Dear NVIDIA Team
We are working on a custom Orin carrier board and are having some issue trying to determine the DTB structure for the USB port. The 2 ports are connected as below:
Port 1: USB2 ----> USB2 / USB3 ----> NVHS1 / UPHY20
Port 2: USB2 ----> USB0 / USB3 ----> UPHY1 (no Cypress / host mode only)
We have configured port 2 following the the adaptation guide but are having trouble figuring out what the DT requirements are for USB3 on port 1 (NVHS1 / UPHY20). Please note that we are also flashing with configuration 2 using ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-1,hsio-uphy-config-16”.
Could you please suggest what changes need to be made to the DT as well as anything else required for this configuration.
Thank you
