Effective bandwidth of stencil algorithms
This is a follow-up issue to the comment here: New edition of "CUDA Fortran for Scientists and Engineers" - #2 by ivan.pribec1
I’ve been trying to implement a few exercises following the CUDA Fortran for Scientists book. Chapter 9 contains an example of using shared memory to cache field values, before computing the finite-difference stencil. This is done to improve memory access order and effective bandwidth.
I found a couple of resources that discuss the use of shared memory for stencils:
Before attempting the shared-memory version and the complicated extra work needed to fill the halo cells at block level (more troublesome in the context of higher-order stencils…), I thought I’d try to establish a baseline using the easier directive-based parallelization methods:
! test_xy_der.f90 --
!     Test for effective bandwidth of 2-d mixed derivative FD stencil
!     Uses OpenACC, stdpar, OpenMP, and CUDA Fortran; in other words
!     don't forget the flags `-cuda -acc=gpu -mp=gpu -stdpar=gpu`
! Ivan Pribec, September 3, 2024
module xy_der_mod
implicit none
public
integer, parameter :: wp = kind(1.0d0)
contains
   subroutine set_known_field(nx,ny,f,f_xy)
      integer, intent(in) :: nx, ny
      real(wp), intent(out) :: f(nx,ny)
      real(wp), intent(out) :: f_xy(nx,ny)
      real(wp), parameter :: pi = 4*atan(1.0_wp)
      real(wp) :: x, y, dx, dy
      integer :: i, j
      do j = 1, ny
         do i = 1, nx
            x = (i-1) + 0.5_wp
            y = (j-1) + 0.5_wp
            ! known function
            f(i,j) = sin(2*pi*(x/nx))*cos(2*pi*(y/ny))
            ! second partial derivative w.r.t x- and y-coordinates
            f_xy(i,j) = (-4*pi**2/(real(nx,wp)*real(ny,wp))) &
               * cos(2*pi*(x/ny))*sin(2*pi*(y/ny))
         end do
      end do
   end subroutine
   ! do concurrent version
   subroutine cross_derivative_dc(nx,ny,f,f_xy)
      integer, intent(in), value :: nx, ny
      real(wp), intent(in) :: f(0:nx+1,0:ny+1) ! includes HALO layer
      integer :: i, j
      do concurrent(i=1:nx,j=1:ny)
         f_xy(i,j) = 0.25_wp*(f(i+1,j+1) - f(i-1,j+1) + f(i-1,j-1) - f(i+1,j-1))
      end do
   end subroutine
   ! OpenACC version
   subroutine cross_derivative_acc(nx,ny,f,f_xy)
      integer :: i, j
      !$acc parallel loop collapse(2) copyin(f) copyout(f_xy)
      do j = 1, ny
         do i = 1, nx
         end do
      end do
   end subroutine
   ! OpenMP version
   subroutine cross_derivative_omp(nx,ny,f,f_xy)
      integer :: i, j
      !$omp target teams distribute parallel do collapse(2) map(to: f) map(from: f_xy)
      do j = 1, ny
         do i = 1, nx
         end do
      end do
   end subroutine
   ! CUDA Fortran kernel routine
   attributes(global) subroutine cross(nx,ny,f,f_xy)
      integer :: i, j
      i = (blockIdx%x - 1)*blockDim%x + threadIdx%x
      j = (blockIdx%y - 1)*blockDim%y + threadIdx%y
      if (i <= nx .and. j <= ny) then
      end if
   end subroutine
   ! CUDA Fortran version
   subroutine cross_derivative_cuf(nx,ny,f,f_xy)
      use cudafor, only: dim3
      real(wp), intent(in), device :: f(0:nx+1,0:ny+1) ! includes HALO layer
      real(wp), intent(out), device :: f_xy(nx,ny)
      type(dim3) :: grid, tBlock
      tBlock = dim3(64,8,1)
      grid = dim3((nx + tBlock%x - 1)/tBlock%x, &
                  (nx + tBlock%y - 1)/tBlock%y, 1)
      call cross<<<grid,tBlock>>>(nx,ny,f,f_xy)
   end subroutine
end module
program xy_der_test
use xy_der_mod
implicit none
integer :: nx, ny, nargs
real(wp), allocatable :: f(:,:), f_xy(:,:), approx_xy(:,:)
real(wp), allocatable, device :: fd(:,:), fd_xy(:,:)
integer :: i, j
nargs = command_argument_count()
if (nargs /= 2) then
   call print_usage
   stop
end if
call parse_args(nx,ny)
call print_gpu_info
allocate(f(nx,ny), f_xy(nx,ny))
allocate(fd(0:nx+1,0:ny+1))
allocate(fd_xy(nx,ny))
allocate(approx_xy(nx,ny))
! Set the field to a known periodic function
call set_known_field(nx,ny,f,f_xy)
! Copy Host to Device
fd(1:nx,1:ny) = f
! Fill HALO layers (SOUTH and NORTH)
do concurrent(i=1:nx)
   fd(i,0)    = fd(i,ny)
   fd(i,ny+1) = fd(i,1)
end do
! Fill HALO layers (EAST and WEST)
do concurrent(j=0:ny+1)
   fd(0,j) = fd(ny,j)
   fd(nx+1,j) = fd(1,j)
end do
call measure(cross_derivative_dc, "Do-Concurrent")
call measure(cross_derivative_acc, "OpenACC-parallel-loop")
call measure(cross_derivative_acc, "OpenMP-target-loop")
call measure(cross_derivative_cuf, "CUDA-Fortran-naive")
contains
   subroutine print_usage
      write(*,'(A)') "Usage: test_xy_der <nx> <ny>"
   end subroutine
   subroutine parse_args(nx,ny)
      integer, intent(out) :: nx, ny
      character(len=64) :: str
      call get_command_argument(1,str)
      read(str,*) nx
      call get_command_argument(2,str)
      read(str,*) ny
   end subroutine
   subroutine print_gpu_info
      use cudafor
      type(cudaDeviceProp) :: prop
      integer :: istat
      istat = cudaGetDeviceProperties(prop,0)
      print '("Device name: ", A)', trim(prop%name)
      print '("  Compute Capability: ",I0,".",I0)', prop%major, prop%minor
      print '("  Memory Clock Rate (KHz): ", I0)', prop%memoryClockRate
      print '("  Memory Bus Width (bits): ", I0)', prop%memoryBusWidth
      print '("  Peak Memory Bandwith (GB/s): ", f9.2)', &
         2.0 * prop%memoryClockRate * (prop%memoryBusWidth / 8) * 1.0e-6
      print '()'
   end subroutine
   ! Measurement helper procedure
   subroutine measure(kernel,name)
      use cudafor
      interface
         subroutine kernel(nx,ny,fd,fd_xy)
            import wp
            real(wp), intent(in), device :: fd(0:nx+1,0:ny+1)
            real(wp), intent(out), device :: fd_xy(nx,ny)
         end subroutine
      end interface
      character(len=*), intent(in) :: name
      integer :: istat
      type(cudaEvent) :: startEvent, stopEvent
      real(kind(1.0e0)) :: time, elapsed
      integer :: niter, k
      istat = cudaEventCreate(startEvent)
      istat = cudaEventCreate(stopEvent)
      niter = 1
      outer: do
         istat = cudaEventRecord(startEvent,0)
         do k = 1, niter
            call kernel(nx,ny,fd,fd_xy)
         end do
         istat = cudaEventRecord(stopEvent,0)
         istat = cudaEventSynchronize(stopEvent)
         istat = cudaEventElapsedTime(time,startEvent,stopEvent)
         ! Aim for at least 0.2 s total runtime
         if (time > 200.0) exit outer
         niter = 2*niter
      end do outer
      istat = cudaEventDestroy(startEvent)
      istat = cudaEventDestroy(stopEvent)
      ! Copy results to host
      approx_xy = fd_xy
      elapsed = time/niter
      write(*,*) trim(name)
      write(*,*) "-----------------------------------------------------v"
      write(*,*) "Avg. time (ms): ", elapsed
      write(*,*) "Max. absolute error: ", maxval(abs(f_xy - approx_xy))
      write(*,*) "Sum of absolute residuals: ", sum(abs(f_xy - approx_xy))
      write(*,*) "Sum of squared residuals: ", sum((f_xy - approx_xy)**2)
      write(*,*) "Effective Bandwidth (GB/s): ", bw(nx,ny,elapsed/1000.0)
      write(*,*)
   end subroutine
   ! Effective bandwidth helper function
   pure function bw(nx,ny,time)
      real(kind(1.0e0)), intent(in) :: time ! Time in seconds
      real(kind(1.0e0)) :: rb, wb, bw
      rb = real(nx+1,wp)*real(ny+1,wp)*8
      wb = real(nx,wp)*real(ny,wp)*8
      bw = ((rb + wb) * 1.0e-9) / time
   end function
end program
I get the following output:
$ nvfortran -O3 -fast -cuda -acc -mp=gpu -stdpar=gpu  -o test_xy_der ../test_xy_der.F90
$ ./test_xy_der 8000 8000
Device name: NVIDIA GeForce RTX 2060
  Compute Capability: 7.5
  Memory Clock Rate (KHz): 7001000
  Memory Bus Width (bits): 192
  Peak Memory Bandwith (GB/s):    336.05
 Do-Concurrent
 Avg. time (ms):     11.02239
 Max. absolute error:    1.2683534149091020E-013
 Sum of absolute residuals:    3.2898682391358757E-006
 Sum of squared residuals:    2.5739284138576398E-019
 Effective Bandwidth (GB/s):     92.91339
 Avg. time (ms):     11.02019
 Effective Bandwidth (GB/s):     92.93194
 OpenMP-target-loop
 Avg. time (ms):     11.02028
 Effective Bandwidth (GB/s):     92.93124
 CUDA-Fortran-naive
 Avg. time (ms):     3.672191
 Effective Bandwidth (GB/s):     278.8874
Notably, the CUF version reaches about 80 % of the peak bandwidth (hooray!). But the other approaches reach (only) 30 %, which is also great, given how little effort it took me. Is there anything that can be done with compiler flags or additional OpenACC clauses to reach the CUF speed?
If such differences occur for the simplest of stencils, I’m slightly pessimistic the directive-based approaches will do things right for larger and more complicated stencils.
A friend just warned me that I might be (accidentally) including the host to device transfer time in the measurement. I thought that since the arrays have the CUF device attribute in the main program, the directive based approached would figure the data was already present in the environment.
After adding an acc data clause I see the same rate with all kernels:
!$acc data present(fd, fd_xy)
call measure(cross_derivative_omp, "OpenMP-target-loop")
!$acc end data
(N.b. in the original post, the acc kernel was accidentally measured twice.)
 Do-Concurrent
 Avg. time (ms):     2.068108
 Max. absolute error:    4.0086019241981268E-013
 Sum of absolute residuals:    5.8486541691133547E-006
 Sum of squared residuals:    1.4462015332100809E-018
 Effective Bandwidth (GB/s):     278.5618
 Avg. time (ms):     2.069487
 Effective Bandwidth (GB/s):     278.3762
 OpenMP-target-loop
 Avg. time (ms):     2.069294
 Effective Bandwidth (GB/s):     278.4022
 CUDA-Fortran-naive
 Avg. time (ms):     2.068002
 Effective Bandwidth (GB/s):     278.5762
