Hi linuxdev,
i am not really aware with the sensor and the ADC but we have the sensor noise and the read noise. We also have to add the ampglow effect which brings light were there is no light. And temperature is also a problem.
I guess 16b noise is different from 8b noise because of the ADC response and characteristics but i couldn’t tell which one is better.
In the video, it is a bit partial because i use heavy noise management with 16b mode. From what i remember, i did not the same with 8b mode because it was only to show the signal strength difference between the 2 modes.
8 bits could be cleaner with the noise removal filters but i should consider that i would need maximum gain (or much longer exposure time which could be a problem for a video). At maximum gain, even with my noise filters, i can’t manage such gain.
Something really important is the HDR mode with a single 16b exposure. HDR gives … HDR images (for sure) but it is also interesting with noise.
Honestly, JetsonSky makes miracles with M31 capture considering the quite poor quality of the sensor (i mean the sensor & the ADC) and the lens i used (135mm with quite high F/D 2.5). With a 8b capture, very high gaim and small exposure time (between 500 and 1000ms), M31 does not looks like my M31. More important, M110 is clearly visible (hard to see it with 8bits mode).
In a perfect world for my specific purpose, i would need a sCMOS sensor and a wide opened lens with excellent optics to get something really good.
Cooled sensor would be a great help but the price is a bit high (for example, a cooled camera with a IMX533MC sensor cost more than 1000€).
Concerning higher clock rate, it’s also a parameter to consider. Higher clock rate means more noise. With my camera, i can choose 2 capture modes : slow and fast. Fast brings lower image quality and higher noise. My sensor is a rolling shutter sensor which is better for noise. A global shutter sensor is interesting but it brings more noise.
Considering my actual equipment, it will be difficult for me to get much better result with M31. If the setup is the same, 2 things can be improved :
- JetsonSky filters (but for now, i don’t have time to work on it)
- the Sky quality (but it will be hard for me to improve this parameter).
Concerning the setup, it’s always the same problem : the money.
Very good lens will always be expensive. I tried some cheap chineses lens but the quality is not good enough.
Sensors evolution is not really amazing those years. Quite few new sensors with no significant improvements.
Just have to wait.
Alain
