Description
I have a custom model that I have trained using Tensorflow 2.10 and exported to an ONNX model using tf2onnx (python interface, not command line). When importing this model using trtexec I get the following output
[11/24/2022-06:14:39] [V] [TRT] Parsing node: StatefulPartitionedCall/count_nonzero/NotEqual [Equal]
[11/24/2022-06:14:39] [V] [TRT] Searching for input: StatefulPartitionedCall/Greater:0
[11/24/2022-06:14:39] [V] [TRT] Searching for input: StatefulPartitionedCall/count_nonzero/zeros:0
[11/24/2022-06:14:39] [V] [TRT] StatefulPartitionedCall/count_nonzero/NotEqual [Equal] inputs: [StatefulPartitionedCall/Greater:0 -> (1, 100)[BOOL]], [StatefulPartitionedCall/count_nonzero/zeros:0 -> ()[BOOL]],
[11/24/2022-06:14:39] [E] [TRT] parsers/onnx/ModelImporter.cpp:780: While parsing node number 1280 [Equal -> "StatefulPartitionedCall/count_nonzero/NotEqual:0"]:
[11/24/2022-06:14:39] [E] [TRT] parsers/onnx/ModelImporter.cpp:781: --- Begin node ---
[11/24/2022-06:14:39] [E] [TRT] parsers/onnx/ModelImporter.cpp:782: input: "StatefulPartitionedCall/Greater:0"
input: "StatefulPartitionedCall/count_nonzero/zeros:0"
output: "StatefulPartitionedCall/count_nonzero/NotEqual:0"
op_type: "Equal"
[11/24/2022-06:14:39] [E] [TRT] parsers/onnx/ModelImporter.cpp:783: --- End node ---
[11/24/2022-06:14:39] [E] [TRT] parsers/onnx/ModelImporter.cpp:785: ERROR: parsers/onnx/onnx2trt_utils.cpp:888 In function elementwiseHelper:
[8] Assertion failed: elementwiseCheck(inputs, binary_op) && "Elementwise layer does not support the given inputs and operator."
[11/24/2022-06:14:39] [E] Failed to parse onnx file
[11/24/2022-06:14:39] [I] Finish parsing network model
[11/24/2022-06:14:39] [E] Parsing model failed
[11/24/2022-06:14:39] [E] Failed to create engine from model.
[11/24/2022-06:14:39] [E] Engine set up failed
What precisely is wrong with this model?
Environment
TensorRT Version: 8.2.1.8
GPU Type: GeForce RTX 3060 Mobile
Nvidia Driver Version: 520.56.06
CUDA Version: 11.8
CUDNN Version: 8.4
Operating System + Version: Arch Linux
Python Version (if applicable):
TensorFlow Version (if applicable): 2.10
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
