Reporting BUG
Synopsis:
[1395:1395:0903/091957.495403:ERROR:ui/gl/egl_util.cc:92] EGL Driver message (Error) eglCreateContext: Requested version is not supported
Warning: eglCreateContext failed with EGL_BAD_ATTRIBUTE
- While trying to discover a BackendType::OpenGL adapter.
at CheckEGL (../../third_party/dawn/src/dawn/native/opengl/UtilsEGL.cpp:98)
Brief Description:
When visiting the chrome://gpu info page of a chromium-based browser, a slew of EGL-related errors occurs and the UI flashes rapidly while loading.
Steps to Reproduce and Frequency:
- Install the chromium package
- launch chromium and visit the chrome://gpu/ page
This is 100% reproducible on Chromium and Brave.
System Configuration: [System model][Operating System][Desktop Environment][GPU][Monitors - Model and Refresh Rates]
- kernel 6.16.4
- hyprland 0.50.1 (-DNO_XWAYLAND:STRING=true)
- sway 1.11 (Native Wayland)
- wlroots 0.19 (Vulkan Backend) (-Dxwayland=disabled)
- vulkan-icd-loader 1.4.321
nVidia 580.82.07
Display (PHL 328E1): 3840x2160 @ 60 Hz (as 2883x1622) in 32" [External]
Display (DELL U2711): 1440x2560 @ 60 Hz (as 1350x2401) in 27" [External]
Additional details: [Screenshots, Screencapture, console output, logs or any details that can help with debugging]
Note: These errors have been occurring for many driver releases and chromium versions. Not new, just newly reported.
Note: This occurs when using latest git versions of egl-wayland
and egl-wayland2
, whether each loaded individually or both side-by-side.
Snippet of errors:
[1395:1395:0903/091957.518913:ERROR:ui/gl/angle_platform_impl.cc:47] SyncEGL.cpp:69 (operator()): eglCreateSync failed with 0x00003009
ERR: SyncEGL.cpp:69 (operator()): eglCreateSync failed with 0x00003009
[1395:1395:0903/091957.519065:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519116:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519157:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.519280:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519310:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519336:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.519409:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519431:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519453:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.519554:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519591:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519617:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.519711:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519734:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519757:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.519869:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.519893:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.519915:ERROR:gpu/command_buffer/service/raster_decoder.cc:1953] [.BrowserWorker-0x1b6c01a34780]GL ERROR :GL_INVALID_VALUE : glCopySubTexture: Dest shared image is not writable
[1395:1395:0903/091957.520269:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.520301:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.520329:ERROR:gpu/command_buffer/service/raster_decoder.cc:2960] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glBeginRasterCHROMIUM: failed to create surface
[1395:1395:0903/091957.520355:ERROR:gpu/command_buffer/service/raster_decoder.cc:3027] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glRasterCHROMIUM: RasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520384:ERROR:gpu/command_buffer/service/raster_decoder.cc:3156] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glEndRasterCHROMIUM: EndRasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520466:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.520489:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.520512:ERROR:gpu/command_buffer/service/raster_decoder.cc:2960] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glBeginRasterCHROMIUM: failed to create surface
[1395:1395:0903/091957.520537:ERROR:gpu/command_buffer/service/raster_decoder.cc:3027] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glRasterCHROMIUM: RasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520561:ERROR:gpu/command_buffer/service/raster_decoder.cc:3156] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glEndRasterCHROMIUM: EndRasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520630:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.520652:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.520673:ERROR:gpu/command_buffer/service/raster_decoder.cc:2960] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glBeginRasterCHROMIUM: failed to create surface
[1395:1395:0903/091957.520717:ERROR:gpu/command_buffer/service/raster_decoder.cc:3027] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glRasterCHROMIUM: RasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520759:ERROR:gpu/command_buffer/service/raster_decoder.cc:3027] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glRasterCHROMIUM: RasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520785:ERROR:gpu/command_buffer/service/raster_decoder.cc:3156] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glEndRasterCHROMIUM: EndRasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520845:ERROR:gpu/command_buffer/service/shared_image/wrapped_sk_image_backing.cc:404] MakeFromBackendTexture() failed.
[1395:1395:0903/091957.520867:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:385] Unable to initialize SkSurface
[1395:1395:0903/091957.520888:ERROR:gpu/command_buffer/service/raster_decoder.cc:2960] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glBeginRasterCHROMIUM: failed to create surface
[1395:1395:0903/091957.520912:ERROR:gpu/command_buffer/service/raster_decoder.cc:3027] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glRasterCHROMIUM: RasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520935:ERROR:gpu/command_buffer/service/raster_decoder.cc:3156] [.RenderWorker-0x2cc40013f600]GL ERROR :GL_INVALID_OPERATION : glEndRasterCHROMIUM: EndRasterCHROMIUM without BeginRasterCHROMIUM
[1395:1395:0903/091957.520977:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:540] Attempt to read from an uninitialized SharedImage. Initialized region: (0, 0, 0, 0) Size: (3840, 512)
[1395:1395:0903/091957.523511:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:540] Attempt to read from an uninitialized SharedImage. Initialized region: (0, 0, 0, 0) Size: (3840, 512)
[1395:1395:0903/091957.525780:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:540] Attempt to read from an uninitialized SharedImage. Initialized region: (0, 0, 0, 0) Size: (3840, 512)
[1395:1395:0903/091957.528052:ERROR:gpu/command_buffer/service/shared_image/shared_image_representation.cc:540] Attempt to read from an uninitialized SharedImage. Initialized region: (0, 0, 0, 0) Size: (3840, 512)
[1395:1395:0903/091957.529916:ERROR:ui/gl/angle_platform_impl.cc:47] SyncEGL.cpp:69 (operator()): eglCreateSync failed with 0x00003009
[1395:1395:0903/091957.530377:ERROR:ui/gl/angle_platform_impl.cc:47] SyncEGL.cpp:69 (operator()): eglCreateSync failed with 0x00003009
Attaching an nVidia Bug Report and full log of the errors.
nvidia-egl-errors-chromium-gpu-page.log (244.4 KB)
nvidia-bug-report.log.gz (1.5 MB)
