Enabling boot loader redundancy on Custom board
To enable boot loader redundancy, I followed “Tegra_Linux_Driver_Package_Boot_Loader_Update_Process.pdf” document.
This guide is working well on TK1 reference Board but fail to our custom board.
We are using CD575M and reference board using CD580M
Below is my flash configuration.
It works on reference board but not on our custom board.
It fail to jump boot loader and goes recovery mode on custom board.
I can’t see any error message why it fail to find boot-loader.
If I disable EB2, EB1, EBT filename and enable only EB3 filename,
it can boot but offline modifications doesn’t work.
From the symptom, looks like boot ROM fail to read BCT or fail to validation hash.
Any clue why this problem happen?
Is there any other constrain or do I need to enable special register?
What can be make this problem?
Please help.
Thanks in advance.
[device]
type=sdmmc
instance=3
[partition]
name=BCT
id=2
type=boot_config_table
allocation_policy=sequential
filesystem_type=basic
size=8388608
file_system_attribute=0
partition_attribute=0
allocation_attribute=8
percent_reserved=0
[partition]
name=PPT
id=3
type=data
size=2097152
percent_reserved=0
filename=ppt.img
[partition]
name=PT
id=4
type=partition_table
size=2097152
percent_reserved=0
[partition]
name=GP1
id=5
type=GP1
size=2097152
percent_reserved=0
[partition]
name=EB3
id=6
type=bootloader
size=4194304
percent_reserved=0
filename=u-boot.bin
[partition]
name=EB2
id=7
type=bootloader
size=4194304
percent_reserved=0
filename=u-boot.bin
[partition]
name=EB1
id=8
type=bootloader
size=4194304
percent_reserved=0
filename=u-boot.bin
[partition]
name=EBT
id=9
type=bootloader
size=4194304
percent_reserved=0
filename=u-boot.bin
[partition]
name=LNX
id=10
type=data
size=16777216
percent_reserved=0
[partition]
name=SOS
id=11
type=data
size=6291456
percent_reserved=0
#filename=recovery.img
[partition]
name=NVC
id=12
type=data		#TEGRABOOT
size=2097152
percent_reserved=0
#filename=nvtboot.bin
[partition]
name=MPB
id=13
type=data		#MTSPREBOOT
size=6291456
percent_reserved=0
#filename=mts_preboot_si
[partition]
name=MBP
id=14
type=data		#MTSBOOTPACK
size=6291456
percent_reserved=0
#filename=mts_si
[partition]
name=APP
id=15
type=data
size=15288238080
percent_reserved=0
filename=system.img
[partition]
name=DTB
id=16
type=data
size=4194304
percent_reserved=0
filename=tegra124-jetson_tk1-pm375-000-c00-00.dtb
[partition]
name=EFI
id=17
type=data
size=67108864
percent_reserved=0
#filename=efi.img
[partition]
name=USP
id=18
type=data
size=4194304
percent_reserved=0
[partition]
name=TP1
id=19
type=data
size=4194304
percent_reserved=0
[partition]
name=TP2
id=20
type=data
size=4194304
percent_reserved=0
[partition]
name=TP3
id=21
type=data
size=4194304
percent_reserved=0
[partition]
name=WB0
id=22
type=data	#WB0BOOT
size=2097152
percent_reserved=0
#filename=nvtbootwb0.bin
[partition]
name=UDA
id=23
type=data
size=2097152
allocation_attribute=0x808
percent_reserved=0
[partition]
name=GPT
id=24
type=GPT
size=0xFFFFFFFFFFFFFFFF
percent_reserved=0
filename=gpt.img
Hi
We are investigating now. Will update here once have any information.
Hi Jack
Could you change your strap pin the same as jetson TK1.
Hi Shane,
Thank you very much.
Our configuration of RAM_CODE[3:0] was 0011 like schematic you posted.
We checked Evaluation board and found it’s configuration is 0010
We changed and it start to work.
Thank you very much for your support.
Hi Guys,
We are facing with very strange problem on bootloader. We created custom board based on TK1 CD575M - A1 with SDIN8DE4 - 16G Taiwan made one and SKYHYNIX CFR-PBA 4 rams. We did full SHMOO test successfully and created necessary files. Successfully flashed IMG files in to the system. However, system stops on very early stage of the booting.
It is very strange because when we flash android os on this exact same system it works. Last month, we made 10pcs of exact same sample boards which were working fine. When we flash L4T in to this system, it shows following error. Please help us to sort out this issue guys. Thanks!
Here I attached my log and i have no clue with this problem at all.
U-Boot SPL 2014.10-rc2-g3127911 (Jun 07 2016 - 21:00:01)
U-Boot 2014.10-rc2-g3127911 (Jun 07 2016 - 21:00:01)
TEGRA124
Board: NVIDIA Jetson TK1
I2C:   ready
DRAM:  2 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie:   I/O: 0x12000000-0x12010000
tegra-pcie:   non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie:   prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
ERROR: tegra-pcie: failed to power on PHY: -110
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/pci/pci_tegra.c:740/)
ERROR: tegra-pcie: failed to enable controller
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/pci/pci_tegra.c:1055)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0...
GPT: last_usable_lba incorrect: 1D58FFF > 1D52000
get_partition_info_efi: *** ERROR: Invalid GPT ***
GPT: my_lba incorrect: 1D59FFF != 1D51FFF
get_partition_info_efi: *** ERROR: Invalid Backup GPT ***
** Invalid partition 1 **
(Re)start USB...
USB0:   USB EHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
USB1:   USB EHCI 1.10
scanning bus 1 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-tegra124
No ethernet found.
missing..
