: Disable SCPM/POD reset
[0001.997] I> SLCG Global override status := 0x0
[0002.002] I> MB1: MSS reconfig completed
I> Emulation:
I> Entry timestamp: 0x001f016c
I> Unpowergate done
I> Busy Spin
No output on screen.
Is there any more steps that I can try?
What about changing cvm_eeprom_read_size also to <0x0>?
Dear @DavidDDD could you advise?
Wit you log provided.
[   0.0651 ] Sending bct_br
[   0.0778 ] ERROR: might be timeout in USB write.
Please disable the autosuspend in host using below commands and run the flash commands again.
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
The reason your minicom output hasn’t changed is that the flashing process did not complete successfully.
I changed the parameters of usbcore.
grzegorzp@grzegorzp-OptiPlex-9010:~$ sudo -s
[sudo] password for grzegorzp:
root@grzegorzp-OptiPlex-9010:/home/grzegorzp# echo -1 > /sys/module/usbcore/parameters/autosuspend
root@grzegorzp-OptiPlex-9010:/home/grzegorzp# cd /home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra
Next I tried flashing with SKIP EEPROM CHECK:
Please install the Secureboot package to use initrd flash for fused board
# Entry added by NVIDIA initrd flash tool
/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p -c bootloader/generic/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit-super internal
*  Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY=""  /home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/flash.sh --no-flash --sign  -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit-super internal
# L4T BSP Information:
# R36 , REVISION: 4.3
# User release: 0.0
ECID is 0x80012344705E00C83000000014FD8100
copying device_config(/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
copying emc_fuse_dev_params(/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying minratchet_config(/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
Existing emcfuse(/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip "0x23" --applet "/home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0436 ] Reading fuses
[   0.0442 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0447 ] File rcm_state open failed
[   0.0450 ] ERROR: failed to read rcm_state
[   0.0450 ]
[   0.0474 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0476 ] Assuming zero filled SBK key
[   0.0454 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0672 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0827 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   0.0921 ] Parsing partition layout
[   0.0929 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0974 ] Kernel DTB used: None
[   0.0974 ] WARNING: dce base dtb is not provided
[   0.0974 ] Parsing partition layout
[   0.0979 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0987 ] Creating list of images to be signed
[   0.1000 ] Generating ratchet blob
[   0.1000 ] Generating coldboot mb1-bct
[   0.1011 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   0.1016 ] MB1-BCT version: 0.13
[   0.1102 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1105 ] Added Platform Config 9 data with size :- 100
[   0.1107 ]
[   0.1107 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   0.1107 ]
[   0.1107 ] Updating mb1-bct with firmware information
[   0.1113 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1130 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1134 ] Generating SHA2 Hash for mb1bct
[   0.1252 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.1267 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.1250 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1254 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1287 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1289 ] Assuming zero filled SBK key
[   0.1314 ] Warning: pub_key.key is not found
[   0.1296 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1314 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   0.1319 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1346 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1350 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1416 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1430 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1684 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1687 ] adding BCH for mb2_t234_aligned.bin
[   0.1743 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1934 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1937 ] adding BCH for mb2_t234_aligned.bin
[   0.2173 ] Filling MB1 storage info
[   0.2173 ] Parsing dev params for multi chains
[   0.2262 ] Generating br-bct
[   0.2266 ] Updating dev and MSS params in BR BCT
[   0.2267 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2276 ] Updating bl info
[   0.2281 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.2285 ] WARNING: boot chain is not completed. set to 0
[   0.2298 ] Generating signatures
[   0.2322 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2323 ] Assuming zero filled SBK key
[   0.2481 ] Warning: pub_key.key is not found
[   0.2460 ] Parsing dev params for multi chains
[   0.2460 ] Generating br-bct
[   0.2465 ] Updating dev and MSS params in BR BCT
[   0.2466 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2477 ] Updating bl info
[   0.2484 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2488 ] WARNING: boot chain is not completed. set to 0
[   0.2505 ] Generating SHA2 Hash
[   0.2544 ] Sha saved in br_bct_BR.sha
[   0.2522 ] Get Signed section of bct
[   0.2527 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2536 ] Signing BCT
[   0.2559 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2561 ] Assuming zero filled SBK key
[   0.2588 ] Sha saved in br_bct_BR.sha
[   0.2591 ] Warning: pub_key.key is not found
[   0.2568 ] Updating BCT with signature
[   0.2572 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.2575 ] Offset :4608 Len :3584
[   0.2582 ] Generating SHA2 Hash
[   0.2606 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.2607 ] Assuming zero filled SBK key
[   0.2634 ] Sha saved in br_bct_BR.sha
[   0.2613 ] Updating BCT with SHA2 Hash
[   0.2618 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2624 ] Offset :4608 Len :3584
[   0.2632 ] Offset :68 Len :8124
[   0.2636 ] Generating coldboot mb1-bct
[   0.2646 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   0.2650 ] MB1-BCT version: 0.13
[   0.2671 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2674 ] Added Platform Config 9 data with size :- 100
[   0.2677 ]
[   0.2677 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   0.2677 ]
[   0.2677 ] Updating mb1-bct with firmware information
[   0.2682 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2697 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.2701 ] Generating SHA2 Hash for mb1bct
[   0.2737 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.2748 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.2729 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.2732 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.2766 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2767 ] Assuming zero filled SBK key
[   0.2785 ] Warning: pub_key.key is not found
[   0.2766 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2779 ] Generating recovery mb1-bct
[   0.2784 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   0.2788 ] MB1-BCT version: 0.13
[   0.2807 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2810 ] Added Platform Config 9 data with size :- 100
[   0.2812 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   0.2814 ] Updating mb1-bct with firmware information
[   0.2820 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2839 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.2843 ] Generating SHA2 Hash for mb1bct
[   0.2877 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.2885 ] Sha saved in mb1_bct_MB1.sha
[   0.2865 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.2868 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.2901 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2902 ] Assuming zero filled SBK key
[   0.2914 ] Warning: pub_key.key is not found
[   0.2894 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2906 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.2906 ] Copying signatures
[   0.2910 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2989 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2992 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2992 ] Boot Rom communication
[   0.3001 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.3008 ] BR_CID: 0x80012344705E00C83000000014FD8100
[   0.3896 ] Sending bct_br
[   0.4777 ] Sending mb1
[   0.4787 ] Sending psc_bl1
[   0.4898 ] Sending bct_mb1
[   0.4951 ] Boot Rom communication completed
[   0.4986 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.5012 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[   0.5017 ] adding BCH for applet_t234_aligned.bin
[   0.5148 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5150 ] Assuming zero filled SBK key
[   0.5173 ] Warning: pub_key.key is not found
[   0.5155 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.5177 ] Sending mb2_applet...
[   0.5182 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.5185 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.7190 ] Sending applet
[   0.8477 ] completed
[   0.8487 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8493 ] MB2 Applet version 01.00.0000
[   1.0341 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0346 ] MB2 Applet version 01.00.0000
[   1.1250 ] Parsing fuse info as per xml file
[   1.1259 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[   1.1264 ] MagicId=0x45535546 version=0x2
[   1.1271 ] trying to read fuse with MB2 Applet
[   1.1281 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[   1.1296 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.1300 ] MB2 Applet version 01.00.0000
[   1.2963 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.3028 ] Fuse read successful
[   1.3044 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[   1.3059 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.3063 ] MB2 Applet version 01.00.0000
[   1.5072 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.5136 ] Fuse read successful
[   1.5152 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[   1.5170 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.5175 ] MB2 Applet version 01.00.0000
[   1.6952 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.7015 ] Fuse read successful
[   1.7033 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[   1.7053 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.7058 ] MB2 Applet version 01.00.0000
[   1.8901 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.8964 ] Fuse read successful
[   1.8984 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[   1.8998 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.9004 ] MB2 Applet version 01.00.0000
[   2.0780 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.0845 ] Fuse read successful
[   2.0863 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[   2.0884 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.0892 ] MB2 Applet version 01.00.0000
[   2.2659 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.2722 ] Fuse read successful
[   2.2739 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[   2.2758 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.2766 ] MB2 Applet version 01.00.0000
[   2.4551 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.4613 ] Fuse read successful
[   2.4631 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[   2.4648 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.4653 ] MB2 Applet version 01.00.0000
[   2.6599 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.6664 ] Fuse read successful
[   2.6684 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[   2.6695 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.6699 ] MB2 Applet version 01.00.0000
[   2.8649 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.8716 ] Fuse read successful
[   2.8734 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[   2.8750 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.8757 ] MB2 Applet version 01.00.0000
[   3.0532 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.0593 ] Fuse read successful
[   3.0610 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[   3.0626 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.0631 ] MB2 Applet version 01.00.0000
[   3.2530 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.2594 ] Fuse read successful
[   3.2610 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[   3.2626 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.2632 ] MB2 Applet version 01.00.0000
[   3.4409 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.4473 ] Fuse read successful
[   3.4491 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[   3.4509 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.4515 ] MB2 Applet version 01.00.0000
[   3.6150 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.6211 ] Fuse read successful
[   3.6229 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[   3.6247 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.6254 ] MB2 Applet version 01.00.0000
[   3.8081 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.8143 ] Fuse read successful
[   3.8162 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[   3.8180 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.8186 ] MB2 Applet version 01.00.0000
[   3.9749 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.9813 ] Fuse read successful
[   3.9832 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[   3.9848 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.9853 ] MB2 Applet version 01.00.0000
[   4.1701 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.1763 ] Fuse read successful
[   4.1783 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[   4.1797 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.1802 ] MB2 Applet version 01.00.0000
[   4.3579 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.3642 ] Fuse read successful
[   4.3658 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[   4.3674 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.3678 ] MB2 Applet version 01.00.0000
[   4.5802 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.5884 ] Fuse read successful
[   4.5900 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[   4.5927 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.5933 ] MB2 Applet version 01.00.0000
[   4.7892 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.7956 ] Fuse read successful
[   4.7974 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[   4.7998 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.8006 ] MB2 Applet version 01.00.0000
[   4.9850 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.9915 ] Fuse read successful
[   4.9932 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[   4.9950 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.9956 ] MB2 Applet version 01.00.0000
[   5.1743 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.1806 ] Fuse read successful
[   5.1824 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[   5.1841 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.1847 ] MB2 Applet version 01.00.0000
[   5.3679 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.3744 ] Fuse read successful
[   5.3765 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   5.3769 ] MB2 Applet version 01.00.0000
[   5.4748 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   5.4755 ] MB2 Applet version 01.00.0000
[   5.5668 ] Retrieving board information
[   5.5675 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   5.5683 ] MB2 Applet version 01.00.0000
[   5.6579 ] Saved platform info in chip_info.bin
[   5.6642 ] Chip minor revision: 1
[   5.6645 ] Bootrom revision: 0x7
[   5.6645 ] Ram code: 0x1
[   5.6645 ] Chip sku: 0xd3
[   5.6646 ] Chip Sample: prod
[   5.6646 ]
[   5.6651 ] Retrieving EEPROM data
[   5.6652 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   5.6660 ] MB2 Applet version 01.00.0000
[   5.7629 ] 000000001f1e050d: E> NV3P_SERVER: Could not read eeprom for module cvm.
[   5.8427 ]
[   5.8427 ]
[   5.8440 ] tegradevflash_v2 --oem platformdetails eeprom cvm /home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   5.8447 ] Error: Invalid option --chip
[   5.8475 ] Usage: tegradevflash_v2 [--instance <number/path>] [--pt <file>]
[   5.8479 ]                         [--mkdevimages <output_path><directory_separator> [binonly sparse|unsparse fullbinpaths]]
[   5.8480 ]                         [--create ] [--dev [device]]
[   5.8481 ]                         [--download <image_type, file> [load_address entry_point]]
[   5.8481 ]                         [--read <name> <file>] [--write <name> <file>] [--erase <name>]
[   5.8481 ]                         [--reboot <coldboot/recovery>] [--oem <cmd arg2 arg3>] [--iscpubl ]
[   5.8481 ]                         [--setverify <name>] [--verify ] [--ccgupdate <fw>]
[   5.8481 ]
[   5.8481 ]    --instance     USB instance
[   5.8481 ]    --pt           Partition layout
[   5.8481 ]    --mkdevimages  Create boot-device images
[   5.8481 ]    --create       Reareate and write all partitions as per specified Partition layout
[   5.8481 ]    --dev          Specify device to flash. Use with --create option
[   5.8481 ]    --download     download image into memory
[   5.8481 ]    --read         Read a partition into file
[   5.8481 ]    --write        Write a partition with data from file
[   5.8481 ]    --erase        Erase a partition
[   5.8481 ]    --reboot       Reboot the device or put device in recovery
[   5.8481 ]    --oem          Run Oem Command
[   5.8481 ]    --iscpubl      Check if cpubl is running
[   5.8481 ]    --setverify    Set partition verification
[   5.8481 ]    --verify       Verify partition
[   5.8481 ]    --ccgupdate    Update CCG FW
[   5.8481 ]
[   5.8481 ]
[   5.8481 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails eeprom cvm /home/grzegorzp/Downloads/ANOTHER_SCRIPT_MODE/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
Error: failed to generate images
Cleaning up...
I tried another time:
terminal output 2nd time flashing.txt (233.1 KB)
No success :(
Minicom output in non recovery mode:
minicom output in non recovery mode after flashing.txt (52.6 KB)
If I buy second NX Orin 16GB chip and flash it, then change to first one chip, could it boot up and work?
@DavidDDD the most friendliest reminder to advise <3
Thanks for your patience.
Some questions to confirm:
  • Is your ubuntu a native or a virtual machine?
If virtual machine, please prepare a native one.
And follow the vendor https://www.waveshare.com/wiki/JETSON-ORIN-NX-16G-DEV-KIT doc to flash your device.
I also tried: different PC, reinstalled host machine and Jetpack 5. I also formatted SSD drive with I am using with Jetson Board.
It’s a native ubuntu 24.04 x86_64, a desktop set only for flashing Jetson purposes.
Thanks for your information.
After internal discussion, we found that the error
E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
is caused by a failure when reading from the CV-M (Computer Vision Module).
We need you to rerun the SDK Manager and record the serial console log at the same time.
This means:
  1. First, run the command to start recording the serial console log.
sudo minicom -C ./flashing_serial.txt -D /dev/tty${node name} -8 -b 115200 B
  1. Then, run the SDK Manager.
Hello all, here are 2 attempts with different ports and cables.
flashing_serial.txt (5.8 KB)
flashing_serial2.txt (5.9 KB)
Do you have the dev kit to cross check the issue?
If yes, please try moving your module to the dev kit and run the SDK Manager.
If the issue persists, please proceed with the RMA process.
