We are working on Jetson Orin NX based custom board.
We want to enable following PCIE Port. (C7 x1 / C9 x1)
[nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi]
/* C7 X8*/
pcie_c7_rp: pcie@141e0000 {
compatible = "nvidia,tegra234-pcie", "snps,dw-pcie";
/* C9 X4 */
pcie_c9_rp: pcie@140c0000 {
So, we added dtb definition as below.
pcie@141e0000 {/* C7 */
status = "okay";
phys = <&p2u_gbe_0>;
phy-names = "p2u-0";
pcie@140c0000 {/* C9 */
status = "okay";
phys = <&p2u_gbe_1>;
After applied changes to the Board, it worked fine for C7.
[ 10.421053] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 10.421841] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 10.421849] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 10.421853] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 10.421856] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 10.527438] tegra194-pcie 141e0000.pcie: Link up
[ 10.537358] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
On the other hand, the following error occurred for C9.
[ 11.028792] tegra194-pcie 140c0000.pcie: Using GICv2m MSI allocator
[ 11.036104] tegra194-pcie 140c0000.pcie: host bridge /pcie@140c0000 ranges:
[ 11.043287] tegra194-pcie 140c0000.pcie: IO 0x002c100000..0x002c1fffff -> 0x002c100000
[ 11.051993] tegra194-pcie 140c0000.pcie: MEM 0x3828000000..0x382fffffff -> 0x0040000000
[ 11.060682] tegra194-pcie 140c0000.pcie: MEM 0x3540000000..0x3827ffffff -> 0x3540000000
[ 12.176922] tegra194-pcie 140c0000.pcie: Phy link never came up
[ 12.183083] tegra194-pcie 140c0000.pcie: PCI host bridge to bus 0009:00
Could you tell me how we should define C9 to be valid?
