I am having problems running the examples in the 2.1 SDK using device emulation. I installed the 2.1 toolkit and then the 2.1 SDK, compiled the code and ran nbody. I got the following error:
cudaSafeCall() Runtime API error in file <nbody.cpp>, line 610 : initialization error.
I then tried deviceQuery:
[codebox]CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “???”
CUDA Capability Major revision number: 116363
CUDA Capability Minor revision number: -1881129765
Total amount of global memory: 0 bytes
Number of multiprocessors: -1073744616
Number of cores: -22336
Total amount of constant memory: 1 bytes
Total amount of shared memory per block: 106568 bytes
Total number of registers available per block: -1073744680
Warp size: 116438
Maximum number of threads per block: 107360
Maximum sizes of each dimension of a block: 1936287589 x 1601332596 x 123748
Maximum sizes of each dimension of a grid: -1814050492 x 2 x 107036
Maximum memory pitch: 2480916806 bytes
Texture alignment: 2414024924 bytes
Clock rate: 0.03 GHz
Concurrent copy and execution: Yes
Test PASSED[/codebox]
This output does not look like what I’ve seen elsewhere on this forum. I then deleted everything under /Developer/CUDA, installed the 2.0 toolkit and SDK, and compiled all the examples. Now the examples run and deviceQuery shows:
There is no device supporting CUDA.
Device 0: “Device Emulation (CPU)”
CUDA Capability Major revision number: 9999
CUDA Capability Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Has anyone else had issues with emulation in 2.1? I am running this on a first gen MacBook Pro, 2.0 Core Duo with an ATI Mobility Radeon X1600. Any help is appreciated.
Thanks,
Kimo
