My goal is to get the C7 pins of PCIe enabled in root mode.
I’ve followed the instructions laid out here: Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux<br/>Developer Guide 34.1 documentation
Updated pinmux and gpio bootloader dtsi files as needed for C7 connections.
pex_l7_clkreq_n_pag0 { nvidia,pins = "pex_l7_clkreq_n_pag0"; nvidia,function = "pe7"; nvidia,pull = <TEGRA_PIN_PULL_NONE>; nvidia,tristate = <TEGRA_PIN_DISABLE>; nvidia,enable-input = <TEGRA_PIN_ENABLE>; nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>; nvidia,lpdr = <TEGRA_PIN_DISABLE>; }; pex_l7_rst_n_pag1 { nvidia,pins = "pex_l7_rst_n_pag1"; nvidia,function = "pe7"; nvidia,pull = <TEGRA_PIN_PULL_NONE>; nvidia,tristate = <TEGRA_PIN_DISABLE>; nvidia,enable-input = <TEGRA_PIN_DISABLE>; nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>; nvidia,lpdr = <TEGRA_PIN_DISABLE>; }; -
Updated the tegra234-p3737-pcie.dtsi file such that pcie@141e0000 is enabled:
- pcie@141e0000 {
status = "okay"; -
num-lanes = <8>; -
phys = <&p2u_gbe_0>, <&p2u_gbe_1>, <&p2u_gbe_2>, -
<&p2u_gbe_3>, <&p2u_gbe_4>, <&p2u_gbe_5>, -
<&p2u_gbe_6>, <&p2u_gbe_7>; -
phy-names = "p2u-0", "p2u-1", "p2u-2", "p2u-3", -
"p2u-4", "p2u-5", "p2u-6", "p2u-7"; - };
- Updated ODMDATA to:
ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0”;
Probing the reset signal for C7 we noticed that it remains low and doesn’t toggle at any point on power-up.
Are there any further changes in bootloader or kernel that have been missed?
