Recently I upgraded my Linux NVidia binary driver to 455.45.01 which has now started advertising EGL_EXT_image_dma_buf_import support, unfortunatly it seems to be broken, the following code which is working fine on Intel and AMD GPUs is not working:
GLAttrib const attribs[] =
EGL_WIDTH , 1920,
EGL_HEIGHT , 1200,
EGL_LINUX_DRM_FOURCC_EXT , DRM_FORMAT_ARGB8888,
EGL_DMA_BUF_PLANE0_FD_EXT , dmaFd,
EGL_DMA_BUF_PLANE0_OFFSET_EXT , 0,
EGL_DMA_BUF_PLANE0_PITCH_EXT , 7680,
EGL_NONE
EGLImage image = eglCreateImage(
texture->display,
EGL_NO_CONTEXT,
EGL_LINUX_DMA_BUF_EXT,
(EGLClientBuffer)NULL,
attribs
The fourcc in use eglQueryDmaBufFormatsEXT reports my GPU supports (Quadro K1200). This fails with EGL_BAD_PARAMETER.
This very much looks like a driver bug as I have dug through the Kronos documentation over and over again and can’t find a reason why this would fail only on NVidia hardware.
Additional information that may be of use:
EGL : 1.5
Vendor : NVIDIA Corporation
Renderer : Quadro K1200/PCIe/SSE2
Version : OpenGL ES 3.2 NVIDIA 455.45.01
EGL APIs : OpenGL_ES OpenGL
Extensions: EGL_EXT_buffer_age EGL_EXT_client_sync EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_MESA_image_dma_buf_export EGL_EXT_output_base EGL_EXT_stream_acquire_mode EGL_EXT_sync_reuse EGL_IMG_context_priority EGL_KHR_config_attribs EGL_KHR_create_context_no_error EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_partial_update EGL_KHR_swap_buffers_with_damage EGL_KHR_no_config_context EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_reusable_sync EGL_KHR_stream EGL_KHR_stream_attrib EGL_KHR_stream_consumer_gltexture EGL_KHR_stream_cross_process_fd EGL_KHR_stream_fifo EGL_KHR_stream_producer_eglsurface EGL_KHR_surfaceless_context EGL_KHR_wait_sync EGL_NV_nvrm_fence_sync EGL_NV_post_sub_buffer EGL_NV_quadruple_buffer EGL_NV_stream_consumer_eglimage EGL_NV_stream_cross_display EGL_NV_stream_cross_object EGL_NV_stream_cross_process EGL_NV_stream_cross_system EGL_NV_stream_dma EGL_NV_stream_flush EGL_NV_stream_metadata EGL_NV_stream_remote EGL_NV_stream_reset EGL_NV_stream_socket EGL_NV_stream_socket_inet EGL_NV_stream_socket_unix EGL_NV_stream_sync EGL_NV_stream_fifo_next EGL_NV_stream_fifo_synch
Note: I have also had reports of this exact code failing on RTX2070s also.
Edit: After upgrading to 460.27.04 the error has changed to EGL_BAD_ALLOC, which implies not enough free memory, however nvidia-smi reports I am only consuming 1061/4041 MiB
Edit 2: The open-source nouveau driver performs DMA just fine using this code, indicating it’s certainly a driver bug and not a hardware limitation.
